Page 3 of 15 FirstFirst 123456713 ... LastLast
Results 61 to 90 of 440
Thread: VN Group A Race Car (round 2 of the V8's)
    Bentleigh Victoria
    3,385
    After thinking about it (always dangerous) I should keep the VL Calais, and install the Holden bits I don't need from the VN. And buy an ok 5.0l to drop in.
    1,560
    Supershakes (steves), $900 dollar dry sump is because he builds racecars all the time.
    By memory, it's a combination of a factory LS7 dry sump kit modified to work on a L98 crank, think custom collars/adapters made. He does all the fab work himself.
    He is also smart enough to know what to buy and where from, along with the many parts he has lying around.
    If he could do a kit for 2k fitted there would be a line of cars heading down to S.A to make it happen.
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
    8,867
    Question. Are you allowed to swap in a VR-VS front end? They have chapman struts vs the macpherson struts found from VB-VP. Which means better lower ball joint location better camber adjustment and a bolt on bearing/hub with hat style rotors.
    Commodores have NEVER used Chapman struts, unless they've suddenly started using a driveshaft to locate the strut.
    1,560
    ^^^^^This, nice EFI 5ltr and manual in the Calais would fetch a reasonable sum.
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
    Bentleigh Victoria
    3,385
    It's getting out of hand now, even for me. My brother just tells me his neighbour has a 5.0l VS or VR that he only wants a grand for... Motor is good.
    Buys a car for a motor, then buys another car for the motor for that one. 🤕
    1,722
    Skompa MKII but with slightly more expensive, less shit cars????
    Bentleigh Victoria
    3,385
    Th vs is gone he said, so hopefully it's sold. Saves me buying it.
    Peoples Champ Fatboy's Avatar
    11,365
    Wait & save for an LS2, see if you can find one with less than 150,000K's on it.
    Freshen with rings, bearings & ARP rod bolts - open up bearing clearances a little - .0025-.0028" on the mains, .0023-.0026" on the rods, you may need 1/2 a set of HX bearings to get there.
    Use the 243 heads that come with an LS2 - they will not produce as much top end HP as the rectangle port heads, but will produce a stronger TQ curve & be more drivable. A reco on the heads with good valve job, stock valves, mild port work & mill to get to 12.5:1 comp is all that is required.
    Cam around 238/242 on 109 centres - none of this wide lobe centre bullshit.
    You may need to eyebrow the pistons for piston/valve clearance, can be done by hand with a die grinder, or send to SPS & have them do it, or buy new slugs that already have valve reliefs.
    Add good springs, pushrods & trunion upgrade for the rockers.
    Run on E85.
    Ditch the stock intake & use an edelbrock victor jnr with a 4 hole TB - much better transient response & more top end into the bargain.
    Grab one of those cheaper dry sump kits I linked you to, cheapest upgrade you'll do (in that it'll save you building another motor).
    By the time you buy a good sump etc you're 1/2 way to the cost of the basic kit.
    Another option is to buy dry sump bits second hand & make your own - but it never seems to work out much cheaper that way, all the little shit like drive, pump mount, pulleys & lines end up costing more than they would if you bought a kit & it comes out only a little cheaper.
    Almost every failure I've seen in an LS circuit engine has been oiling related, you can build it reliable without a dry sump, but it's not much cheaper, dry sump is good insurance.
    It won't be the cheapest engine, but it will be reliable & fast enough to not be cursing the lack of HP.
    I've got a couple built just like that, they make 320-330rwkw & run hard.
    Hey Tony,
    If someone dropped an LS2 on your doorstep and you rebuilt it as above what would it cost roughly ? Just curious... and someone has made a pretty generous offer on my Pulsar...
    11,365
    After thinking about it (always dangerous) I should keep the VL Calais, race it and sell the VN cheap to Fatboy as is...
    Fixed that for you...
    Bentleigh Victoria
    3,385
    I need to own the VN for more than a week before I can think about selling it.
    Bentleigh Victoria
    3,385
    I am taking the VL for a spin tomorrow. And should be able to make a deal.
    Registered User Brad88's Avatar
    Oct 2008
    331
    you are off your head...
    '93 6SPD T04Z UZA80 Supra
    '93 Auto T04Z JZA80 Supra
    '97 5SPD Corolla RallyX Shitbox
    PF F1 SuperBru Tipping Champion '15, '16 & '17
    Bentleigh Victoria
    3,385
    It's the cheapest way to get the car running with a nice 6.0l. And as a bonus I end up with a car I can run on ch plates.
    11,365
    You picked it up 3 days ago. Let's talk in another 4 ?
    Bentleigh Victoria
    3,385
    If I didn't have to make a batch of carbon fibre parts, in 4 days this car would have an LS2 in it. I presume I can just drop the subframe out with motor and box, and bolt it into the VN? Same subframe surely. I was always told a VN is just a fat VL.
    One mod I might do is swap to a lightweight flywheel. I like the quicker rev for down changing gears that you get with a lighter flywheel.
    And the sump will need modifying.
    Bentleigh Victoria
    3,385
    Had a quick look on eBay. This one is local, so might get it quicker.
    http://www.ebay.com.au/itm/Lightweig...kAAOSwMmBV0UQo
    This is another option. I have ordered parts from USA that have arrived faster than from Sydney.
    http://www.ebay.com.au/itm/Competiti...EAAOSwZ8ZXBnIu
    Cronulla
    1,263
    I was informed a vn has a narrower track than a vl if that effects anything.
    turbosurfer
    Bentleigh Victoria
    3,385
    That can be fixed.
    I just found some pics of what I did to my last VN.
    forum image hosting
    1,560
    Don't do that
    Sandown 1.23.31
    Calder 1.05.76
    Winton 1.33.30
    Bathurst 2.47.49
    Racer 36's Avatar
    Oct 2014
    248
    What about the awd ones- Adventra/Crewman -what did they use?
    Bentleigh Victoria
    3,385
    Look what I have.
    I now own 4 Commodores. WTF??
    image sharing sites
    4,768
    Look what I have.
    and how many MX5's and toranas?
    Bentleigh Victoria
    3,385
    No more Torana's. And only 1 MX5. Technically it's only 3 Commodores and a Calais. , not so bad.
    Bentleigh Victoria
    3,385
    This is probably the view of the VL you want to see.
    img host
    11,365
    Cage the VL ?
    Apr 2003
    Roleystone
    3,343
    https://www.facebook.com/groups/1395...67693896813790
    GURU ENGINEERING PTY LTD
    Apr 2003
    Roleystone
    3,343
    Any links or details?
    I will see if I can find pic's of it for you, Works a treat.
    Bentleigh Victoria
    3,385
    I have a 4 puck ceramic clutch, it works
    I will get a flywheel for under $500. I had a thought of showing a quick video, but I was almost home so made a tiny video. Probably the last time I drive the car. Went for a cruise to check out the cars at B.P Eastlink.
    https://m.youtube.com/watch?v=O5y8wSSeMlU
    1,924
    How tall is that silly scoop?
    Bentleigh Victoria
    3,385
    Not as tall as the gearing. 3:08 diff gears make 5th and especially 6th redundant. I will have to change the bonnet. There was a few cars with the same bonnet cowl at B.P. And an amazing amount of younger loser looking people.
