Page 5 of 8 FirstFirst 12345678 LastLast
Results 121 to 150 of 213
Thread: 13's for $1300 Barina SB #2
  1. #121
    Canberra Nth
    3,231
    So you're bringing this to Geminats then
    - PSN: rotacoupe
  2. #122
    Sydney rAmR0d'
    4,048
    Quote Originally Posted by no13b_Coupe View Post
    Maybe give this a go on the track if anyone drops out, will be surprised if I can get the Piazza going again by then.
    as short as possible
  3. #123
    Shitney
    1,082
    Take a log and see if you're getting tooth errors causing sync issues. I've seen that cause stumbles and sometimes stalling which is usually noise or interference on the TachIn. See if this helps (from the docs):
    "Optionally, when adjusting R56, you can measure the voltage at the "top" of R54. You'll need the board powered
    up. Set your meter to volts, and connect the +ve probe to the top of R54 and the -ve probe to ground. Adjust
    R56 to get around 2.5V on your meter."
    If you're getting noise on the TachIn, this helps prevent the computer from thinking the noise is a tooth on the wheel and fucking up the trigger wheel signal. Keep in mind though, if it doesn't start, the air gap might be a bit too big between the sensor and the wheel so if you can't tighten the gap up
    you might need to lower the voltage until you get a signal. If you have an analog meter or a scope you might be able to trace the peak voltage when cranking and set R65 about 0.5V below what you measure. Where does the shield get grounded? At the ECU end of the sensor end? (not both I hope).
    HTH
  4. #124
    Shitney
    1,082
    Oh and if you're not running "Noise Filtering", try enabling it also. I usually enable it on all the cars I do. Distributor cars I'll also turn on Tach Period Rejection, but trigger wheels usually don't need it.
  5. #125
    Canberra Nth
    3,231
    Yeah bring it to the cruise anyway. Piazza next year
    And yeah I'll drop you a line if that happens man.
    - PSN: rotacoupe
  6. #126
    Sydney rAmR0d'
    4,048
    I'll play with it on the weekend starting with logging. Started work last week so have limited time on it again, and the car is at my parent's house.
    Have an analog meter and a scope if needed. The cable is only grounded at the ECU. Not sure if I can get the pickup any closer to the wheel, there's no adjustment as standard.
    Many other non Isuzus going to the cruise Jonno?
  7. #127
    Canberra Nth
    3,231
    Yeah couple of datsuns. Probably a falcon or two a lame wrx.
    Was talking to a fella up here who has a piazza as well. He's talking about bringing his MU down lol
    - PSN: rotacoupe
  8. #128
    Sydney rAmR0d'
    4,048
    Finally figured out what was wrong with the low rpm stalling. If I set the trigger to falling edge instead of rising edge it works perfectly. Have gone for a few test drives without a problem with it self tuning. Wastegate pressure with the lightest spring seems to be at 5psi (was supposed to be 7), added boost control to the MS2 so I can adjust that. I think the next spring up was 14psi which might be too much.
    Feels pretty fast. Have never driven a fast FWD car before so torque steer is new to me.
    Tidied up the wiring a bit.
  9. #129
    Jan 2013
    3,923
    i was thinking about this the other day. im about to sell mine. its done i just havent run it in anger. dirvorce means no toys.
    hows the ms2 to set up etc?
  10. #130
    1,397
    That's way neater than factory. Nice work!
  11. #131
    Mar 2013
    Cairns, 'Straya
    43
    If you're concerned about intercooler flow, post a few pics of the intercooler as fitted, the underside of the front bumper (looking up), the gap between the cooler and radiator, any gaps between them all and the body, etc. Enough to see any possible airflow path. I'm certain I could offer some advice to help with that.
    My own car (A Suzuki Mighty Boy) had an engine swap and a front body kit that were poorly executed. It overheated in traffic, the fan operated until about 60km/h, and if you were overheating and then drove to 80km/h it took about a minute or two to come down to temp. With the application of some real estate sign and an old foam mattress (held on with zip ties) I dropped 80km/h cruise temps by about 5 degrees, any forward motion above about 10km/h didn't need the thermofans. If you were stopped at lights and it got hot enough for fans (which now took a while), it cooled down by the time you *got* to 80km/h, and generally solved all temperature problems. Air pressure across the radiator jumped by some 80% (meaning that airflow through it increased by around 40%). And I didn't even do it right. I could have got another 20-30% of airflow with another hours work, but it didn't need it.
  12. #132
    9,051
    Oh mighty boys are awesome kiwi bloke! Build thread? /It
    This looks great man!
  13. #133
    Mar 2013
    Cairns, 'Straya
    43
    Kiwi? Oh I mustn't have updated my info. I'm back in 'Straya now. No build thread, I didn't do the work and the car's gone.
    Build thread on my 13's for $1300 all-motor AU though, I can do that.
  14. #134
    HUGH MUNGUS InsaneAsylum's Avatar
    1,733
    That looks bloody awesome, nice job.
    It's not torque steer, it's activating the "surprise lane change" feature. It gets really funky in the wet
  15. #135
    8,707
    This is cool. Needs to be reshelled into a Combo van!
    Sonova Beach
    6,748
    *Cabrio.
  17. #137
    16,462
    Pity we never got the Tigra.
    Actually, looking at that pic, it's probably a good thing we didn't get it. Pity we didn't get the Puma.
  18. #138
    1,373
    But we got the later convertible Tigra so you can satisfy your desires
  19. #139
    Canberra Nth
    3,231
    Apparently the HSV version is good?
    - PSN: rotacoupe
  20. #140
    Sydney rAmR0d'
    4,048
    Why no toys? Especially ones that aren't really worth any $.
    MS2 is pretty easy to set up, having a distributor makes it simpler because it's not setup to run COP straight out of the box, but that's not hard to add.
    But then again sometimes you run into a problem like what I had and it takes a bit of time to figure it out.
    Quote Originally Posted by BLSTIC View Post
    It doesn't have any overheating problems, just that about half the intercooler has no direct air flow, i'm sure it circulates up behind the bumper a bit. I don't think it matters much though after looking at the logs.
    Did some tuning tonight, got it running 7psi and tuned decent through the whole power and cruise range up to redline and it's pretty damn fast.
    Datalogs say the intake temp was 27 degrees on boost and ambient was maybe 1 degree lower than that, temps don't seem to rise at all with boost anyway. It only got up to 40 degrees with the car sitting idling.
  21. #141
    Sydney rAmR0d'
    4,048
    I don't mind the Tigra front stuck on a Corsa though
  22. #142
    Sydney rAmR0d'
    4,048
    How's this for no lag? This would be 2nd gear starting at 2600rpm up to 5500rpm with slight wheelspin
  23. #143
    Old Pac
    6,866
    Was along for the ride when tuning last night. This is a stupid, ridiculous car and I love it. The in gear response is insane, accelerating to pass someone and you easily end up at twice the speed as intended. The thing makes boost free revving in neutral. Also makes all sorts of fknwhoosh noises, pretty much all the time because its instantly on boost.
    The 1.8 N/A makes over twice the original HP, so at 7psi or so, would be about 3x the original barina power.
    Will try to get some videos in daylight.
  24. #144
    16,462
    Yeah, that works!
  25. #145
    Sydney rAmR0d'
    4,048
    Wonder how much power I'll need to run a 13. Rego says it weighs 820kg, I might've added around 50kg to it.
  26. #146
    Mar 2013
    Cairns, 'Straya
    43
    http://www.torquestats.com/modified/...bmit=Calculate
    According to that, which seems to be within acceptable errors for a Falcon (210hp, 1700kg, rwd, generates a 17.3 sec 1/4 mile,) you'll need around 210hp at the flywheel. So if we're talking metric wheel-killer wasps, about 110 of them
  27. #147
    Mar 2013
    Cairns, 'Straya
    43
    That seems suspiciously low, but the intercooler is fairly big and even with zero airflow a core that big and heavy can store an awful lot of heat before the cold side gets hot. Given the moderate boost level that could take a long time at WOT. Let me know if it heats up going up long hills or something.
  28. #148
    Sydney rAmR0d'
    4,048
    I don't think there is a hill anywhere that I can get on it for long enough without exceeding the speed limit enough to lose my licence.
    I think it can do more than 110kw at the wheels easily.
  29. #149
    Mar 2013
    Cairns, 'Straya
    43
    Well, you've effectively build a lower boost, smaller, Astra turbo motor.
    http://www.torquestats.com/index.php?car_id=605
    2003 Astra turbo. 147kw, 1250kg. 15.17 @ 93mph
    Astra turbo runs 12-13psi on a 2L engine, so unless your car holds on to its torque really well high in the rev range, you will have less power, but you weigh 400kg less.
    T28 is apparently good for 250-260 odd hp at 15psi, so you shouldn't run out of turbo before you run out of conrod or cams
  30. #150
    Sydney rAmR0d'
    4,048
    It's higher compression than the Astra Z20LET though. This runs 10.5:1 and the Astra is 8.8:1.
    Probably helps with eliminating turbo lag and more low rpm power, but i'm going to be limited with how much boost I can run.
