Page 6 of 7 FirstFirst ... 234567 LastLast
Results 151 to 180 of 210
Thread: 13's for $1300 Barina SB #2
  1. #151
    Death is for pussies... 6000SUX's Avatar
    Aug 2006
    3,013
    Mr Bugle...... I used to own an SB Barina GSI in the early 2000's that we used for recce in the Australian Rally Championship. I've long since sold the car BUT I still have a set of Murray Coote Proflex suspension from it. They've been sitting in my garage for a long time so they may need some attention but if you want them then they're yours. All you need to do is pay for the freight or arrange for it be transported to you. They are in Camp Hill, Brisbane. PM me if you're interested!
    Can I wear the Scream mask? The mask from Scream... when I do you from behind...
  2. #152
    Get your azz to mars bugle's Avatar
    Sydney rAmR0d'
    4,048
    I'd buy that for a dollar!
    Sent you a pm
    as short as possible
  3. #153
    Mar 2013
    Cairns, 'Straya
    43
    Water injection? Octane on demand
  4. #154
    Sydney rAmR0d'
    4,048
    Yeah I could try that. Hadn't considered it before.
    I'll probably end up with another engine and building it for more boost eventually..
  5. #155
    logan
    7
    Hey mate just a quick question what drive shafts have you used
  6. #156
    Sydney rAmR0d'
    4,048
    I used the original shafts
  7. #157
    Jun 2007
    742
    Quote Originally Posted by 6000SUX View Post
    Fuck me, they must be the only set ever made! Great pickup for this thing.
  8. #158
    Aug 2006
    3,013
    I found them!
  9. #159
    Sydney rAmR0d'
    4,048
    Sweet thanks, let me know how much I owe you and where to send it!
  10. #160
    Aug 2006
    3,013
    Mr Bugle... check your pm's! I need a physical address for the courier!
  11. #161
    Two years in Lompoc... Lobster's Avatar
    6,339
    Any updates?
    CJM 4 Life yo!
  12. #162
    VIC
    1,118
    Quote Originally Posted by Lobster View Post
    Any updates?
    Can confirm Thomas does some nice fab work and it drives quite well
  13. #163
    Jan 2016
    300,102
    Indeed. It looked quite tidy at Kiama the other day.
  14. #164
    Registered User I'm DJ!'s Avatar
    Jan 2012
    Beach-ville
    9,010
    And then
    Quote Originally Posted by thebluerx7 View Post
  15. #165
    Sydney rAmR0d'
    4,048
    Yeah it has been going alright, just a couple of problems with the cooling system. First the heater tap started leaking so changed that. Then this other hose on the firewall side of the engine started leaking when I got stuck in traffic or right after shutting it off. Fun times getting to that one especially with spring clamps.. Bloody expensive piece of hose too.
    Also the muffler motor mount broke off because they only tack welded it. Only had one tack left by the time I went to fix it so lucky it didn't completely fall off. Next problem with that was that the open position stopper was about a 3mm diameter rod. and the motor was able to bend it. I had some 10mm stainless rod so used that. It doesn't bend.
  16. #166
    Sydney rAmR0d'
    4,048
    At the Gemini nationals because my Piazza doesn't work
    Found a big potato along the way
  17. #167
    Sydney rAmR0d'
    4,048
    So apart from the cooling it has been perfectly reliable. Fuel economy is probably similar to the original engine at about 6-6.5L/100.
    Need to look at ignition tuning, at the moment it's running a computer generated map. I need a dyno.
    Waiting on a custom front swaybar with a dip across the front. Currently using a GSi one spaced down 40mm to clear the turbo, but this is not ideal as the wheel hits it on full lock.
    Will hopefully get to the drags sometime in the next month.
  18. #168
    VIC
    1,118
    You had to post a photo with my headlight grille about to fall out didnt you.
  19. #169
    Canberra Nth
    3,103
    Someone said "why is some gay barina following us everywhere"
    I told them promptly to shut the fuck up.
    BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe
    - PSN: rotacoupe
  20. #170
    Sydney rAmR0d'
    4,048
    Nick did you fix it before it completely fell out?
    I'm ok with people thinking it's just some gay Barina, and then chopping them.
  21. #171
    VIC
    1,118
    Yeah, clip rattled loose from wakefield. Just needed to clip it back in.
    BeepBeep needs an obnoxious dose pipe and a set of factory Barina GSi alloys for more lols. Seriously if the thing runs a mid 13 and lower it would be a fucking riot on the road chopping all manner of Golf GTis, Commos/Falcons etc
  22. #172
    Registered User 9triton's Avatar
    4,861
    Quote Originally Posted by bugle View Post
    .. Bloody expensive piece of hose too.]
    hope it didn't bust your $1300 limit..
  23. #173
    Sydney rAmR0d'
    4,048
    It gives plenty of dose noises with the current setup. Those GSi alloys are horrible, I think i'd prefer Ronal Teddys
    If I included the new stuff I did to make sure it would be a reliable car that handles well and stops I'm well over $1300. But I'm pretty sure I just broke the $1300 on the engine and mods anyway. The clutch and ECU/wideband were the most expensive bits.
  24. #174
    What goes here? 23Kev's Avatar
    3,949
    Seems pretty similar to my old Swift GTi that I stuc a T25 to.
    Ran a mid 14 back in the day but was always traction limited. Would keep up with low 13 sec cars once moving anywhere above 40km/h. Always annoyed me I could never get a 13 sec timeslip as I knew it was that fast. Had about 150hp at wheels, weighed a bit over 900kgs.
    I survived the patio flooding catastrophe of 2012.
  25. #175
    Sydney rAmR0d'
    4,048
    I made the screamer, haven't tried it yet. I now have this problem where it will go to the set boost and then after 4500rpm it will go near 10psi where it hits the boost cut. Doesn't do it with the muffler closed, but then it doesn't have as much power either. I thought a 38mm wastegate would be big enough for a 1.8 litre, so maybe something is limiting how far it opens.
    Also got the custom swaybar to clear the turbo from signature swaybars. I think i specced it slightly lower than it needed to be, it's about level with the sump plug though.
  26. #176
    deep south, NSW
    3,216
    Did you put those fancy shocks in, and what did you do with the old ones? did you want to sell them?
  27. #177
    Sydney rAmR0d'
    4,048
    Haven't got them yet. If I get them onto my car i'd probably sell the Konis. They weren't terribly expensive brand new though, I think it was around $800 posted from the UK for the whole set.
    Got Federal 595-RSR's on now, 205/45/16 which looks to be the widest possible tyre without bodywork modifications.
    Going to take it to the drags tomorrow and see what happens. Guessing either a fried clutch or a 14, or both.
  28. #178
    VW Service Bloke Sloth's Avatar
    3,788
    i reckon low 14 dependant on launch and 60 foot. a mate had a 1.6 8v version with a t25 making 180bhp and it would run 14.1 like clockwork
    Only be concerned if that Dunning-Kruger Motorsports bloke is there and goes all Captain Damphands McGigglefingers on you after a couple of lemon squashes....
    I'M NOT A HOOKER BUT 20 BUCKS IS 20 BUCKS...
    robslothyoung - follow me on insta.
  29. #179
    Jan 2012
    Beach-ville
    9,010
    Love this, good luck at the track
  30. #180
    deep south, NSW
    3,216
    Got same tyres on ours. Which track are you going to?
    Sent from my SM-G950F using Tapatalk
