Page 2 of 2 FirstFirst 12
Results 31 to 39 of 39
Thread: Cooling system pressure testing.
    Cuntberra
    6,094
    Also drop a block of head sealer in too apparently they help with not only a sealing leaks but also lubricating the water pump.
    6,065
    Raw eggs also assist with filling small leaks.
    5,134
    Dropped the oil, probably 75ml of water in it.
    Yeah, I'm slow.
    I'd rather put a 253 than efi
    5,134
    If you have sealed the manifold and there is nothing else where things can leak and mix your going to be pulling the heads
    This guy wins.
    Heads off.
    Leaking past the head gasket at the rear and into the valley on both sides.
    Tell me about re-using the cometics.
    Clean up with thinners and spray with hylomar?
    Should I paint around the water passages with "something" before dropping the gaskets on as well?
    Might just chuck some regular graphite type gaskets on and keep the cometics for "later"
    Jan 2008
    Bris
    1,123
    I've successfully reused head gaskets after spraying them with VHT copper gasket cement. I don't know about Cometic/MLS gaskets however.
    10,584
    You need a specific surface finish for a MLS gasket otherwise itíll leak. Theyíre coated with Viton so if youíre going to put sealer on you wonít need much as all youíre trying to do is fill the machining marks. Hylomar would be a good option.
    5,134
    Yeah I (now) know the surface finish is not where it needs to be.
    I might be tempted to reseal/assemble enough to hold water and test again (no need for pipes/rocker arms/wiring/fuel etc etc) but since my luck means if it rained nymphos I'd get washed down the drain with a bloke I can't really be fucked trying again when I know the usual gaskets will work properly.
    4,115
    Masking tape up the bores, ear plugs down holes and a really good sanding block with 600-800 grit wet and dry to get the finish nice.
    10,584
    Yep thatís pretty much what I did to finish my deck when I built mine. CRC as the lube and away. You go.
