Page 31 of 41 FirstFirst ... 21272829303132333435 ... LastLast
Results 901 to 930 of 1203
Thread: Eds Lotus 116 GT3
  1. #901
    SEQ, Australia
    3,314
    Spinny things and shiny pipes. Do like.
    Norbie!
  2. #902
    irgendwo
    4,279
    got the firewall installed for good...
    sits in pretty well actually, quite happy how it worked out, and didnt get sikafelx absolutely everywhere
    Mit freundlichen Gre
  3. #903
    irgendwo
    4,279
    page 3 eh? im slipping...
    got the turbo flange (12mm alloy compressor and 12mm stainless turbine) receiver grooves machined...
  4. #904
    PF Brisbane Cuntarm
    17,136
    Sweet flange bro.
    irgendwo
    4,279
    no one likes a leaky flange, mate
  6. #906
    8,904
    Is flange, is good.
  7. #907
    15,963
    Top one before prison, bottom one after?
  8. #908
    irgendwo
    4,279
    Top one before pregnancy, bottom one after?
    Fixed
  9. #909
    irgendwo
    4,279
    firewall and intercooler now all back together with some fiberglass heatshield/deadender sheeting. itchy fucking stuff to work with
  10. #910
    irgendwo
    4,279
    everything out... getting ready to go back in for the last(?) time. hopefully get it all done this evening
  11. #911
    Jul 2009
    Inner Westside/Sydney
    1,250
    Makes the fd look like a nugget.
    How do those gearbags hold up to power?
  12. #912
    irgendwo
    4,279
    Pushing 1400kg around they have a habit of munching shaft bearings (even on low power oem diesel applications). Theres some oiling mods that you can do to increase volume, theres a service bulletin with an updated casing with bigger bearings plus extra oil galleries and reinforcement etc. combined with only pushing half the weight around Im hoping it wont explode. Other than the bearing failures though, they seem to hold up ok.
  13. #913
    Mar 2009
    Bendigo, Vic
    1,696
    So what fuels do you have over there?
    Eg pump closeish.
    Mmmmmmmmm beer.
  14. #914
    irgendwo
    4,279
    Fuck all. Though 98 at the pump is standard fare at least.
    E85 lost its tax exemption last year, became more expensive than ULP, plus there's some weird anti ethanol media bandwagon and public mistrust, so it's essentially no longer available anywhere.
  15. #915
    irgendwo
    4,279
    so, -3degC in the shed, and i still cant feel my feet, but this happened...
    and in the process of that, this happened. fucking stud fouled the rear subframe. so out with the stud, cut down a diff crownwheel bolt and continued
    then this became obvious (in retrospect you can see it in the pic above) - the wastgate actuator also decided to foul on the subframe.
    so loosened the compressor housing, and rotated it a poofteenth. 2mm to spare now
  16. #916
    irgendwo
    4,279
    and how its looking as i walked out
  17. #917
    8,904
    I went fishing this morning, opened this thread and every jellyfish within cooee got an instant horn.
  18. #918
    syd
    2,699
    well done mate
    is it worth looking into skimming the face of the exhaust manifold on a bevel to lift the turbo a smidge more?
  19. #919
    irgendwo
    4,279
    Im going to try tilting the engine a little on the mounts
  20. #920
    syd
    2,699
    Titz
  21. #921
    irgendwo
    4,279
    Had a look at what degrees of freedom were available in the mounts to free up some space.
    Tilting the motor unfortunately doesn't achieve anything where needed. The edger the motor near the subframe tends to rotate on an arc tangential to the subframe, so there's no win in terms of absolute clearance. What would be needed is a forward shift of the upper mounts, as well as a rotation of the lower mounts. To do that I'd need to slot the upper mounts about 5mm, and yeah, nah.
    Dominik (wiring guy) was talking about bending the actuator mount, but be fucked if I can get to one of the mounting bolts without disassembling the whole turbo assembly. Apparently I need to be a small double jointed female Asian to do this.
    Anyway, after a lot of jacking the motor and shifting mounts around with a crowbar, I bolted it all back down again without changing anything.
    Soo... Went back to the compressor housing, backed it off and rotated it a bees dick further. I uncoupled the shaft from the wastegate and tried to line things up better, ended up bending a kink in the shaft so everything operates straight, adjusted a few hardlines, and it's all now sitting with 4-5mm clearance.
    Not heaps, but I suspect enough. Hopefully the mounts are stiff enough, and the motion of the motor is so constrained that it doesn't try and bang things together
  22. #922
    5,889
    Surely cut/weld a notch into the subframe would be an easier fix?
  23. #923
    Jun 2007
    QLD / NZ
    477
    Would bolting the actuator on the front side of the compressor housing and extending the actuator shaft gain any space?
    If in doubt, flat out!
  24. #924
    irgendwo
    4,279
    And one more pic... Europa S driveshafts looking pretty:
    So, to quickly summarise the bits making this work
    - A20NFT 2L DI Turbo (Ecotech/B207 family)
    - M32 6Sp Box from some 2.2L Opel/Vauxhall
    - Europa S left/right motor mounts
    - Europa S front/rear torque mounts
    - Europa S driveshafts
    - Tesla Roadster uprights (first car in space!)
    - SKF Hubs
  25. #925
    irgendwo
    4,279
    Quote Originally Posted by toyabusa View Post
    If I could be fucked actually disassembling the whole assembly to get the actuator free I'm sure there'd be a couple of possibilities
    Notching would work. Banging it with a hammer would be better. Material is pretty borderline to be fucking with.
    That said, it's actually not bad as it is, so I'll wait and see if it actually hits before I spend too much more time worrying about it. Gut feeling is that it'll be fine
  26. #926
    Jun 2007
    QLD / NZ
    477
    All good. The whole things looking great!
  27. #927
    irgendwo
    4,279
    spent the arvo tidying up, measuring some stuff, and doing some small bits so i could start calling things 'done'
    as mentioned above, i managed to get the gap to the wastegate actuator out to 4-5mm. tried putting the car in 1st gear and rocking it to see what a torque load did... barely moved 1mm, and after thinking to myself hey, thats pretty good, i realised that the lower motor/torque mounts werent even fastened. so yeah, hopefully itll be just fine
  28. #928
    irgendwo
    4,279
    started looking at exactly how much space ive got to bring the compressor outlet pipe straight over the top of the engine and down into the cooler core.
    63-76mm reducer elbow into the cooler core
  29. #929
    irgendwo
    4,279
    over the top of the engine is tight. 63mm might be a little optimistic, but the alloy coupler pictured is around 70mm. conveniently the mesh insert of the motor cover is in exactly the right place to allow a bit of room to get a pipe past. its going to be tight, but everything is tight, so no surprises really. as long as its doable
  30. #930
    irgendwo
    4,279
    edit - double
