Results 1 to 30 of 31
Thread: 80 v3 Uterus
    Sunshine Coast
    439
    80 v3 Uterus
    Some scum decided to help them self to my 80 series. Was stolen off the side of the road and I haven't heard anything since.
    So I bought this.
    97 40th anniversary, Has a half decent chop done on it and a heap of parts on it but its very untidy. Also twin locked. It was originally a 1fz but for some reason someone put a Holden 5L in it. Negotiated for less without the v8.
    Plan is to un-convert it back to a 1fz with boost and do stupid shit.
    5,215
    Awesome man!!!
    No, that's asians
    A80 Supra
    80 Landcruiser
    Sunshine Coast
    439
    This has got to be the worst conversion in the world. I think someone spent alot on the chop and parts, then some tard has done this.
    Engine mounts are kind of bird shitted into place, but only on one side. I removed them with a pry bar...
    I am also entertained by their concept of extended brake lines.
    Anyway I've got most of the v8 shit out of the bay
    Bracing the chassis while I fix the mess
    I've ended up buying a 1HDT for 2k, ditching the auto. Gturbo and pump will be ordered soon then its 35psi time.
    12,453
    That looks pretty awesome, 4wd lyfe
    Sunshine Coast
    439
    Got the 1hdt home, I knew it had spun a big end but I didn't know what I was getting myself into.
    Rod was fucked head is coming off
    Hmm oversize pistons this has been rebuilt
    Standard balancer bolt removal procedure
    Balancer wouldn't come off cunt had spun been and chemiwelded on
    hmm...
    Sunshine Coast
    439
    This is the gear behind the balancer also fucked/10, loves the lash
    Midway though crank change from a spare 1hz, everything timing cover related is also now being swapped.
    Got my cooler
    Also 3 pedals now
    Sunshine Coast
    439
    This the oil pump gear, its pressed onto the oil pump shaft and doesn't come off , at least I know why its done the big end now..
    7,397
    Watching with interest.
    Sunshine Coast
    439
    Sunshine Coast
    439
    Got over working on this thing in the front yard so trailered it to my mates work.
    Started fixing the gouged mess that was the chassis.
    Kept welding and grinding until it was flat, Auto box came out was replaced with a manual and my old part time transfer, to put the auto in the crossmember mounts had to be cut off and moved 70mm forward and captive nuts put into the holes. The tunnel also needed adjustment with a plasma
    Engine mounts were positioned with a spare block.
    Tacked then welded in fully
    Also began making the shifter surround fit.
    1,851
    and those mounts where signed off with blue plates?
    9,230
    Jesus, I can't weld but I reckon my attempt wouldn't be much worse than that shit.
    Registered User E-Z's Avatar
    3,777
    craigs workshop?
    caprice nugget.
    Sunshine Coast
    439
    Its a common problem with these for the chassis to crack around the steering box and panhard bracket, Theres a bloke on facebook that makes cnc cut plates for $60
    Plates welded in both sides not the neatest welds but it was a cunt and will do.
    Diff guard, lol I wish I was making this up, removed again with a pry bar.
    Motor build is coming along too
    Sunshine Coast
    439
    I assembled the motor in a day, wasn't as hard as I had thought, Just need a clutch and pump now.
    Have also started the tray and mounts, all hand cut with the grinder out of 6mm. I hope I wont bend them with the abuse this thing will cop.
    9,230
    Saw a bloke in the US make up some tube sliders for his flat tray out of steam pipe. Could be an idea if you intend to get abit nuts off road.
    Sunshine Coast
    439
    We are going to do something with tube definitely for the guards as the tray is too narrow for the wheel offset, may end up connecting it to the sliders somehow. Headboard will be bent up out of 3" steel.
    Mounts welded up and tacked into place, we used a string line and level on the side trim to get them level lol.
    Fully welded, there are currently 4 but I'm thinking of adding a extra 2 in the center.
    Cut out the gearstick surround, tided it up with pinchweld and it came up pretty good.
    Sunshine Coast
    439
    I've got the motor in and begun connecting everything up
    Aug 2008
    Buddina
    1,775
    wow, this is scooting along!
    Sunshine Coast
    439
    Braced the lower arms, welded 25x8 bar on them. Will stop them bending/breaking then taking out the pinion shocks and driveshaft when the rear diff walks forward.
    Pump on and timed.
    Using arb compressor airline for all lines haha, normal vacuum line doesn't seem to last over 30psi
    Intercooler brackets done and front end reassembled
    After a few primer pump issues and the throttle being a tooth off on the pump I got the thing running. Took it for a quick spin out the back of my mates work, first impressions is that its a lot smoother and quieter than my old 1hz. It seems to run well and is quite quick for no tune. Also finished off the exhaust.
    Sunshine Coast
    439
    Thing is stupid response, still untuned
    Sunshine Coast
    439
    3,777
    love it
    caprice nugget.
    Sunshine Coast
    439
    So the 1hdt was doomed from day 1. Started blowing water out the overflow within 1000ks, pulled the head, got it checked new gasket and bolts. Still was doing the same shit. Suspected cracked block.
    Fuck it time to max the pump get at least some fun out of this thing. Went quite well, It saw over 900 deg egts one night while doing 4th gear hoops in a paddock. It got worse and worse until it was using the same amount of water as fuel. It also began to hydro lock if the radiator was not depressurized before turning it off lol.
    I picked up a 1hz for effectively nothing and sold what was left of the 1hdt, Bolted my turbo manifolds ect on to it and it will be getting a 12mm pump soon.
    Also finally got some decent rubber under the thing
    Sunshine Coast
    439
    Bolted the hdt pump on. Now running 30 psi boost on this poor 1hz.
    Went out to Glasshouse twice this weekend. Drove Little + Big Red, Kamikaze, Goat Track and Palm tree.
    Cab left unscathed but the drivetrain is another story.
    Broken L/H engine mount, Massive air leak from front locker, Broken rear axle, Rear locker seal housing and flangecap is fucked but looks salvageable as long as ARB can get the parts.
    9,230
    Standard axles?
    Sunshine Coast
    439
    Yeah standard axles never had a issue with them, other side is twisted and has stress cracks. They probably have had a lifetime of abuse and finally gave up.
    Sunshine Coast
    439
    Fitted some superior remote res shocks around 11.5" travel
    New tray
    Also I ran into something and bent alot of shit
    Sunshine Coast
    439
    Built a unbreakable style engine mount because more shit is failing behind the little 1hz
    Picked up a fresh diff housing and will be bracing and building it over the next few days
    7,397
    I just imagined Kimmy Schmidt as an engine mount. Carry on.
