Page 32 of 48 FirstFirst ... 2228293031323334353642 ... LastLast
Results 931 to 960 of 1439
Thread: Eds Lotus 116 GT3
  1. #931
    GTFO of my ED doctor ed's Avatar
    irgendwo
    4,510
    also got a chance to pay a bit of attention to the intercooler piping, and cut stuff properly to size. 3" hose/pipe isnt small, and im not exactly blessed with space here! pretty happy with the way it all lines up though. nice short run from the compressor outlet to the throttle over all.
    W2A core fittings are 3", so post cooler piping is all 76mm stepped down to 70mm with a silicone reducer immediately before the throttle body
    Mit freundlichen Gre
    Quote Originally Posted by Keith Duckworth View Post
  2. #932
    1,758
    It's all about packaging....
    Looking great.
    " I didn't have $$$$$, so I thought I'd build a car instead" : Ron Tauranac
  3. #933
    Shaved cunt Andrew Bolt's Avatar
    3,913
    Able to use an oval or square section over the top of the engine?
  4. #934
    irgendwo
    4,510
    Ive got an 80x26 oval section in my sights. Ive ordered a regular 63mm 45deg bend for now, and see how it fits, but the oval is there as plan B
  5. #935
    Registered User Norbie's Avatar
    SEQ, Australia
    3,613
    Starting to look like real progress! Skids any day now.
    Norbie!
  6. #936
    irgendwo
    4,510
    the devil (and time) in the details
    plonking the engine kindve means its mostly all done. just bolting stuff up now and figuring out stuff like pipework
    that said, its basically our 2y anniversary. pic from 04/02/2016. didnt start with much!
  7. #937
    Loving teh titties.. carcrazy's Avatar
    Central Coast - NSW
    3,155
    Its always amazing to see cars come back from the point of destruction to live a new life with lots of powers.
    Good work.
    Quote Originally Posted by Einstein
    The definition of insanity is repeating the same action and expecting a different result
  8. #938
    Registered User jimmyg's Avatar
    Mar 2009
    Bendigo, Vic
    1,700
    2 years! Wow the times gone fast!
    Mmmmmmmmm beer.
    You had one fucking job, Imran. One. Now look, there's Flibberty Gibbets all up in here, seeing straight through your ruse. One. Fucking. Job!
  9. #939
    Registered User Justengt4's Avatar
    canberra
    3,646
    Looking good...80% done, 50% to go
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
  10. #940
    irgendwo
    4,510
    Quote Originally Posted by Justengt4 View Post
    seems about right. i started making a list of things to do to get it running... hmm. its a long list
  11. #941
    irgendwo
    4,510
    the 'wobbly' oulet fitting in the fuel filter has been weighing on my mind. Internet says this is pretty common, but theres also stories of the things leaking and spraying fuel... something id like to avoid from an 044 on full noise. so bought a slightly different fitting with a longer shaft that seats on the internal orings. checked the position and conditions of the o-rings in the filter (which is new) and everythings Looks as it should. gut feeling reckons the new Fitting is more stable, but it still has a bit of play. not really sure theres much more i can do, just suck it and see.
    also started tacking the exhaust together. somehow teh HF Start on my welder seems to have died? nee to scratch start a TIG - which sucks. at least im only tacking at present.
    3.5" OEM Dump Pipe - not bad for a factory config on a relatively small turbo!
    (edit, Jesus i need to take some pics in daylight. my eyes!)
  12. #942
    Mar 2009
    Bendigo, Vic
    1,700
    Mmmmmmmmm beer.
  13. #943
    irgendwo
    4,510
    hopefully the lighting isnt as shit in these photos...
    3.5" dump to cat, v-banded, flex-piped. tacked ready for welding. not really much of an exhaust system to speak of!
  14. #944
    Registered User schnitzelburger's Avatar
    syd
    2,792
    yeah i like that, thats sweeeet
    Turbo NB MX5: more derp less carbon lightyear clone
    Supra sold it: 1983 MA61 Supra - 2JZ-GTE + 6spd
  15. #945
    1,864
    would just keep the compressor outlet pipe the same size till it's over the engine then try and spread the size transition to the cooler over the down-leg distance say down to a 2.5 90' and then into the 3' cooler
  16. #946
    irgendwo
    4,510
    Quote Originally Posted by doctor ed View Post
    did some quick BOTE maths...
    1.5mm walled 80x26mm oval has a sectional area equivalent of a 49mm OD 1.5mm walled tube (46mm ID) = 1657mm^2
    1.5mm walled 63mm pipe (60mm ID) has in comparison a sectional area of 2827mm^2
  17. #947
    irgendwo
    4,510
    low-ball offer on a H2 Hummer airbox from the states got accepted... looks like ill be giving this a go
  18. #948
    irgendwo
    4,510
    Sunlight!
    Couple of pics of the new firewall and how clearance to the seat worked out (with my new seat brackets lowering and reclining the seat a chunk over stock)
  19. #949
    irgendwo
    4,510
    And a bit of a step back - current state of affairs in the shed...
  20. #950
    cunning linguist lickmyleftone's Avatar
    Mt Cotton
    4,445
    You Sir, has skillz.
    The World's Best Pest Control in Brisbane, at PF mates rates, PM me.
    when all else fails, hit it harder.
  21. #951
    8,544
    That's looking really good.
    Registered User lightyear's Avatar
    Mar 2010
    Bentleigh Victoria
    3,560
    It's going to be so satisfying to jump in and drive it I bet. Small exhaust is a light exhaust. With these small cars its worth the effort to get the seat back and down as far as possible. And a good weekend trip to the ring once it's sorted will be in order.
    NA8B 89KW- P.I. 1:50.1, WNTN1:38.0, SDWN 1:27.6, WKFLD 1:10.4
    NB8B 181KW- P.I 1:43.8, WNTN 1:32.9, SDWN 1:22.0, BDFD 1:05.3
    VP 293KW- P.I 1:43.8 WNTN 1:33.5
  23. #953
    irgendwo
    4,510
    Cheers blokes!
    Sat in it and made broom-broom noises yesterday. Didnt have the keys with me tho, the steering column locked, and the fun was over
  24. #954
    irgendwo
    4,510
    H2 Hummer Airbox is a tad bigger than expected. Not too bad, but still impressively large. Filter outlet fitting is a random 108mm - matches perfectly to my 80mm MAF and 60mm compressor inlet. lol. Need to figure how best to mount it, but for now I just want it bodgied together so itll run
  25. #955
    1,864
    no side intake infront of the back wheel?
  26. #956
    Registered User I'm DJ!'s Avatar
    Jan 2012
    Beach-ville
    9,010
    This thing is sex
    Quote Originally Posted by thebluerx7 View Post
  27. #957
    canberra
    3,646
    Quote Originally Posted by TRD-MX62 View Post
    Yeah I agree...intake off the rear in all that turbulent flow might not be the best?
    That airbox does look comically large compared to the teenie weenie turbo
    Overall it's looking very purposeful ...the wheel/paint combo looks awesome.
    GT8
    1UZ Celica
  28. #958
    irgendwo
    4,510
    One option originally was maybe a side duct feed, but its too obnoxiously large for that. Like I said, not sure how to mount it now. Something neat will sort itself out
  29. #959
    1,864
    photos of the side duct area and the filter near said area? maybe chop the big angled end off and then get out the corflute
  30. #960
    irgendwo
    4,510
    Wont have a pic for a couple of weeks, but trust me, it wont fit even sawing off the curved duct (which will likely get chopped anyway).
