Page 5 of 16 FirstFirst 12345678915 ... LastLast
Results 121 to 150 of 475
Thread: VN Group A Race Car (round 2 of the V8's)
  1. #121
    Peoples Champ Fatboy's Avatar
    11,424
    Ray Hislop has the IPRA lap record with a 1.40.1 - just so you have something to aim at...
    In saying that, his car is stupidly fast and well clear of the pack. Keen to see how you go mate, your laptimes in the other nugget were pretty good so following with interest...
    Bogan taxi owner
    Budget APRA racer
  2. #122
    Bentleigh Victoria
    3,500
    The green car would have done a 1:47 with a lighter flywheel, better diff gears and brakes that worked. Probably even more given the driver was still learning the car.
    This car will be a massive improvement in every way. 60% more horsepower for a start. I am guessing a 1:43 on its first day out. Then improve on that with testing and tuning.
  3. #123
    May 2014
    263
    I last thing I saw mr hislop, do. Was run out of talent at Bathurst. That car was miles quicker than any thing else.
  4. #124
    Bentleigh Victoria
    3,500
    Without looking over the rules, I wonder why this car can run Supercar aero, and I can't.
    forum image hosting
  5. #125
    8,409
    That's not supercar aero...
    While the bumper is free there are limitations with regards to the splitter and there are very strict limitations with regards to the rear wing. That is much, much smaller than a v8 supercar jobbie.
    Bentleigh Victoria
    3,500
    Well when the time comes I will start attending IPRA meets and get a better understanding. With the VicV8 rules, I would want to be at least 2 seconds faster than the IPRA guys if I want to run at the front of the pack once converted to there rules.
  7. #127
    8,409
    Just take a look at the rule book. Despite up to 7litre motors and 10" wide slicks the local (sister to Vic v8s) QTCC cars are much slower than front running IPRA cars.
    1,576
    Couple of basics for IP dave,
    265 is the largest tyre for LM models,
    Limits in spoiler height, width front and back,
    1450kg min weight for an engine swap LM V8
    R spec tyres
    100mm ground clearance
    Lots if guidelines on what you can change and where you can put it.
    Don't doubt the effort required to run at the front.
    Also no wet dumped LS is running 43's at PI for more than 1 lap.
    Sandown 1.23.31
    Calder 1.05.76
    Phillip Island 1.47.95
    Winton 1.33.30
    Bathurst 2.47.49
  9. #129
    Apr 2003
    Roleystone
    3,378
    We cut this until it fit the IP rules.
    GURU ENGINEERING PTY LTD
  10. #130
    Bentleigh Victoria
    3,500
    Quote Originally Posted by adamRSLC View Post
    Couple is basics for IP dave,
    265 is the largest tyre for LM models, -I have 265's (slicks)
    Limits in spoiler height, width front and back, -Same as VicV8's? Or similiar.
    1450kg min weight for an engine swap LM V8 - I should be 200kg under
    R spec tyres - I knew that one
    100mm ground clearance - same as VicV8's
    - I will find out if that's true
  11. #131
    Bentleigh Victoria
    3,500
    I will do the same, VicV8's is also 100mm
  12. #132
    938
    Ray also knows how to steer and poke at the pedals. I pity whoever takes over his car.
  13. #133
    11,424
    I have to say, I admire your optimism mate. There is a thing called the law of diminishing returns. It's very applicable to Motorsport.
    Following with much interest, your car is almost the perfect recipe for a fast V8 without requiring a stupid budget !
  14. #134
    Bentleigh Victoria
    3,500
    I have never been wrong about my predicted lap times. Unless there has been an issue, and the lap times had to wait until the next go. There may be some issues as its a new car, and it may not have everything finished in time for the next round. But it will get there.
    Been looking at buying a 9" diff now. I don't like the idea of having a heavy diff, but it is good for ratio choices and won't break. Also have been talked into going full floater. Then if you go that far, may as well get camber and toe adjustment.
    I ordered some B.C S13 coilovers. Will see how that goes too.
  15. #135
    8,409
    Run a strange alloy carrier, drops something like 9kgs out. Probably makes it lighter than the BW. On top of the toe/ amber adjustable floaters, Geoff at Race Products also does chromoly housings and really sweet adjustable roll centre watts links.
    Bentleigh Victoria
    3,500
    I decided to just go with the VL diff, then when I have more money and time, sell it and upgrade it.
    The alloy carrier was 7kg lighter I was told.
  17. #137
    Aug 2014
    1,326
    Sound reasoning. As I'm sure you know, you're going to want to strip as much of that chassis / unsprung weight as possible on these girls down the track. Talk to JET 3LT Jase about how much he swiss cheesed his VL body and how boat anchor the thing still was. Of course, a big ol' steel 9in - and all the rest - does that. Lol.
  18. #138
    1,445
    Quote Originally Posted by BLO 767 View Post
    it was a solid barge that thing lol, i made many offers to hack the shit out of it for him
  19. #139
    8,409
    Once you start Swiss cheesing you can say goodbye to IPRA for ever though. JET3LT also had rediculously heavy/big ROH Modena wheels on it didn't it?
    Keen to see you get this lapping quick. If you can change it back to IPRA spec relatively easily would also love to see a relatively budget car towards the pointy end. But it certainly won't be easy.
    1,956
    Got 9 inch in back of vh...holy fuck do you notice the extra weight compared to borgwarner but the truck diff feels almost unbreakable.
    Cheapest route would be vn diff but guessing want vl for the bigger wheels & group a spec.
  21. #141
    8,409
    Wouldn't a 9" with strange alloy carrier & chromo housing be considerably lighter & stronger than the BW?
    Aug 2014
    1,326
    Yep all good points. Retaining IPRA is the hardest part considering the two major things you want to do are making room and saving weight, both which require some hefty modding. Everything to make them fast has been done before, but it all depends on how much you can get away with.
    Correct, but path of least resistance is often the steel 9in.
  23. #143
    Bentleigh Victoria
    3,500
    I need the VL length so the wheels fit in the guards. There will be no permanent chassis mods made. I need to keep the options of other categories. Things like wheels, bumpers, body kit and even doors are all on the easy to swap list. There is also the heavy metal sport sedan class that I will look into as well. I think it's a great idea. You don't need a spaceframe car to compete at the front then.
  24. #144
    7,398
    How the fuck did i miss this thread!
  25. #145
    Sep 2014
    Ballarat
    273
    'Cos it one of 11ty bazillion threads started by lightyear about the 12ty bazillion race cars he has hiding in his shed ............
    I'm now waiting for when the nopics drops the hammer and orchestrates a fleet rationalisation (sorry Dave !!)
  26. #146
    7,398
    Yeah that would explain it.
  27. #147
    Bentleigh Victoria
    3,500
    I have culled already. Only 3 Commodores now (including the spare parts car). I probably have started more than a few threads on cars. 😗
  28. #148
    Bentleigh Victoria
    3,500
    I ran out of carbon fibre, so decided to go down to the car for the arvo. The S13 coilovers arrived and I trial fitted them. They don't just bolt in as I was told. The top holes are close, I used a rats tail file to elongate the holes by about 2mm. The bottom holes are way off. The coilovers needs to be about 100mm longer. We will modify the bottom brackets to suit. Rears will also need mounts made at the top, and bottom shock mount reinforced. Also took a pic of the throw out, looks too good.
    upload a picture
    free image hosting
  29. #149
    16,054
    The rear spring rates will be miles too stiff.
  30. #150
    Sep 2014
    Ballarat
    273
    Tongue was very firmly in cheek Dave .............. I'm loving what you are doing and how you go about it.
