Results 61 to 90 of 95
Thread: Supercharging - The basics?
    5,310
    Thats what I thought!!! My friend Adam (JEM) said he will put a standalone Haltech on for me...I said no way not for a station car!
    No, that's asians
    A80 Supra
    80 Landcruiser
    3,558
    yet problems like this are exactly why you should put a standalone on it. as per page 1
    Also it is running pretty damn lean in the low-medium rev range. Get a smaller sc pulley, put a better intercooler on it (does it even have an intercooler??) and do whatever you can to free up the intake and exhaust, and get a proper tune on the cunt
    edit; the way the boost ramps on is fairly slow. does this thing have a bypass valve or something? does the engine run VVT? look at the MAP versus speed. a supercharger should click on and give you maximum boost very early on, yours seems to come on slowly. could also be a boost leak as justen suggested i guess, although i would pin it on the blitz kit running a bypass valve which bleeds the boost on slowly to stop the stock engine from grenading
    1988 AW11 9A-GTE - project #1 | 1980 KP60 4K - project #2 | 1994 UZZ31 Soarer 1UZ-FZE - Cruise missile
    5,310
    Yep, it acts exactly like a Turbo man, it ramps up and by 3.5k feels awesome.
    Man how the fck I check a leak on this thing?? And yes it has VVTi
    No intercooler on them. Here is the Dyno graphs for both Blitz and Trust kits on the same car
    No, that's asians
    A80 Supra
    80 Landcruiser
    5,310
    Also, kit came with this Top Fuel Zero 1000 intake, thinking no point to put on to suck in hot air?
    No, that's asians
    A80 Supra
    80 Landcruiser
    3,558
    check around gaskets and joiners for oily residue?
    that blitz dyno plot is suss as, what the fuck is going on at 2k lol! knock sensor must have gone into overdrive. again makes me think there is something going on down low to limit the boost. do you have more pictures of the whole setup in your engine bay?
    5,310
    haha and yeah making 80kw stock...Suss as!!!! Ill get some more pics tonight, will be bringing it to toyfest haha
    No, that's asians
    A80 Supra
    80 Landcruiser
    3,558
    haha sick. hoping to get the adub there too but unlikely, just not enough weeks left for tune and stuff
    the power figures on the blitz dyno plot are likely flywheel figures also, hence the higher numbers
    5,310
    Oh yeah good point! Would be good to see your adub!!
    Hereis a pic if it helps?
    No, that's asians
    A80 Supra
    80 Landcruiser
    1,877
    that looks a lot like a 1G-GZE SC14 with a custom drive snout to me!
    3,558
    it wont be an sc14 unless it is massively underdriven. more likely an sc12 or even a smaller ogura unit
    1,877
    looks like a damn large pulley so my bet is under driven trying to not be a hairdryer
    12,588
    Get a smaller pulley. Is it a clutch pulley?
    9,036
    I know nothing about superchargers, but is that belt too small? Is it slipping?
    5,310
    Its a clutch pulley.
    Belt is the one that comes with kit.
    Someone mentioned that E-Manage Ultimate doesnt control VVTi, so think the tuner just tuned for when VVTi cuts in at 3.5k rpm
    No, that's asians
    A80 Supra
    80 Landcruiser
    1,877
    If it's a SC14 It's really old tech, two lobe rotors etc.. it will make boost just don't expect the world... you can measure the crank pulley and the blower pulley that will tell you the drive ratio is, maximum you're looking for is spinning the blower to about 10,000 rpm.
    Some water injection pre blower will help.
    3,558
    if the belt were slipping you would see it on the boost plot. normally the slip gets worse with revs so the pressure should go erratic as the revs go up. dont think its slip.
    canberra
    3,651
    Bypass valve sticking? Something is causing the slow boost build...it should be literally instant full boost with full throttle from anywhere 1000rpm and upwards
    GT8
    1UZ Celica
    1.07 flat Wakefield Park
    5,310
    Yeah, but even with the supercharger off, down low is shit. Esecially when its cold...like this morning, 2nd gear, would not go past 22km/h
    No, that's asians
    A80 Supra
    80 Landcruiser
    1,877
    get an ECU on it with data logging other wise its all a crap shoot
    Mar 2009
    Bendigo, Vic
    1,704
    For the love of god get a stand alone ECU! Wasting money on half ass shit.
    Mmmmmmmmm beer.
    5,310
    lol, a standalone will cost more than the cars worth. The kit doesnt even come with a standalone, it comes with an air/fuel contoller box which is pre configured.
    No, that's asians
    A80 Supra
    80 Landcruiser
    3,558
    might have to accept the way it drives then dude
    i couldnt see a bypass valve in the pics you posted, but i presume there is one. as per my earlier post i would be poking around there and seeing what controls it/whether it is working properly. really it is just a guess tho
    Registered User Marty!'s Avatar
    Sydney, Aus
    995
    man please put an ECU on it... my mates turbo setup with an e-manage just never worked properly, ever.. it's always fighting the stock ECU and runs like turd
    put a haltech on it, tuned it in about 15 mins flat and car is a completely different beast, works perfectly, makes power safely, and yes its a shitty hatch back thing just like yours.. doo ittttt
    5,532
    If its just a shitty station car you should have left it stock.... It's a project car now and as such there should be no issue with spending more than the cars value to get it running right 😉
    Just stick the most basic haltech on it, will shit on some piggyback abortion.
    Sent from my Lenovo TB3-710I using Tapatalk
    Daily: Honda Civic EK1 Hatch
    Mar 2009
    Bendigo, Vic
    1,704
    This^^^
    Mmmmmmmmm beer.
    12,588
    Realistically you've already spent a fortune on useless dyno tuning, suck it up and do it right. Megasquirt could do it at a pinch.
    5,310
    haha Fck you bastards! I will look into this later. I will just enjoy it as it is. Its still heaps better than stock at least.
    No, that's asians
    A80 Supra
    80 Landcruiser
    Aug 2013
    gawler
    1,867
    That is the right answer. You have the low hanging fruit, take that and be happy.
    I'm no further on with mine, but intend running it via a Microsquirt...
    5,310
    Update, a year later and the car runs flawlessly, fuel economy isnt any worse than factory, have had some good little digs here and there aswell as a couple of wakefield Days. Gets driven everyday by the no pics
    I think I want more power, Im thinking of getting a larger (?) crank pulley, to increase boost seeing there is nothing off the shelf to change the supercharger pulley. Does anyone know about these light weught crank pulleys, weather they can limit the life of the engine?
    http://www.worksengineering.co/produ...oyota-vios-1-5
    No, that's asians
    A80 Supra
    80 Landcruiser
    Aug 2013
    gawler
    1,867
    Nah! She'll be right, you wouldn't worry about a lightened flywheel...
