Page 14 of 16 FirstFirst ... 410111213141516 LastLast
Results 391 to 420 of 465
Thread: VN Group A Race Car (round 2 of the V8's)
  1. #391
    Bentleigh Victoria
    3,423
    I would like to spend money on brakes once. So if I can afford it, get something that will work. The car does need brake ducts for sure. The heat coming off the front wheels was amazing.
    I am also thinking I should just keep the car set up for VicV8's and not worry about IPRA. I will start again with a Jap car for IPRA.
  2. #392
    Ballarat, Victoria
    359
    How was the wing?
  3. #393
    Bentleigh Victoria
    3,423
    It is mounted too low, and too far forward to do a lot, especially on such a low speed track. It felt planted around the sweeper, but the slower corners didn't feel like it was doing much. It's set at zero degrees as well. Can't wait to stick it in the air stream. I might just get my MX5 on the track without its rollcage and do a proper test. There is a bunch of data online for this wing showing it to excel with high downforce and low drag. It also makes a good bench to sit the 25l Jerry can on when refuelling via a rattler siphon hose.
  4. #394
    Ballarat, Victoria
    359
    Build me one for my FD and I will test it for you
  5. #395
    Bentleigh Victoria
    3,423
    Will do. I called last week asking if the alloy bits had been cut. Yep, come pic them up they said. I get there, some are cut, but not other bits. Why does it have to be so hard???
    What width are you after?
  6. #396
    Ballarat, Victoria
    359
    1800mm? Can you do that wide?
  7. #397
    Bentleigh Victoria
    3,423
    Yep. Can go about 1950.
    I accidentally uploaded the full race (shortened). This was supposed to be just one lap showing how easy I lost the rear end. We will work on setting it up one day. This was Race 1, I was still working out what gear to use, and I was not in a rhythm yet.
  8. #398
    Bentleigh Victoria
    3,423
    The start of Race 2. Not good for Adam and Vic.
  9. #399
    Bentleigh Victoria
    3,423
    Race 3 or 4, can't remember.
  10. #400
    Bentleigh Victoria
    3,423
    I think I need at least 50kw's more to even keep close down the straights.
  11. #401
    7,540
    Shave heads, cam and e85
  12. #402
    Bentleigh Victoria
    3,423
    This will be next once I sort the brakes. I don't want to go faster if I can't stop. The guys at the front have it too easy
  13. #403
    483
    Another cracker start, you've got those dialled. Good prioritization on the brakes. What type are you considering?
  14. #404
    Bentleigh Victoria
    3,423
    I am surprised I can get it off the line so well given how extreme the clutch is. There is so little between in and fully out. It just bites real hard, but I manage to be able to get a little slip for long enough. The starts at Phillip island where better, I spun the wheels a bit too much this time.
    Not sure on brakes, I got onto a guy that had a good set from a VN IPRA car. But he hasn't been back in touch since we first spoke. I have seen XYZ brakes on a few cars, they look like they do the job, but I would rather go with a good brands like AP or Alcon, etc.
  15. #405
    4,796
    what happened to vid of race 2 ?
    has been removed ?
    due to legal action ?
    embarrassment?
    other ?
  16. #406
    Jun 2007
    724
    Have a look at Essex Racing in the states, they've got some really good information on there although they won't have anything to fit the Commodore. There's some cheap AP 6 pistons jobs on Ebay at the moment.
  17. #407
    7,540
    It must be all that spirited driving of the wagon
  18. #408
    Bentleigh Victoria
    3,423
    I had to remove the video as it is in the club rules. Looking on eBay now.
  19. #409
    Ballarat, Victoria
    359
    Got these on my FD. Work good and the rotor life had been fantastic. Use them with PMU club racer pads.
    http://pbbrakes.com/brake-kits/holde...brake-kit.html
  20. #410
    Apr 2003
    Roleystone
    3,358
    I used DBA T3 slotted 362mm Rotors and Ebay Alcon 6 pots on my VN.
    GURU ENGINEERING PTY LTD
  21. #411
    Jun 2007
    724
  22. #412
    Bentleigh Victoria
    3,423
    I am going to work on the master cylinder first. It would be nice to have a pedal that doesn't just drop to the floor, even in the pits. So bought this from Demon Tweaks.
  23. #413
    Bentleigh Victoria
    3,423
    I am running out of time to get this ready before the next round. I have less than 2 weeks (due to trip to Sema), and Nick is busy.
  24. #414
    Apr 2010
    90
    How did it go with the new master cylinders?? I'm curious about the pedal feel with the standard pedal box
  25. #415
    Bentleigh Victoria
    3,423
    I didn't get time to get the car ready, plus I couldn't make the next round as we timed it wrong with the flights. When I get some money the car will go down and get this sorted. For now it will sit in the garage as an expensive ornament.
  26. #416
    Peoples Champ Fatboy's Avatar
    11,379
    Currently looking around for an ex Commodore Cup VS roller for IPRA. Is this for sale yet ?
  27. #417
    Bentleigh Victoria
    3,423
    Thinking about it. I just got the car back from the shop, it's been there for months. And it's amazing to think I haven't driven it since August. $5500 later it has a working brake pedal. :/
    I am a bit over it, it is way more expensive to build than I anticipated, and I don't really have the budget to race it. I am going to tidy it up, it needs a good wash at the very least. I probably won't sell it as I would cry from how much it's cost and what it's probably worth. In labour alone it's well over $35k.
    In a few weeks I will book it in for a test day to try out the new brake feel. I also have some nice Project Mu pads that are the same as the V8 Supercar compound apparently. With some brake ducts I should finally have a car that stops with confidence.
  28. #418
    11,379
    Yeah, i hear you mate, it gets disheartening hey ? I dumped 70k into my IPRA RX-7 and got back almost 25k. It sucks but it is what it is...
    BTW - Take the Project Mu pads and throw the cunts as far away as possible. Then go track them down, repeat. Several times. Here's my vid from when the pad peeled away from the backing plate leaving me with a pedal that went to the floor...
    https://drive.google.com/file/d/0B1Y...IwRFZOanM/view
  29. #419
    Bentleigh Victoria
    3,423
    The guy I bought them off has been running them, they have been fine. I hope mine don't do that. I have only really done a couple of race meets in this car, so everything is still pretty much new. I would like to put some more k's on before I think about selling it. You could always p.m me if your serious
  30. #420
    11,379
    Hopefully you're right. Pull them out after each couple of sessions for peace of mind mate...
    I've been kinda looking for VS for ages, but love the VN as well. Have a think about it and if you end up wanting to sell let me know ballpark...
