Results 1 to 30 of 56
Thread: Adaptronic Modular Series
    6,434
    There are two new Modular series coming out soon. The M2000 and the M6000. The "Modular" design allows for the selection of hardware based on requirements, and is upgradable in the future as hardware requirements change.
    M2000 shown with AMP/TE Connectivity Superseal 34 and 26 pin plug. On the rear is the USB comms, 4x RS232 serial and amplified knock headphone jack (inbuilt knock ears)
    The M2000 has the following inbuilt - 1 additional small option card slot available.
    Unlimited functionality due to cusomised logic for the ECU to control fuel, IO and internal calculations. A similar system to the 1280 and other manufacturers custom logic.
    Inbuilt 3 axis accel and gyrometer
    FAST!!!! USB connection with no drivers required
    Inbuilt WIFI for tuning and real time data
    Inbuilt 4 channel SCOPE for CAS/calculated values and real time values (spectacular for diagnostic)
    Inbuilt logging - Huge amounts of datalogging - 32 MB - Max 30 hrs @ 10 Hz, 13 channels - Min 20 mins @ 100 Hz, 125 channels
    Two CAN channels - OEM vehicle and or propritary CAN such as WBo2, DASH, EGT's, GPS etc etc.
    Four serial connections - Still the most common peripheral communication protocol for WBo2, Dash's and other equipment - Power supply included for hand controllers and powered devices
    Screw mounts - additional mounting kits not required!
    USB comms powers the unit - logs and settings can be adjusted with the ignition off
    1 Inbuilt Inlet MAP
    1 Inbuilt Exhaust MAP (for DP tuning wowowow)
    8 Ignition outputs (configurable as AUX if unused by IGN)
    8 Injection outputs (configurable as AUX if unused by INJ)
    4 Aux outputs
    11 Analogue Inputs (ext MAP(s), Oilp, TransP, external wb02 x2, EGT, boost trims)
    4 Temps with switchable pullup (ECT, IAT, OilT, TransT)
    4 Digital In (clutch, two step, rolling antilag, pit limiter, two step, boost trims, aircon)
    1 VSS
    3 CAM/CRANK trigger inputs (V engine closed loop VVT)
    1 Knock (with headphone plug for audio knock while tuning)
    1 Dedicated Tacho out
    1 Dedicated EFI Relay out
    The small option slot can be populated with one of the following.
    • DBW / e-throttle controller
    • Mini Output Board (6 x push-pull aux)
    • Mini Analogue Input Board (4 x analogue inputs)
    • Mini Real-Time Input (6 x inputs) So you can do another 2 x CAS (giving 5 total), 3 x VSS (giving 4 total), 1 x flex
    • Lambda Controller
    • EGT Inputs
    So basically you get to run a VVT V8 sequential, with every single temp and pressure monitored and you can then choose either of the above options above should they be required(DBW or FLEX for instance). There is only 1 option slot on the M2000.
    The M6000 has all of the above but has the ability to expand to:
    24 Ignition outputs (configurable as AUX if unused by IGN)
    24 Injection outputs (configurable as AUX if unused by INJ)
    12 Aux outputs
    4x Small option slot
    • Lambda Controller
    • EGT Inputs
    This means you can have a a lot of IO (due to unused injectors and ignition outputs), DBW, Flex, traction control, inbuilt lambda, EGT and anything else you can think of!
    12,769
    Fuck that sounds pretty awesome!
    Any hints at pricing?
    wait.. uses jaycar connectors. Wnb /cracka
    6,434
    1800 for M2000
    2000 for M6000
    Ballarat, Victoria
    359
    Ive been chasing Andy for one for a while. He said another few weeks.
    In another few weeks I won't have any money
    3,208
    there was already a thread for this :P andy needs to hurry up and release these!
    6,434
    Yeah soz trdee I wanted top post lol, all credit to you
    Wrong.
    7,034
    Just need to adjust the screw pot for maf scaling, and set the jumpers to determine if comms are through printer cable or ATA ribbon cable. Molex 4 pin connector for easy powering up when beside PC.
    windsor nsw
    1,192
    But can you run over it with a car??
    Wrong.
    7,034
    Makes a good wheel chock.
    If adaptronic people sat back, opened their website, and read it... They would realize the whole modular series makes zero fucking sense. It's written so poorly and filled with gibberish that unless you know exactly what it is, it sounds as if it's got a 386 SX30 with 8 spare ISA slots for expansion and a soundblaster 2. In no way makes them inferior, just they have next to no clue how to market a product at all. 6 very technical, asbergers as all fuck, and highly eccentric guys with FJ20's in datsuns or mx5's does not make a compelling argument sadly. Despite how excellent it seems to be if it's in any way comparable to the 1280's software, with better hardware.
    6,434
    But can you drive over it?
    6,434
    I just updated with the digital ins and temp inputs I forgot.
    11 Analogue in
    4 Temp in - pullup switchable for piggy back or stand alone
    4 digital in - sick two step, rolling antilag for power cruise etc etc
    So that's 15 analogue in!!!!!!
    gold coast
    1,629
    finally! an ECU that will run my V24 Bentley Packard fully Sequential!
    but for srs, looks good. have only seen rendered images of these so far. do they exist?
    Oo___oO
    6,434
    I think the main idea of the upgradable outputs to that level is to program for all cylinders but mainly use them for digital outs and pwm for super complex cars.
    Auto control,
    nos injection
    staged v8 injectors
    direct injection with efi on top and control all individually.
    12,391
    Cracka has the inside running on aspergers
    6,434
    Oh they exist on my buffet in the office
    I'm putting it on the aristo this week to test the faggot microtech causing me grief then it's going on a FJ20 Datsun.
    Sunshine Coast, Qld.
    7,656
    V72 sequential ecu on an fj20?
    6,434
    The one pictured is a M2000. It only has 8 injection and ignition.
    The injection and ignition outputs are all high current generic outputs on the M series, so think of it as something with 1 million analogue and digital inputs and 2 million digital outputs which can be used for injection and ignition if needed.
    Think of all the high tech gizmo's I can drive on an FJ20
    7,656
    You might be able to get the cold idle valve thing to work.
    3,208
    dash2 pro? or regular dash2?
    6,434
    Regular dash2
    Should be wiring it up next weekend.
    3,208
    nice. dash 2 is ok if you arent data logging. if you are i would go the pro tho because fuck the DL1 and its fucking shit cunt ecu interface malarkey. it's the only thing that shits me about my system. the ecu interface adds tonnes of latency to the readings on the dash
    6,434
    The ECU would look after any logging I am interested in (engine/g force/speed) but yeah I know what you mean.
    The Dash2 is such a nice bit of gear. Has a real feel of quality to it and I always enjoy using them!
    gold coast
    1,629
    the "custom logic function" stuff released yet?
    Oo___oO
    6,434
    Not yet.
    Mar 2011
    Quindanning WA
    444
    Is there some trickery to make this handle 2 channel knock sensing?
    3,208
    the new M1200 looks really good for 1k. data logging and inbuilt scope at that price is fkn awesome, and for those already running a 440 the connectors are plug and play so makes for an easy upgrade. its for 4cyls only though
    http://www.adaptronic.com.au/the-m1200-ecu/
    6,434
    To be fair, it'll run any engine just batched.
    The plugs are 99% identical, so most cars don't even need pins changed
    They are good bits of gear I haven't played with one yet though.
    Jul 2006
    1,182
    So would custom logic allow you to control the vq25det auto with these ecus? Or is it still to much work deciphering the canbus?
    24,303
    Although id never buy one M1200 does look like a decent bit of gear for the price. Few extra outputs for when they stop working over the 420d isn't a bad thing as well.
    garvice - if its any help to you at all i have a Y32 vq30det factory auto ECU box kicking around that I'll never use. I'd hazard a guess 25/30 share the same auto.
    6,434
    Quote Originally Posted by garvice View Post
    User CANBUS would be required, but it should be coming soon. Maybe not on the M1200.
    The custom logic, if it's anything like the 1280 will be more than capable of doing an auto and it's been implemented on many 1280's. I don't have an ETA for custom logic yet, but very keen for it! As it stands, you can do a fair bit just like any other ECU with axis on tables, but user logic is next level shit.
