Page 2 of 6 FirstFirst 123456 LastLast
Results 31 to 60 of 170
Thread: Blue haze
    4,933
    CBR250RR has dual lines stock too, no issues.
    www.markpakula.com
    Feb 2012
    Brisneyland Aus
    166
    Quote Originally Posted by Slain View Post
    No problem changing it to a dual banjo and line as long as the braided lines are marked as ADR approved. I use HEL lines for this reason.
    Good to see another smoker around, I'm currently rebuilding a KR1 which my neighbours hate.
    Before I pulled it apart I also used to treat my neighbors to the aural and nasal pleasure of two stroke. Should be more of it.
    Feb 2012
    Brisneyland Aus
    166
    While engine is out it is a good opportunity to de-grease the engine and frame. After uncovering 20 years of oil and grime it appears the lower shock mount is not cracked which is common for this model.
    De-greasing the engine prior to removing cylinders would have been a better idea. My solution was to hang the engine upside down to avoid getting any unwanted grime and degreaser in the crank case.
    Output shaft seems to be in fair condition also as its another common ailment for this model.
ID:	99805   Click image for larger version.
    Registered User 51ave's Avatar
    Sep 2016
    ACT
    84
    Looks awesome mate! Inspiring me to look into getting something cheap to have a play with/learn from that won't matter if I butcher
    Feb 2012
    Brisneyland Aus
    166
    Have been cleaning the frame...... lots.
    Went through about 12 cans of degreaser on engine and frame. First pic of webbing inside frame was black prior to cleaning.
    I new that the choke guides were prone to breaking on these so in my bc engineering order was their billet choke guides. Sure enough on close inpection one was broken.
    Fairly easy to change, just unscrew from carb body remove plunger and thread off old plastic guide and place new one on.
    Small steps at the moment waiting on cylinders but I like doing these small detail jobs.
ID:	100106   Click image for larger version.
ID:	100107   Click image for larger version.
ID:	100108   Click image for larger version.
ID:	100109   Click image for larger version.
    16,340
    BC are good guys. Next time I break one of those fucking choke things, I'll get a set from BC.
    Feb 2012
    Brisneyland Aus
    166
    As I intend to run 1.4mm base gaskets compared to the standard 0.5mm gaskets, a few things need to change and one of them is the deck height of the cylinder heads.
    The two options are to run the standard heads sans head gasket and have a groove machined to take an oring (tz).
    The other far more sexy option is to go aftermarket. The benefits aparantly are centering the plugs, better ports for cooling, replaceable inserts and no gaskets just orings, blah blah blah I like them cause they are shiny.
    The pics show the heads with standard inserts.
    Below these are custom inserts with neg deck height to hopefully maintain about 0.9 squish and 12.00cc volume.
    In the closeup of the inserts, you may be able to se the positive height / recess of the standard and the negative height /proud machining.
    VHM make blanks so you can order those yourself or just send your specs and they will cut the blanks for you.
    The standard cylinders on the right have had the uuheels treatment pre photos are further up they look better than new.
ID:	100198   Click image for larger version.
    Feb 2012
    Brisneyland Aus
    166
    Pipes and fairings have also arrived. Its a travesty the pipes will be mostly covered.
    Nov 2016
    382
    Definitely a travesty. Pipes look beautiful. Also had an RGV a couple of decades ago, lol. Was a 92 model N. Was pretty sweet. They're definitely a rare sight these days.
    16,340
    Quote Originally Posted by MVLUV View Post
    Can you take some pics of the heads without the inserts installed? I'm contemplating making a set of heads for my VJ23 motor to take VHM RM125 inserts...
    Feb 2012
    Brisneyland Aus
    166
    Let me know if you want to take some measurements, I won't be screwing them on for another 3 or 4 weeks.
    16,340
    That would be most excellent! I'll shoot you a PM
    Apr 2008
    Sadstone
    1,331
    Fuck Tyga do some sexy pipes!
    Feb 2012
    Brisneyland Aus
    166
    16,340
    Champion!
    Feb 2012
    Brisneyland Aus
    166
    Forks done, heavier springs, custom valving with rebound on one leg and compression on the other. Non stiction oil and new seals.
    Lower legs vapour blasted as you can see in the first pic was pretty grubby.
ID:	100322   Click image for larger version.
    Temporary Australian Rorz de Puniet's Avatar
    3,454
    This is coming together real nice.
    Randy De Puniet has had more crashes than any other rider in the history of Grand Prix motorcycle racing.
    Feb 2012
    Brisneyland Aus
    166
    Started assembly of the cylinder heads and installing vertex pistons. As with the standard pistons they have a pin in the ring groove so the gaps stay clocked in a certain position. Which after looking is away from the exhaust port.
    BC engineering gear is great except for the pv collars, the 4mm holes look like they are drilled slightly off centre so the pin that joins through both pv's and collars won't go through. Took one side of each collar out to 4.5mm and fits well with no play.
ID:	100729   Click image for larger version.
ID:	100728   Click image for larger version.
    Feb 2012
    Brisneyland Aus
    166
    Here is a good comparison shot of standard power valve and BC engineering one. You can see the roll pins in the standard one on the right. This is the achilles heel of the vj22.
    The internets state they went through 3 generations. The first had a small pin about 4mm I think. The second had a slightly larger pin, then finally this design which is two pins.
    They are all still prone to bending or shearing and putting debris or the power valve blade into the chamber.
    The second pic shows how the hole has become elongated over the years and approx 38k assuming these are the original items.
ID:	100752   Click image for larger version.
    4,933
    How much did the fork job cost?
    www.markpakula.com
    Feb 2012
    Brisneyland Aus
    166
    Quote Originally Posted by trent from punchy View Post
    $500
    Feb 2012
    Brisneyland Aus
    166
    Wheels and swingarm done.
ID:	100756   Click image for larger version.
ID:	100757   Click image for larger version.
    Feb 2012
    Brisneyland Aus
    166
    Installing the swingarm is by screwing in a hollow pivot bolt until it makes contact with the dust seals that sit outside the swingarm needle roller bearings. Then torque the pivot shaft to 85 - 115 nm. After that torque up the pivot nut to 70nm.
    30mm pivot nut tool is about $50 plus postage so made this up out of a washer and a socket adapter I have never used.
ID:	100828   Click image for larger version.
    16,340
    Yup. You're totally going to finish this before I finish the Mito.
    Feb 2012
    Brisneyland Aus
    166
    Maybe. ....how about a build thread?
    Feb 2012
    Brisneyland Aus
    166
    Engine screwed together and getting another batch of stuff together to be powder coated. All the shiny stuff makes the rest look ordinary now.
    16,340
    I have suffered a crippling bout of CBF and can't be fucked sorting a new image host, so all my build threads are dead. I also cbf'd replicating the Mito's thread here. it exists on another forum or two, but the images are broken.
    As an example, I had the engine out of the bike yesterday, to discover the carb clearance issue I thought I had isn't actually an issue. sigh.
    Feb 2012
    Brisneyland Aus
    166
    Chin up and all...
    Its threads like your alfa rebuild that make me think anything is possible in the backyard.
    So as stuff gets cleaned/ painted/ replaced with aftermarket hotness what is left tends to look worse than what it originally did. Among other things I wanted to remove the top triple clamp for a coat of satin black. Turns out the ignition assembly is screwed from under, then the bolt heads are twisted off for better security .(This information was supplied by a rgv forum member as I was stumped as to what they were.)
    So I centre punched and drilled a 2mm pilot hole then a 8mm got the rest of the bolt head.
    When I reassemble I'll just use cap screws or bolts as it will only do hard parking and no carpark duties.
ID:	100881   Click image for larger version.
ID:	100882   Click image for larger version.
ID:	100883   Click image for larger version.
ID:	100884   Click image for larger version.
    Feb 2012
    Brisneyland Aus
    166
    Ever since I did my squish measurements I have been concerned. I was aiming for 0.9mm after installing 1.4mm base gaskets and ordering inserts to suit.
    Accross both cylinders I have 1.25 to 1.3mm consistently after doing 4 measurements on each cylinder.
    I am not chasing 70hp but I don't want to give away any power when I can just change to 1mm base gaskets and land in the 0.8 - 0.9mm range.
    Any comment or opinions welcome as to what the potential gains are reducing the squish to the above numbers. Cheers
    Feb 2006
    4,882
    I presume you are using the solder method? Use a thinner solder and I bet you get a different result.
    Read through this carefully
    http://twostrokeperformance.com.au/m...ish-clearance/
