Page 5 of 5 FirstFirst 12345
Results 121 to 127 of 127
Thread: IPRA S15 Build
  1. #121
    Perth from 23rd Jan 2009
    1,706
    Yeah cool, well that does give me a direction for the master cylinder sizing. Cheers mate.
    Go Hard..........or Go Home!
    VW Amarok - Daily
    2014 Jeep Grand Cherokee (Limited) - Nopics
    2001 S15 - IPRA Build
    VE SS Redline Ute - SOLD
  2. #122
    Apr 2003
    Roleystone
    3,339
    7/8, Call Brent Mathews at Perth brake parts
    GURU ENGINEERING PTY LTD
  3. #123
    1,706
    Hey Steve, will the stock pedal work with dual masters? In other words, does running dual masters require more pedal effort than running the tandem master?
    I have this balance bar set-up in the garage, haven't made the bracket yet as I was concerned the pedal would be too hard with the stock pedal ratio? What are your thoughts?
Name:	Dual Master Set-up.jpg
    VW Amarok - Daily
  4. #124
    Apr 2003
    Roleystone
    3,339
    That will work fine, Used that setup on an R32 GTR a few years ago with no problem.
  5. #125
    1,706
    Thanks Steve, that's good to know. Will give it a try and see how we go.
    VW Amarok - Daily
  6. #126
    1,706
    Made some good progress last weekend. Got the last of the braided lines fitted up to the braking system, filled it with fluid and bled the system. No leaks and a good pedal, just need some wheels now to take it for a drive and road test!
    Running the stock booster for the time being, but will start planning the twin master cylinder set-up pictured above, as I already have the balance bar set-up.
    VW Amarok - Daily
  7. #127
    1,706
    Six months between updates isn't too long....particularly at the rate I am going! (snails pace)
    Made a decision recently to change the plan for the build. Improved production is no longer the destination. Instead, I'll be running in "Street Cars" here in WA. Main reasons for this.
    1. Run the car lighter (about 100kg lighter than IP spec)
    2. More Powah's - no restrictor, so planning a Stroked VE headed SR with around 500-520rwhp
    3. Sequential Box
    4. Adjustable suspension arms are allowed
    5. Lightweight body panels & glass replacement allowed
    6. More Aero allowed
    Should be a faster car for similar money...... and the Street car guys I've met seem like a great bunch of guys. Should be fun.
    Now I just need to find some time (and more money) to keep things rolling!
    VW Amarok - Daily
