Page 2 of 17 FirstFirst 12345612 ... LastLast
Results 31 to 60 of 484
Thread: VN Group A Race Car (round 2 of the V8's)
    Bentleigh Victoria
    3,577
    Yes.
    2,004
    Thought it might have getrag due to hydraulic clutch..if t5 find what it is out of sell befrore you pop 3rd out the case.
    Buy ls1 do speed rebuild + cam/springs yourself...who cares if it pops grab another as spare lol.
    Dogsballs could point you in right direction for engines etc
    Still got that muncie/t10 thing or has to be 6 speed?
    Bentleigh Victoria
    3,577
    I still have the 4 speed T10, it would be a lot lighter than a 6 speed. I could use it, but like the idea of a modern 6 speed without the linkages.
    True, the LS1's are cheap and plentiful. But I want to finish races. If I get an LS1, I would need to get it rebuilt half decently. I will pay attention to the oil supply as that seems to be the killer. So good baffled sump and accusump. Unless I can get some dry sump at a reasonable price, but doubt the budget will stretch that far.
    Tits! Kroozer's Avatar
    Sep 2014
    NSW Yo!
    210
    I can buy crate L98's, but dont see any crate LS1's.
    Where can you find Crate L98's 6+months ago I couldn't find any in Aus?
    2,004
    Holmart still got one for 7k also 2 other joints on ebay all in Vic.
    If you want NSW arse reaming try Eagle Autoparts.
    Sounds like whether 2nd hand ls1 or crate engine you're still going to pull it apart for mods.
    Peoples Champ Fatboy's Avatar
    11,507
    Group A had 6 spd so if budget conscious go LS1 & stock 6spd.
    A decent LS1 with cam and heads will easily go north of 300rwkws - more than enough in a VN to be competitive....
    Bentleigh Victoria
    3,577
    Around 300 is what I am after. LS1 with a rebuild might be the go. But if it's not much more to go 6.0l then I would consider it. Depends what the LS1 ends up costing.
    7,829
    Ls1 is pushing it though. 6.0 or 6.2 rectangle heads will do jt easy and room to upgrade
    7,829
    I replies to your message btw
    Cuntberra
    6,094
    Loosely quoting TK the cathedral port heads have a more usable torque band so they are better on a circuit track.
    11,507
    L98 with the right cam and heads will go close to 350rwkw. How fast do you want to go ?
    Me personally i'd save a few extra bucks and go dry sumped L98. But that's just me....
    Bentleigh Victoria
    3,577
    Cheers.
    Bentleigh Victoria
    3,577
    I sent off an email asking for a price on dry sump to an American company. They have not replied. What is the cost roughly?
    There is a pump and tank on gumtree for $800.
    Bentleigh Victoria
    3,577
    HPW have 6.0l motors with box and loom for under $5000. Might be the go.
    938
    We've run a crate l98 with cam, springs, pushrods and a home brew 4 stage dry sump for 4 years. 310kw at the rears. Never touched a rod bolt, pulled the intake or a head.
    Can't recommend one highly enough for cheap fasts.
    We also run a Jerico which is great if you can get over your linkage fears. Keep the cam sensible and you won't run out of power between gears.
    Registered User TK's Avatar
    Sep 2006
    6,983
    Wait & save for an LS2, see if you can find one with less than 150,000K's on it.
    Freshen with rings, bearings & ARP rod bolts - open up bearing clearances a little - .0025-.0028" on the mains, .0023-.0026" on the rods, you may need 1/2 a set of HX bearings to get there.
    Use the 243 heads that come with an LS2 - they will not produce as much top end HP as the rectangle port heads, but will produce a stronger TQ curve & be more drivable. A reco on the heads with good valve job, stock valves, mild port work & mill to get to 12.5:1 comp is all that is required.
    Cam around 238/242 on 109 centres - none of this wide lobe centre bullshit.
    You may need to eyebrow the pistons for piston/valve clearance, can be done by hand with a die grinder, or send to SPS & have them do it, or buy new slugs that already have valve reliefs.
    Add good springs, pushrods & trunion upgrade for the rockers.
    Run on E85.
    Ditch the stock intake & use an edelbrock victor jnr with a 4 hole TB - much better transient response & more top end into the bargain.
    Grab one of those cheaper dry sump kits I linked you to, cheapest upgrade you'll do (in that it'll save you building another motor).
    By the time you buy a good sump etc you're 1/2 way to the cost of the basic kit.
    Another option is to buy dry sump bits second hand & make your own - but it never seems to work out much cheaper that way, all the little shit like drive, pump mount, pulleys & lines end up costing more than they would if you bought a kit & it comes out only a little cheaper.
    Almost every failure I've seen in an LS circuit engine has been oiling related, you can build it reliable without a dry sump, but it's not much cheaper, dry sump is good insurance.
    It won't be the cheapest engine, but it will be reliable & fast enough to not be cursing the lack of HP.
    I've got a couple built just like that, they make 320-330rwkw & run hard.
    7,829
    But thats $20k
    May 2014
    267
    But thats $20k
    This
    8k motor
    2-3 k dry sump
    6-7k gear bag
    Plus all the rest....
    I love club racing, can't handle the dollars.
    938
    Cheap, fast or reliable. 2/3...
    Bentleigh Victoria
    3,577
    My original budget was way under that. I will go with the 6.0l motor.
    I emailed the dry sump guys. But no reply as yet. I can get my sump modified by my mechanic. And buy an acusump. Should work out cheap enough and hopefully work.
    May 2014
    267
    With the accusump. Just do what vett guys do in the states.
    I pretty much, force oil back into the oil pump, gears.
    Apr 2003
    Roleystone
    3,382
    My LS drysump was about $900 total
    GURU ENGINEERING PTY LTD
    Sep 2014
    NSW Yo!
    210
    Tried both them and they told me no, and just had a look on Holmart Website again and no good...
    Bentleigh Victoria
    3,577
    I saw one on Holmart I thought, or eBay.
    I finally caught up with the guy across the road, he has a really neat VL Calais with a 6.0l conversion built as a burnout/cruise car. He wants $18k for the lot. But it has a lot of good stuff, so if I can part out the bits I don't need and sell the car minus motor and box. I should get out of it for around $10k or less. He said he spent $2k or so on the cooling system, $3k on the fuel system, etc. Ceramic clutch, 6 speed. And the motor is built not long ago with forged bottom end. It only has a HSV cam, something to do with rego. Made just shy of 300rwkw's. Not sure what a good VL Calais is worth minus it's motor and box. $6k? It's bright red and silver. Original 5.0l car.
    The best part is I just have to walk across the road and pick it up. And it has everything I need. No sourcing conversion kits and bits and pieces. So will speed up the process. And being a newly built engine with maybe 2000km's it should last a lot longer than a wrecker motor with 150,000km's.
    Bentleigh Victoria
    3,577
    Any links or details?
    7,829
    Whats another car?! Lol
    Cuntberra
    6,094
    Lightyear you have to remember that a street car vs a race car is like cat and dog. I would listen to TK if your filling the rocker covers and hit a hard turn and the pick up go's dry for one millisecond that's it at the right revs.
    2,004
    Yep you're broken haha
    Fucking envious of $900 dry sump setup.
    Kroozer it's all on ebay,according to that Holmart have 2 available.
    May 2014
    267
    Good luck parting out the VL....
    Get ready for the all time low dealing with flat brim, comoodore people.
    Bentleigh Victoria
    3,577
    The motor should be no different to a race car motor. Except for the dry sump. He said it has a baffled sump, but I would like to see how baffled it is.
    If I can get a dry sump that works for $900 I will be all over it.
    I know of one guy that runs a good sump and accusump and has had no issues.
