Calm down cunts, Moby dick is going to Scotty h next week, remote filter setup is here and just waiting on oil cooler.
This shitter has headed to broadtune to check
- voltages from all sensors are within spec eg water temp, air flow meter, oil pressure , temp, oxy sensor as it's dead in the upper mid range
- then stick the wideband on it and check out mixtures (seems stupid rich)
- do the mod that bypasses the alternator for better starting
- supply and fit water temp gauge
- remove 80's spec alarm
- sneak Broadhurst back onto pf around his current ban
#freebroadhurst
DJ's don't need sigs
^ That is really quite a gay image
He's banned? Why?
LOL. You've had one too many Chardy's Damo.
Rich as fuck at low load is common if someone has fitted an oiled air filter at some stage and it rogered the MAF, rich on boost is stock 9:1afr+ is "normal"
they start fine without "mods" reco starter and good battery and alternator (7m-gte alternators love blowing the terminals off the rectifier / stator )
toyobd1 includes an over temp alarm, there is no where in an ma70 that is not gay for an extra gauge unless you hack the dash up and remove the ciggy lighter
Alarm : http://www.ebay.com.au/itm/190977557308?
I think the starting is actually due to fuel pressure perhaps or ECU not getting the mixture correct due to faulty sensors. Will know more tomorrow anyway.
Holy shit 9:1 fuck me were the test drivers blowing head gaskets or something on leaner mixtures?
Re starting mod:
http://www.supramania.com/forums/sho...ter-Relay-Mod)
I spoke to Scotty hoffmann re what he knows about 7m's: "I know how to pull them out"
You don't need the starter mod till like 300,000km lol
Yeah that looks gay, sorry.
I didn't want to hack up the dash or mount it on the steering column so that was about the only option.
Yes we Chemistry
Do you need a boost gauge? How often do you look at it?
But mine has a boost gauge from factory.
I'm vacillating between dirtyrex's opinion and wanting something like this
https://youtu.be/C_raKYG7SLQ
I removed cig lighter and hole sawed the soft plastic fascia in mine and slapped the gauge in there. Did the job. Never looked at it once.
Cool cars, blew a lot of dosh on mine trying to get it right for the track but ended up selling after the third wiring job. Best looking 80s jap car when done right.
replace the clock with something like this...
http://www.projectz61.com/design/arduino-boost-gauge/
