Page 4 of 4 FirstFirst 1234
Results 91 to 105 of 105
Thread: 'Tourqe Lock' borg warner centres
  1. #91
    1,883
  2. #92
    caibstastic!!1 caibs's Avatar
    perth
    288
    fair thread dig, any updates on reliability of these torque lock rigs and gearsets that theyre sold with?
    some fucken busted ass peice of shit
  3. #93
    One street away from Guido's den of sin
    24,348
    Mine hasn't broken yet. Only had a single run at the drags (as the car conked out half way) but did 11.1 @ 122. Other than that done a couple of thousand street km's - zero issues.
    Edit - no idea on gearsets.
  4. #94
    perth
    288
    sweet thanks mate. may as well give it a nudge
  5. #95
    24,348
    Still haven't broken it. Handful of 10 sec passes all leaving the line at 1.7 60ft. Launches and tracks straight every time.
    I'm more worried about axles now than diff.
  6. #96
    perth
    288
    mine went in this week. looking forward to taking it down thw strip as soon as im home on a wednesday.
    bit of drama getting the gearset fitted, diff shop reckons the r31 housing requires m75 gears and the dana m78 gears wouldnt fit in my housing. tuff car parts reckons you can make it work by machining the pinion and grinding housing.
    diff shop ground housing, pinion fit without being machined but there was a poor meshing pattern and it just wouldnt allow enough adjustment/shimming to make it work nicely. so ended up going with a genuine set of 3.9s.
  7. #97
    are hairy Dogsballs's Avatar
    7,922
    Quote Originally Posted by caibs View Post
    I had a big argument with them as a couple places said you would have to machine the gears (even 3.08) and its a cunt to get spot on. Tuffcarparts say nah nah fit in without mods, poor diff guy spent a few hours making it fit and now has a whine at decel. Not happy jan
  8. #98
    perth
    288
    yeah i wont deal with them again. after i said the diff shop fitted them and they wont work regardless of machining the pinion head (nothing had been machined, modified or used other than dummy fit), he said well theyre second hand now and we dont deal in second hand parts.
    fair shout, thats their right as a business to make that call.
  9. #99
    Pull my finger StupidFlanders's Avatar
    1,501
    I've been using a Drivetech mechanical LSD in my VS BW75. Went in with 3.7 genuine Spicer gears with no mods or machining needed.
    It's done a few clutch kicks on the street and 5 launches at the drags with no fuss, works really well. No noises. Price was around the same as the Torquelock.
    The diff shop did say Drivetech had stopped selling them for VE because of bolts coming loose and grenading diffs, something he has witnessed. No problems with the BW model.
  10. #100
    24,348
    Quote Originally Posted by psi999 View Post
    1.5 60ft now with mid 10s 1/4. Safe to say these things are pretty strong. You'd laugh if it ended up being stronger than the Eaton/Harrop things it was knocked off from.
  11. #101
    Registered User ls400x's Avatar
    Aug 2008
    QLD
    2,232
    Torque worm reviews? $495 delivered for a BW/Dana M86
    https://www.ebay.com.au/itm/Borg-War...75.c1#viTabs_0
  12. #102
    Registered User GreatWallGT500's Avatar
    Dec 2012
    860
    haven't read anything as yet. is it just me or does the quality look a bit average? personally id pay the extra and grab the torquelock.
  13. #103
    Aug 2008
    QLD
    2,232
    I might buy one and pull it apart
  14. #104
    Inner Westside/Sydney
    1,362
    I don't suppose one of you clever cunts could add an e-locker type mechanism on to one of these helical lsds? They are much nicer on the street 95% of the time than a detroit but not much point in the bush unless you left the handbrake on a few clicks.
    I'd have a go on that ebay one.
  15. #105
    1,883
    Quote Originally Posted by Slides View Post
    Most of them have a pre-load pack so no handbrake required
