Page 4 of 14 FirstFirst 12345678 ... LastLast
Results 91 to 120 of 415
Thread: VN Group A Race Car (round 2 of the V8's)
    Bentleigh Victoria
    3,132
    I recieved a bit of info about the motor.
    LS2 with forged pro Pistons, scat rods, double row timing chain, standard Comp. L98 heads with aftermarket valves, springs and pushrods. LS2 HSV cam, 24 x reluctor wheel. 25% under drive pulley. Fast throttle body and standard injectors. HPC coated Pacemaker extractors, LS1 ECU, custom harness.
    The sump will come off to get modified with better baffles and maybe larger capacity. Will have a look at the engine condition.
    Bentleigh Victoria
    3,132
    It's started.
    how to capture screen
    Bentleigh Victoria
    3,132
    I bought a Yella Terra lightweight flywheel, and was told the clutch was pretty new. Pulled the clutch apart, the flywheel has massive heat marks in it. And the clutch material rivets are loose. It worked fine. But it's no good to put back in. So now I need to buy a clutch.
    I figured I can return the flywheel, and buy a twin plate clutch and flywheel package. Does anyone know of something that will work without spending $2500?
    Not the VPW guy :) 132oft's Avatar
    Jul 2010
    QommunistLanD
    1,435
    Why twin plate? Just get a Nicks (NPC) single.
    Perfect mix of sports and luxury... Like an automotive version of a mullet
    1,873
    Clutch wasn't going to last when it was built to powerskid in the vl...
    Bentleigh Victoria
    3,132
    Progress is just researching and buying parts at the moment. Once I have the new clutch, gasket kit and baffled sump kit, the motor can be bolted in. Also going with a new pulley under drive kit. Trying to work out coilovers. And I need to buy the wheels and tyres. Brakes are going to be AP.
    1,528
    Keep me in the loop regarding brakes Dave.
    Adam
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
    Bentleigh Victoria
    3,132
    My mechanic is getting me AP Racing brakes. I think they are late model HSV?
    Also, I bought some spare parts.
    upload pic
    Picked up the Improved Racing baffled sump kit today, as well as the Powerbond 25% pulley kit. It already has a 25% pulley, but wanted the Powerbond kit. Just need the sump gasket kit now, and the motor can go back together and be installed.
    Bentleigh Victoria
    3,132
    AND, I am hiring a complete set of VP Supercar moulds so I can make my own bumpers, wing and stuff. (Might be lighter with me making it all)
    7,113
    Fuel cell and lift pump?
    Bentleigh Victoria
    3,132
    Sorry, forgot. Will ask in the morning. Pretty sure I don't need the 20l and pumps from the VN.
    7,113
    Still think it's 40 litres
    Bentleigh Victoria
    3,132
    It's easy enough to measure the size. Pm'd you.
    ACT Now!
    26,755
    Oh, NOW VN 's are the hotness. :/
    Looking good mate! I ran a single plate mal Wood ceramic and it was actually pretty good.
    You may also find turning the inlet manifold around and plumbing a filter in the plenum may work and save you the bonnet bulge hassle.
    Prod Sports Racer CT's Avatar
    1,437
    Did you sort a clutch? I use a Mantic twin plate on the vette and it's awesome.
    A slow day at the track is better than any day in the office.
    Bentleigh Victoria
    3,132
    I wanted to get on the VN bandwagon so I don't miss out on being in the cool crowd. Never thought about turning the manifold. Will look into it.
    I am getting a triple plate clutch. Can't remember the brand, but apparently it's the one that J.B runs in Touring car Masters. Cost was similiar to the Mantic.
    Bentleigh Victoria
    3,132
    The shiny bits are starting to arrive.
    photo hosting
    7,113
    That's an ashtray not a clutch
    Bentleigh Victoria
    3,132
    I don't want to go through clutches and brakes this time. So I am spending the money on good stuff straight up. Works out a lot cheaper. I am too poor to buy cheap parts.
    Aug 2014
    1,277
    Good shit.
    883
    It's a PTT unit. We run the same. They last for ages.
    Pro tip: the flywheel bolt pattern matches most of the ex NASCAR complete units you will find on eBay that are barely worn and cheap...
    Bentleigh Victoria
    3,132
    Good to know. Not much fun sourcing bits, getting them, trying to fit them and they don't fit. Then take them back...
    Such is race cars. I bought 2nd hand Pirelli slicks of a guy last night, and a set of 2nd hand Koya 18x9.5's this morning. Then did a quick check to see fitment on the rear. Turns out I will need a VL diff. Fuck, should have swapped the one in the VL before selling it. Probably works out better this way as I get a fully rebuilt diff with billet 31 spline axles, new 4.1 diff gears, and new good quality full spool. I figured it was important to have a car that finishes races. So hopefully the diff won't break any time soon.
    The Powerbond harmonic balancer was the wrong one. So took that back, and sourced the right one.
    Still need to source brakes and suspension. I think I need to do the springs to clear the wheels. But the brakes can wait. I may run out of money.
    Peoples Champ Fatboy's Avatar
    11,282
    Not trying to rain on your parade mate, but why wouldn't you build it to comply with IPRA regs - like Adam's VL ? That way it opens up options down the track plus you can always get more dollars for a 3J logged car if / when you decide to move on ?
    14,704
    Building a race car to meet regs is neither the Lightyear way, nor the PF way...
    Bentleigh Victoria
    3,132
    I will build it to suit VicV8's. And modify it to suit IPRA when/if the time comes. But really, IPRA has all these rules. If VicV8's gets really popular, there may not be a need to change. So far the car has had no permanent mods. I will finish the MX5 to race in Sports cars. So between the 2, I am sure I will be kept entertained/poor. And in a couple of years I may sell them and try something else, who knows. But for now, I am happy to give the V8's a go. There is something special about driving a V8. Sure the Jap cars may be faster, but being surrounded by V8's and hearing your own car is bogan heaven.
    205
    If you are trying to get the diff done properly first time around get fully floating hubs. Consider camber/toe etc. talk to someone with high level experience of similar car, or there are quite a few setting up these diffs that know their stuff.
    Ps. It's your car so built it how you want, but got to agree with those suggesting to keep an eye on ipra regs. If not for the competition, certainly for saleability.
    Bentleigh Victoria
    3,132
    It's about $4500 for a cambered full floating diff. I don't want to spend that much. I haven't done any mods that put it outside of IPRA that I know of. I will do, buy they will be reversible. Like door Windows.
    7,847
    So far the things that will cause issues for IPRA:
    9.5" wheels
    Slicks (easy/cheap enough)
    VP supecar aero
    6 speed if it is rebodied a VP
    Despite these obvious advantages, pretty sure the front running IPRA cars are still faster.
    My Sports Sedan
    May 2014
    243
    9.5" wheels
    VP supecar aero
    Don't forget most front running IPRA cars are 6 figure builds
    Bentleigh Victoria
    3,132
    9.5" wheels
    VP supecar aero
    All these things are pretty easy to change. Will look at IPRA times. But it's hard to say how much slower I am given I haven't driven it.
