Page 6 of 6 FirstFirst ... 23456
Results 151 to 177 of 177
Thread: CAR HOISTS - 11 different types - Brisbane and Melbourne Warehouse.
  1. #151
    Opens AxGT's Avatar
    Brisso
    1,953
    Thanks Lincoln
    Dirty Subaru owner
  2. #152
    Jan 2011
    Bundaberg australia
    78
    Just placed the order for my HAPP40 to go in the shed, now to play the waiting game for it to arrive so can install it
  3. #153
    Jan 2011
    Bundaberg australia
    78
    Got the hoist up and test run over past few weekends. Can say i am impressed at the quality for price of the Haap 40. Its not far behind the molnar and rotary lift ones we have in the workshop.
    Didnt use the supplied dyna bolts decided to chemset 16mm rod into the slab for less chance of bolt movement.
    Can put the jack and stands away in the corner and enjoy not rolling on the ground.
    Thanks to Lincoln for getting the logistics and ball rolling for me.
  4. #154
    1,230
    I only see one hoist there. I'm forever jacking up cars underneath my project cars that always seem to be on the hoist.
    P.s. nice work shop space mate
  5. #155
    Jan 2011
    Bundaberg australia
    78
    Quote Originally Posted by garvice View Post
    One will hopefully do the job but guess there is always room next to it for a 4 post. Slab only strengthened in one bay for a 2 post.
    If i had more hoists then i will get too busy at home.
    Shed is slowly getting to where i want it. Gotta make up some study benches next, Most the good ones ive seen come with a good price attached
  6. #156
    1,230
    Bit of a thread deflection, but I originally had a 6m bench along one wall. It became a shelf and wasnt usable. Best thing I did was pull it down and use the space for machine/toolbox storage and build a decent, heavy, metal movable fabrication table. Only 1100x900 but has all my welding, cutting, grinding equipment on it.
  7. #157
    Opens ALLMTR's Avatar
    Newcastlish
    23,411
    So, if I use these
    http://happ.com.au/miscellaneous/large-baseplates/
    I can get away with a standard (4 inch thick) slab?
  8. #158
    Pollitically incorrect
    Aug 2007
    7,660
    maybe PM linc. IIRC he is away a lot for work these days.
    .... because every driver experiences the destructive potential of the effortless surge of power available through the smallest of body movements.
    Dr Hoon
    DrNick is king!!!! No, Mark Webber is now! Long live the king!... hold on a minute mate, Ricci is in charge now
  9. #159
    May 2007
    ACT 2607
    1,826
    I am also curious about said plates/concrete requirements
  10. #160
    Smoke em if you got em! LINCOLN's Avatar
    825
    Workcover/insurance will not cover you if there is a failire/accident that is attributed to concrete failure. In practice they do the job very well. All concrete and fasteners must be monitored periodically for pulling.
  11. #161
    Newcastlish
    23,411
    Cool, thanks. Doing some basic (very) maths, me standing on one foot would be more downward pressure on the concrete per square inch than a 1500kg car on that hoist using those plates (obviously there are leverage loads to account for)
  12. #162
    ACT
    1,327
    No one cares about compression loads, concrete is very strong in this regard and why it is such a common building material. If the load was only in compression then you could put a hoist on dirt with no issues.
    Concrete is very weak in tension, which is the load the hoist is putting on it when it isn't perfectly balanced ie always. The hoist is basically a lever trying to pull the concrete up, hence the requirement for a stronger slab with greater force distribution underneath the posts.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
  13. #163
    Newcastlish
    23,411
    Thought i covered that with the parenthesis but yeah, I agree. Problem is adding thickness to an established slab
  14. #164
    1,230
    Hey Lincoln,
    Trying to get an idea of clearance height underneath your 4 post hoists. Need extra floor space in the shed to run my business so thinking of parking my longterm datsun project (going on 6+years without work) on a 4 post and working underneath it. I'm short but don't want to be hitting my head on the long ramps all day long. Website has a lifting height. It's that height of tires off the ground or clearance under all parts of the hoist?
  15. #165
    Owns a Ferrari BeverlyHillsCop's Avatar
    Aug 2006
    Garage
    4,735
    What options are there if I wanted to put a hoist in my garage but the existing slab doesnt meet spec.. what can be done so I can put one in?
    /csh Racing
  16. #166
    Newcastlish
    23,411
    Iíve got their load spreading plates and highly recommend them. Theyíre going to say you need spec to cover their butt
  17. #167
    Registered User Norbie's Avatar
    SEQ, Australia
    3,616
    Bit of a thread dig... trying to get an idea of how hard it is for two average blokes to put up a hoist without any special equipment. Is it doable or should I stop being a jew and pay someone to do it? Currently looking at a HAPP60 clear floor hoist if it makes any difference.
    Norbie!
  18. #168
    17,325
    Not that hard, engine hoist to move each post around, one holds it still while the other walks it up, need a couple of decent ladders, takes some time, easier than I thought
    Sent from my Pixel 2 XL using Tapatalk
  19. #169
    17,325
    Aligning the posts was difficult - trying to find a good reference etc
  20. #170
    1,230
    I installed my 2 post by myself (had someone help me unload from ute) then uninstalled (used the hoist to lift itself over/off the bolts) and reinstalled in the other bay with the help of a mate. Not hard, just take it easy /slow and don't rush.
  21. #171
    SEQ, Australia
    3,616
    Thanks guys, good to know. I have an engine hoist so I should be sweet.
    Norbie!
  22. #172
    17,325
    And if you have been looking for an excuse to purchase a rotary hammer - the dynabolts are it.
    Picked the load up from the freight place on my car trailer - it's a large package... get the trans jack & the oil drain from HAPP at the same time - they are good quality for excellent price.Click image for larger version.
ID:	109449Click image for larger version.
  23. #173
    Newcastlish
    23,411
    I was surprised how easy it was.
  24. #174
    Registered User Justengt4's Avatar
    canberra
    3,646
    The only bit Iím still struggling with is getting the balance cable tension even...Iím still 100mm out each side and nothing I do seems to make a difference?
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  25. #175
    17,325
    One side is higher than the other? The cable routing wasn't massively intuitive... One end of the cables was pretty hard to get to - also needed to be adjusted after it has a few trips up and down - with a car on it..
  26. #176
    canberra
    3,646
    The cable routing is ok but I canít get the tension to even up...tweaked it a dozen times back and forth but one side always ends up tighter?
    GT8
    1UZ Celica
  27. #177
    825
    If it is 100mm out then they are no way near tight enough. The pump side one that pulls the other carraige will need to be tighter. A tube spanner and a rattle gun works well because the cable wants to spin. Show me a photo of how you did it. Got both nuts on one side?
