Page 2 of 2 FirstFirst 12
Results 31 to 47 of 47
Thread: nugget vc commo wagon sr20det thing
    Melb
    832
    Blingcommander - What adjustable upper rear arms are they?
    1,873
    That those $80-$95 panhards from suzukisuper? Any good?
    Melb
    832
    Thanks mate - $70 cheaper than whiteline.
    Heyfield
    165
    So just wasted another day on this thing. Attempted to get the front suspension together. Bolted one side up and ran into a serious issue straight away. The balljoint was binding... Worked around it, but ended up running 0 camber. Any negative and it would bind.
    The issue was simple, here is the silvia lca with balljoint sitting about middle of its travel, and commodore lca with silvia balljoint at full travel
    And here is the dodgy drifters solution. V2 lca is 25mm longer at the top and 40mm longer at the bottom
    This stopped the binding in the balljoint, and gave me about -3.5 degrees camber. But the tierod end is now hitting the caster arm nut, limiting steering lock. Lame.
    Now onto V3 lca. This one is 55/75mm longer. It fixed all previous issues, plenty of lock and -6.5 degrees camber (yay) but created another. Because od the curve of the lca the wheel is now hard against the front of the guard. The extension now needs 10mm taken out of the rear to centre the wheel. Another days issue. Also needs to be raised a heap.
    So yeah. Surprised the wheels fit (ish)
    17x9 +22 rpf1 with 215/45 tyres
    Heyfield
    165
    Allrighty, got my lower control arms sorted. Pie cut 10mm off the rear side. The wheel sits pretty good and the tierod end doesn't fowl on anything. Pretty happy with the amount of lock it has now.
    Also had a bit of time to get the engine mount adapters made and tacked in. I used r31 mounts because they are more simple to use than the sr ones. I ended up moving the engine forward 25mm compared to the previous post. Gave more room for the exhaust and the shifter hole doesn't need to be made bigger.
    And a quick test fit of the radiator/intercooler setup
    Also chasing some rear wheels, either 17x9 +45ish or 17x9.5 +50ish, can be either 5x120 or 5x114.3
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    2,410
    this rules
    Heyfield
    165
    Thanks man.
    Been finding it tough to get time to work on this. Made a gearbox mount. 20x20 box welded together to make 20x40 'rhs' just because i had the scrap steel already.
    Anyone know how far you can pull the rear guard on these? Is 15mm going to be a pain in the ass?
    1,873
    Inside the arch is quite strong could be pain in the arse unless cut some of then will be easy as piss.
    Cant see it being difficult for you.
    let me tighten ya nuts wagoner's Avatar
    Jan 2009
    South of Radelaide
    905
    fucking gold, you're going to upset a lot of people with this!
    '71 BMW 2002 - restoration
    '14 Colorado 4x4 dual cab - reliability
    Quote Originally Posted by Marv
    my cuts look like they're done by Michael J Fox using a grinder on the end of a pool noodle
    Melb
    832
    Any updates on this one?
    Heyfield
    165
    Stalled hard, got a job further away and bloke across the road bought the engine and box ....
    1,873
    Was it you that knew where to get tie rod extenders?
    To correct steering when cunts 40mm chassis spacers in commonwhores.
    9,991
    Not sure how I missed this, seriously cool backyard fab. I hate SR swaps with a passion but I don't hate this because I know commodore flops will lose their minds when it sees the track. Get back into!
    Heyfield
    165
    Can you repeat the question? not sure what you are getting at? all performance garage in QLD does some bits like that for commodores
    Heyfield
    165
    Cheers mate, i still have this: http://www.performanceforums.com/for...nd-t56-package
    but also been playing with my BA XR6T ute, will probs have a skid in that
    1,873
    Thought I'd seen one of your posts somewhere that their were adjustable height tie rod ends for commodores like some drift cars have?
    Looking into chassis spacers that raise body 40mm but looking for a fix to bumpsteer issue for commonwhore.
