Results 31 to 60 of 95
Thread: Supercharging - The basics?
    5,293
    Quote Originally Posted by hiddeous View Post
    Yeah have watched that, sounds like a little bee!
    No, that's asians
    A80 Supra
    80 Landcruiser
    Aug 2013
    gawler
    1,809
    Ah, OK. Right, the Blitz kit had a different FPR so that is going to be the first thing you require, Echo's run higher fuel pressure than most vehicles, around 53 psi instead of the more usual 43 psi. As already noted the FPR is in the fuel tank.
    As pointed out by an earlier poster, the 5.8 psi of boost is about correct for a supercharger suited to a 1.3 fitted to a 1.5.
    Getting the supercharger pulley machined smaller would increase it's revs and produce more boost.
    I've, just last week, modified some BA falcon injectors, fitted a Magna fuel pump and 98-2000 Evo Lancer rising rate FPR to my Open Wheeler Toy with the intention of going to E85 and Turbo on my 1NZ-FE....
    Aug 2013
    gawler
    1,809
    Oh, forgot, the 1NZ has a knock sensor so that is likely pulling timing and costing HP, especially if it is running lean due to having a fuel "black Box" for a 2NZ.
    If you can find out what fuel pressure the Blit FPR should be you may be able to crush (compress the spring) in a std. one to gain that pressure Then you'll need to tune for the extra capacity.
    Failing all of that ... sell it to me !
    5,293
    Hey Roy, shit thats awesome info man! Yeah, this FPR thing, I think i need. Now I need to find this FPR....and get a new pulley!
    No, that's asians
    A80 Supra
    80 Landcruiser
    5,293
    dude, I tried for a year to sell the engine/box/sc kit for $1500, no bites, so i said fuck it, I put it on my own car lol.
    But thanks again for this info!
    No, that's asians
    A80 Supra
    80 Landcruiser
    12,566
    I'd be nervous about a dyno guy who keeps his foot into a boosted car that is super lean at 100 kays under full load. That's a big risk with an unknown engine man. The power output should have told him how unhappy it was.
    Not busting balls but that's sketchy as.
    5,293
    Quote Originally Posted by Bigmuz View Post
    You're not wrong man
    Will hit him up about that. Its like he just wanted to get the car out.
    Back to the little nugget..got the emanage and loom..now he told me to order the map sensor...fml. so thats on its way.
    I want to try and add more boost. No idea where to start
    ACT 2607
    1,838
    pulley sizes is where you start.
    canberra
    3,649
    Have you got a pic of the intake? Could be a very cheap psi or two lurking there
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
    Melbourne, S.E. suburbs
    1,460
    Not familiar with Toyota Echo tuning, but 70kw at the wheels sounds pretty healthy for a 1.3 litre with a mostly standard exhaust and 6psi in it from an ancient roots 'charger with no intercooler.
    It is well lean through peak torque, but being such a small bore, if its running 98 it might not be hurting itself. There's still power to be had though. Install the emanage, do a full exhaust system and it should see some decent gains. Still be lucky to see 100kw I reckon.
    Aug 2013
    gawler
    1,809
    Factory rated at 63kw presume that is @ F/wheel, + 6 psi = 87-18%driveline loss= 72kw @ wheels, yep it is there or there abouts.
    I reckon there isn't much to be gained by a cooler at these boost pressures, but if you go to a smaller pulley and more boost it will reap reward.
    1,460
    Agreed. As it sits, exhaust and management will sort it good.
    5,293
    Thanks guys, mines actually the 1.5
    Ive got all the parts now to complete this, the 5 Zigen Headers, frind will custom the exhaust to the axel back. Ive got the Celica 2ZZGE injectors, and Corolla 1zzfe throttle body. Ive got the e-manage ultimate, and universal harness now, and a 3bar map sensor.
    Mechanic wants $1500 to wire up the Emanage and tune..i think its a bit steep to be honest!
    No, that's asians
    A80 Supra
    80 Landcruiser
    9,031
    You need the tune which is broad....
    Registered tax offender SuperDave's Avatar
    Apr 2010
    West Philly
    2,751
    Probably not much help, but if you have the brown injectors they are around 350cc/min, the yellows which are more common are 330cc/min. Whether that helps with tuning or not...
    My car
    Corolla
    I'd have no qualm about punting a kid into the fresh produce section if it meant the difference between getting a set of night vision goggles or not.
    Sep 2007
    5,362
    Should be a blast when it's running right, a 2-door Echo with this setup or the 2L 3zr-fe would be hilarious!
    3x1UZ+1x2UR...
    5,293
    Quote Originally Posted by SuperDave View Post
    Thanks Superdave, they are in fact Yellow. I didnt know this, thanks!
    Quote Originally Posted by perthdrivers.txt View Post
    Yeah man, cant wait to take it to the track! Its a 5 door BTW., still about 990kg.
    No, that's asians
    A80 Supra
    80 Landcruiser
    5,293
    So the "beast" is now tuned! A massive 80fwkw on 5psi. I want more..clutch doesn't so ive ordered an exedy heavy duty. Does anyone know how or who can get a crank pulley made for more boost?? I want at least 7 to 10
    4,272
    Will the blower do it and how hot is the air going to be?
    5,293
    I have no idea lol
    No, that's asians
    A80 Supra
    80 Landcruiser
    Aug 2013
    gawler
    1,809
    Thanks for the heads up, I'm heading down the turbo E85 path and was wondering what the clutch was going to do...FRY !
    Just another thing to sort out, will probably just double up on the diaphragm spring.....
    5,293
    Hey guys, reporting back after the:
    5Zigen Header install
    High Flow Cat
    E-Manage Ultimate
    Made a little bit more power...but its very laggy...like ive got a T51r Turbo lol..once it hits around 3.5k, it goes awesome!! Im putting it down to the tune..
    No, that's asians
    A80 Supra
    80 Landcruiser
    canberra
    3,649
    Must have a leak somewhere? Roots SC can't be laggy? You should be able to easily see full boost free revving....there's a problem there somewhere
    GT8
    1UZ Celica
    12,566
    Afrs are embarrassing, is the emanage unable to control mixtures?
    3,196
    Quote Originally Posted by Grand Mufti Murray View Post
    Strange isn't it, looks like it tips in fuel then waits tips bit in then waits. Would be interesting to see the tables in the tune.
    5,293
    He didn't install the injector for me..said it dodnt need them.
    Even with the supercharger off..below 3.5 it doesnt move...like as in this morning had it in second and it wouldn't go past 30km...
    Might have to take it somewhere else for a 2nd opinion
    12,566
    Sounds like a plan.
    That is so fucking rich up top it's not funny and the big hole down low is cause it is lean unless there's something else going on. I would never let a customer see that graph.
    5,293
    Apparently its a battle against the stock ECU causing these issues...AFR seem to be super safe?
    No, that's asians
    A80 Supra
    80 Landcruiser
    Sep 2007
    5,362
    Welcome to previous gen Toyota factory tuning
    sub 11 AFRs at WOT thx
    3x1UZ+1x2UR...
    12,566
    Really? Jesus. What's the emanage for then?
