Results 1 to 24 of 24
Thread: Adjustable wing mounts.
    5,906
    Race team head engineer wasn't happy with the rear wing positions on the mount supplied with the wing (standard multi-hole deal) so asked if I could make something with more adjustment.
    The answer was some small rigging screws (turn buckles), which of course necessitated a whole new mount.
    Needs a few minor tweaks but all in all it works well, rigging screws are easily turned with your fingers through the sweep to give between 8 and 18 degrees angle off attack.
    Apr 2009
    Devonport, Tasmania Australia
    2,204
    Fucking tops work!
    06/07/2011
    15,830
    Needs more beef to support the rear mount of the wing. Also, hopefully they remember to do the front mounts back up after adjusting...
    5,906
    Quote Originally Posted by fantapants View Post
    Fucking tops work!
    Cheers mate.
    You reckon it'll bend ? At the thinnest point it is 22mm and the material is 5052 @ 5mm (x2 per upright). This is going on a 1.5l super production car, not a v8supercar.
    2,793
    Nice
    Bentleigh Victoria
    3,419
    Looks like drag city to me.
    5,906
    The range of 8 to 18 degess is not right ?
    What should it be ?
    15,830
    I think The Lightyear is referring to the bulk of the mounts, and he'd be right if it were strapped to the bootlid of a sedan/coupe rather than the hatch of a Mazda 3.
    I guess if you're not seeing much over 100mph down the straights then it's not much of an issue - how coarse was the old adjustment setup?
    5,906
    Ohhh I did not consider drag from the actual mount saying that I ran my idea past the head engineer beforehand and he certainly did not express any concern.
    Hole spacing's on old uprights are 2.5 degrees apart which were not ideal, It is possible this new set-up will be no good but that why we rent both the local race track and a military airstrip and do aero testing and log km/h vs kg/f with each change in angle.
    From memory (albeit vague) I think the cars top out at 220km/h.
    Stupid Engine Light Nacho's Avatar
    1,538
    You need two bottles. The big ones!
    Looks decent, nice bit of fab there man.
    5,906
    Quote Originally Posted by Nacho View Post
    Cheers and yep more grunt is on the way, new turbo being built now.
    . crack's Avatar
    BNE
    2,444
    Why were the turnbuckles needed?
    5,906
    Race engineer wanted finite adjustment.
    5,906
    So with more grunt we can dial i some more downforce, not sure what to do with the front splitter as making it beefier will result in more weight and as these things are diesel more weight in the front is bad.
    Here's the current front splitter, made from 4mm marine ply and 1.5mm ally, works really well in this application.
    any suggestions on how to improve this (stronger/more down force), Keep in mind they are disposable (new splitter fitted every outing x 2 cars, Ban Saeng speed week is coming so cars will go out 8 times Between practice and racing).
    Bentleigh Victoria
    3,419
    You could put end plates on the sides to help with more downforce at the front.
    5,906
    like this ?
Name:	front splitter.jpg
    Toowoomba
    1,204
    4mm seems pretty thin compared to what I see most using, I would have expected 9mm. Perhaps something more substantial would last a whole weekend?
    I've got a sample of Monopan honeycomb panel coming, it's 4.5kg/m2 for 17mm thick compared to your 4mm at around 3.1kg/m2.
    Availability is the problem I guess. Another option is 6mm honeycomb aluminium composite panel.
    5,906
    Neil_se,
    the main issue is grinding the heads off the rivet heads underneath, hence a new one is fitted for each outing (whole splitter costs us about $10.00) but the outer edge cops a beating as well.
    Monopan is not available here but we do use it, we import from Germany in a thickness of 30mm for other projects we do.
    Bentleigh Victoria
    3,419
    Breadboard material can be used under the splitter.
    5,906
    Last lot of splitters I made were from a 6mm thick plastic material, A small 100mm x 100mm sample felt a lot more rigid than the 4mm marine ply but In practice though is was way more flexible and wore out very quick and was expensive ( $90ea for each splitter).
    What do you mean under the splitter ?
    15,830
    I imagine he means as a rubbing block to protect the rivet heads?
    5,906
    Ohh ok, yeah I cannot see that working.
    Toowoomba
    1,204
    Whatever you go for the weight would have to increase, surely the 4mm ply flexes significantly? 9mm ply + countersunk fixings would be simplest.
    5,906
    Fucks me where all the pics fucked off to but new season is upon us so now need to adapt the sedan wing mount
    To the hatch !!
