Page 5 of 16 FirstFirst 12345678915 ... LastLast
Results 121 to 150 of 451
Thread: Not another fucking MX-5, what is this faggotry?
  1. #121
    Sep 2005
    787
    I've tried most pads at some point and used Hawk Blues for a long time. However, once I changed to Carbotech's, I never looked back. My race car is road registered, so I need something that can handle a very broad heat range. I run XP12's on the front and XP10's on the rear and find them to stop as well or better, last longer, chew rotors less and far less dusty than the Hawks.
    PS put some Castrol SRF in it and you'll never change the fluid again.
    Thanks for the suggestion. I looked at a few options and was recommended Hawk blues by others as well so ended up with some of them. I'll be interested to see how they go and how street friendly they are - on my rx3 I find them ok but squealy unless regularly tracked or when hot. I'll keep the carbotech's in mind for the next set.
  2. #122
    Moderator Cal's Avatar
    Nov 2002
    Brisbane, Queensland
    22,275
    Carbotech's also squeal when cold.
  3. #123
    CNGAF rowdytoot's Avatar
    hotel vast horizon
    10,073
    My Cusco diff centre will be at my place today. $1212 AUD landed- shipped via TNT air freight Ordered and shipped through Jesse Streeter. Now to find someone to install it.
  4. #124
    Canberra Nth
    3,103
    Oohhh!!
    Another trip to Wakefield soon then
    - PSN: rotacoupe
  5. #125
    hotel vast horizon
    10,073
    Yeah just need to get it installed by someone....
  6. #126
    Canberra Nth
    3,103
    M & A in Mitchell? They seem to do ok work?
    - PSN: rotacoupe
  7. #127
    hotel vast horizon
    10,073
    Yeah they seem to be the ones. Of course th nopics wasn't home yesterday so I have to go grab this from Hume
  8. #128
    hotel vast horizon
    10,073
    Mmm finally got around to uploading this picture.
    At some point to Jim is going to give me a hand to install the centre, since he has the skills to set bearing clearances etc.
    Still enjoying the car a lot, brakes need a bleed and the drivers door is starting to rattle again- need to adjust the delrin door bush. Diff bushes need doing as well, starting to get axle tramp off the line
  9. #129
    syd
    2,783
    get braided lines if you dont already
  10. #130
    hotel vast horizon
    10,073
    Already do
  11. #131
    hotel vast horizon
    10,073
    Decided to pull the front wheels off for a look see this afternoon....
    Time to install new slots.. ..... Interdastingly their was plenty of meat on them when I went to Wakefield and I've done about 400 km since then admittedly quite a bit of that was brisk hills work...
  12. #132
    Bentleigh Victoria
    3,559
    I am not using my front brakes any more. $1000 delivered. The rotors will need to be replaced soon. But they are very cheap at $50ea. I have only done about 3 hours on these (calipers and rotors) from new.
    free screenshot software
  13. #133
    hotel vast horizon
    10,073
    So new brake discs installed, and bedded in
    Decided to do a quick brake bled tonight and fit the semi slicks to go to the Wakefield next week.
    I checked over the tyres and noticed this on 3 of the 4 tyres
    They are FZ 201 and have about 350 track km on them
    Hrmmm not confident that they will last......the photos 'flatten' the splits quite a bit. They are deeper than they look. Probably a couple of mm.
  14. #134
    Former hairdresser Captain_Slow's Avatar
    9,357
    I still need to see this car!
  15. #135
    hotel vast horizon
    10,073
    Quote Originally Posted by Captain_Slow View Post
    You so do. I think Jim is the only pf er to have seen it aside from uncle
    Wheel alignment tomorrow and the trackday on Wednesday...
  16. #136
    hotel vast horizon
    10,073
    Wheels got aligned thanks to the. Top cunts at Capital steering and suspension.
    Zero toe, 1.5 degrees neg camber , 4 and a bit degree caster on the front
    1 mm toe in 1.5 degrees neg camber on the rear
    Turns in much better now from the quick blat up coppins crossing on the way home . Hopefully will make a difference on Wednesday.
  17. #137
    BIG MEK buzz's Avatar
    Nations Capital
    3,775
    Me too.
    Take care and have fun on Wednesday.
  18. #138
    hotel vast horizon
    10,073
    Yeah we need to go for a weekend cruise mx5s and the 86..
  19. #139
    5,442
    Is 1.5deg generally what mx5s like with semis? Seems pretty low
    Daily: Honda Civic EK1 Hatch
  20. #140
    hotel vast horizon
    10,073
    It's all I can get without losing a stack of caster. I have extended balljoints to go in as the next mod so 3 degrees will be easy.
  21. #141
    5,442
    Ahhk. Im using NA uprights in our spaceframe car, so when I read the 1.5deg I was a touch confused.
  22. #142
    Nations Capital
    3,775
    Well?
  23. #143
    Peoples Champ Fatboy's Avatar
    11,479
    It's now only 2.4 secs slower than my stock 2.0 N14 Pulsar now... Sorry Rowds !
  24. #144
    hotel vast horizon
    10,073
    Ha ha. yeah the Chisholm version of 'stock' stripped, caged, suspension, mega negative camber, new semi slicks etc... I can drive mine for hours at a time on the road comfortably while listening to tunes... When was the last time you did that in your poosar?
    Was faster than an r34 GTR (although I also overtook the same r34 on the highway uphill with the car on the trailer on the way home! ) , turbo astra, a bunch of 86s, a VW golf turbo thingo and an s2000 with a stupid wing etc. There was a copy a harrop supercharged VF SS too... It sounded tits and had big flames on the overrun...
    I made friends with an dude my ages in an 86 running 12s and had a great laugh all day,especially in the wet sessions. Only spun once,trying to hold it on the lock stops and out braked myself into turn 10 once.
    Some chinese dude destroyed the engine in his gen2 crx by just ignoring the temperature gauge and running it to the limiter everything shift and then wondered why it'd dumped all the coolant out...
    There was an n15 poosar that was built for the was race series 1st time out and neither of the dudes driving could steer or use their mirrors. Was fucking scary to get past.
    New wheel alignment worked well - much more responsive on turn in , although from a quick and dirty IR temperature check, the outside edges of the fronts are still hotter than the middle or inside, so the extended lower balljoints will have to go on plus a new wheel alignment and go to perhaps 2.2 degrees with more caster.
    By the end of the 2nd session the LF wheel bearing was rather noisy, so I sat out the 3rd session, checked it for play and waited for the rain.... The car hit 150000 km sideways out of turn 2...which was funny as..
    The FZ 201s now have close to 200 laps on them and are heat cycled to fuck, a few mx5 dudes who have run FZ 201 s reckon even a hankook RS3 is ~ two seconds per lap faster.. ... So need new semis - probably look to get hankooks or NT-01 and the the new diff in too
    The other annoyance at the moment is the front bar - I caught it on the trailer lip and have cracked the lower edge, so now it catches on everything- it needs a respray anyway, so might loom at going to a nb8b front end..
  25. #145
    Nations Capital
    3,775
    ...so 1:13 it was?
  26. #146
    hotel vast horizon
    10,073
    Yup again.. Racechrono fucked out in the session I set that time, but looks at sector times it should run a 12 comfortably if I manage to string together a clean lap without hitting traffic... ( straight from the book of excuses!)
  27. #147
    hotel vast horizon
    10,073
    Spent 25 minutes bolting the street wheels back on and drove to the shops,roof down, tunes playing..
    Front LH wheel bearing is noisy even in a straight line but still no real play when tested odd..
    New wheel bearings will be here on Monday.....
  28. #148
    hotel vast horizon
    10,073
    Pulled the hubs this arvo... Definitely shagged. Grease fried, not much play yet but happy new ones will arrive tomorrow.
    Will do the new balljoints too
  29. #149
    hotel vast horizon
    10,073
    Finally got around to editing the in car..
    This is the 'best' dry session of the day
    https://youtu.be/r3c50wAWIHA
    This is shits and giggles in the semi wet...
    https://youtu.be/4eI9QY_TsS0
    Running about 1.23s...
  30. #150
    11,479
    You realise one of the boys here has his APRA Pulsar still street registered and drives it to and from Wakefield from Sydney right ?
    And i'm just winding you up about laptimes... 11.5 is the number to beat...
