Page 22 of 22 FirstFirst ... 121819202122
Results 631 to 660 of 660
Thread: 1967 VH Camaro
  1. #631
    23,311
    Took it for it's first drive today, all good!
    Just need to fix a few little details ie speedo, handbrake
    Oh, and change out the 2.92 gears for some 3.5's
  2. #632
    Slanted big_pete's Avatar
    Sep 2003
    Wagga
    7,684
    A Chuck project on the road
  3. #633
    1,328
    great to hear
  4. #634
    Registered User 308hjute's Avatar
    693
    Like.
  5. #635
    23,311
    Riddle me this, Batman. How the fuck am I supposed to bleed the air out of the system when the filler neck is three inches below the top of the radiator???
  6. #636
    Struggletown
    6,552
    Where do the head bleeders go?
    Also if it's a recovery system it should suck itself full after a few heat cycles
    Hold it flat cunt
  7. #637
    Newcastle
    10,846
    Jack it up in the front right? Seems a bit daft though.
  8. #638
    Shitney
    1,038
    What this cunt said - just run a recovery setup. My cap is below the highest point which is the hot radiator hose. After 2-3 heat cycles it'll push the air out and suck the overflow dry so keep it topped up after each run and it'll be fine. You'll know when it's pushed the air out, your temp gauge wont fluctuate as much.
  9. #639
    7,598
    Crack the head bleeders while car is running
  10. #640
    23,311
    No air in the head bleeders and fitted a recovery bottle. I'll cycle it a few times and see how it goes. Thermostat seems hell high (90ish?) Going to see if I can source a lower one as the carby isn't going to like it that hot, me thinks
    Also got a 28 day UVP that starts tomorrow to cover Xmas testing
  11. #641
    23,311
    Pulled the thermostat today and drilled 3 holes in it. It's an 86 degree one. Took it for a drive and then let it sit idling in my shed (39 degrees in there) for 1/2 an hour and never went over 90, so, that's good.
    I've ordered a 1/2 phonelic spacer kit for it just to try and keep some of the heat out of the carby
    Went through a local drug testing/rbt set up (we have a festival here this weekend) and, after confirming the UVP, had a crowd of 20 cops gawking at it
  12. #642
    10,303
    What's going on with the rear ride height here, I don't remember this being 4wd height previously.
  13. #643
    23,311
    Yeah, I need to play around with that. I added multi leaf springs from a 69 Camaro when I changed to the ford diff
  14. #644
    23,311
    Drove it 100kms today, all good. The stall converter and tall gears are a bit of a pain (and a bit of a temperature concern) so looking to get 3.5 or 3.7s fitted over New Years. Definately got some go and a heap less of a pain to drive than the 5 speed
    Also thoughts on these wheels, please
    http://www.mhtwheels.com/chevrolet-c...11-g-16605.htm
    Also thinking of either ditching the front spoiler or making an alloy, powder coated matt black one that half the height
  15. #645
    14,816
    Not a fan of that wheel chuck, thou looking thru that website i found these similar style that i think looks better http://www.mhtwheels.com/rambler-u121-w-8848.htm
    https://i.imgur.com/D1fJ60C.jpg
  16. #646
    8,936
    Either of those wheels is hot
  17. #647
    Hooroo! Nitephyre's Avatar
    ormeau@gc.qld.au
    6,789
    I like the wheels it currently has. Also, don't retired cops have a special handshake to just get through all that jazz anymore?
  18. #648
    23,311
    They're pretty cheap too
    https://www.ebay.com.au/itm/18x8-18x...4AAOSwKtlWoGRX
    I've sent them a message to see if I can get ford pattern rear, chev pattern front
  19. #649
    4,832
    Quote Originally Posted by Nitephyre View Post
    I Also, don't retired cops have a special handshake to just get through all that jazz anymore?
    as if Allmtr is going to give away ex cop secrets to anyone not in the 'club'
  20. #650
    PF Brisbane Cuntarm
    17,171
    Any of those wheels will look good!
    Oct 2012
    483
    I thought the wheels looked good, Reminds me of the Elanor Mustang wheels, but betterer
  22. #652
    Sep 2003
    Wagga
    7,684
    There’s a couple of Camaro’s in town with those wheels, look the goods, especially with the extra dish on the rears
  23. #653
    Mar 2011
    637
    Were an agent for US Mags aswell, I'll have a look in the morning.
  24. #654
    23,311
    Cool, much appreciated
  25. #655
    23,311
    First hot day of summer so went and picked the kids up from school (about 50km round trip) was funny watching the other kids and parents reaction haha
    Ran really well, had it idling for a while with no problem. Still has the small thermo on it but have a BF one to fit. Also the phenolic spacer arrived but it's a 1" one not 1/2" so back it goes
  26. #656
    PF Brisbane Cuntarm
    17,171
    I've got a new spacer in the shed somewhere but think it might be 1inch also, will have a look tonight as it's just sitting there and not sure I will need it with the EFI set up going on.
    23,311
    Sent it back today and I've already paid for it so no biggie, thanks anyway
  28. #658
    23,311
    Found this in the back streets of Osaka, how cool!
  29. #659
    ormeau@gc.qld.au
    6,789
    Now it just needs a Barra.
  30. #660
    23,311
    You're not borrowing my fuckin Camaro!
