Results 1 to 19 of 19
Thread: turbo changes and vic roadworthy's
    12,877
    hey guys, turbo's on my GTR are toast. was hoping to convert to a single anyways, but being unreg'd, ill have to get a roadie.
    spoke to my usual roadworthy guy, and he said straight out no way. so that was the end of that.
    however i was reading the NCOP rules, and they reckon you can change turbo's up to 20% bigger without re certification.
    so does anyone know what the go is?
    TIA
    5,443
    Surely some acl heat sheilding would avoid the roadie guy even knowing the single was there?
    Daily: Honda Civic EK1 Hatch
    6,130
    TIA
    it looks like the 20% applies to power output, not turbo size (no idea how you would determine that anyway. weight? how many nokias you can fit in the inducer?) and that might cause you problems as an RB26 puts out more than 120% of its rated power from the factory.
    what state are you in? that's probably more relevant than the NCOP. I don't have any solid experience but from NCOP https://infrastructure.gov.au/roads/...jan2011_v3.pdf page 31 and 31
    I've smalltexted the bits that don't apply to your case, but the two normaltext examples still need LA1 or LA2 certification.
    The following are the options for certifying turbocharger and supercharger installations:
     A turbocharger (or supercharger) installation does not require certification, if the
    installation is available as an option from the original vehicle manufacturer. All vehicle
    components that were supplied by the manufacturer as part of the original specification
    for the turbocharged vehicle must also be fitted.
    A turbocharger (or supercharger) installation can be performed under Code LA1 only if
    the original engine was supplied with a turbocharged option and a non original equipment
    turbocharger (or supercharger) is fitted that does not increase the original most powerful
    engine power output by more than 20%.
    A non original equipment engine with its turbocharger/supercharger may be installed
    under Code LA1 provided the power output is not 20% more than the most powerful
    optional engine offered by the manufacturer for that vehicle model.
     A turbocharger (or supercharger) installation can be performed under Code LA2 only if
    turbocharger (or supercharger) is fitted that increases the original most powerful engine
    A non original engine with its turbocharger/supercharger may be installed under Code
    LA2 if the power output is 20% more than the most powerful optional engine offered by
    All other turbocharger and supercharger installations will require certification under Code LA3.
    also going from twins to a single will mean you have to comply with
    When exhaust systems are modified, proof of compliance with the relevant ADR or in-service
    vehicle rule is required (refer to Code LT4 - Noise Emissions Test in Section LT Test Procedures).
    toast as in fucked or don't work very good? i'd say the easy option would be zip it together as per factor and then make sure you don't fit a single after it is registered.
    12,877
    nah, they be fucked. hopefully i can piece one together out of the 2 and use it on my rolla later.
    well my plan was to jew out and make my own manifold, and use an FG falcon turbo.
    so 206kw to 235kw (tell the cunts its a BA turbo lol) = 114%
    factory turbo's are worth lizard tanks. might have to go that way fro rwc then change again later.. but what a fuck around!
    12,877
    probably get away with it if it was a GTST. but because fucking complicated TT enginebay, its real obvious going single.. especially since theres no other option than go high mount.
    7,758
    Just go to kmart place to get rwc. In and out 30mins
    Registered User Peter UC's Avatar
    Eastern subs Melbourne
    217
    I was going suggest something like above, go elsewhere. I had no problems with the Torana that has many mods, some legal, some should have an engineers for and they didn't care.
    I did tell them it was for club permits so they may have been more lenient
    Jun 2007
    743
    Ebay turbo rebuild kit for the T28's, cheap and easy.
    12,877
    they are trust t517z's. so fairly average turbo's in the first place, and the impellor is fucked on the front turbo (havent got to the rear yet)
    so imho its the perfect opportunity to get something modern, if i can pass the RWC dilemma.
    ill have an ask around. been 6 years since i was in the trade. hopefully i can find a lenient contact round here.
    Pollitically incorrect
    Aug 2007
    7,658
    x2 for kmart auto.
    Dr Hoon
    12,877
    yeah i get what you guys are saying. look for young fucks that barely know what a GTR bay looks like.
    there is one Kmart tyre and auto in bendi lol. not sure if they do roadies.. but i can guarantee it will end up on its roof on the test drive!
    might have to pop in and ask them
    Registered User vlsv88's Avatar
    Aug 2017
    68
    Thought I'd add my 2c here. Larger turbo's technically aren't a roadworthy issue. They're an epa issue which can become an engineering problem for you. Find a roadworthy tester that will pass the car on the fact that it passes roadworthy requirements (noise, height, safety items etc) then go to a quiet VicRoads place to play it safe.
    2 weeks ago I drove through a VL with a 6boost high mounted GT42, big plenum and all the associated gear. VicRoads didn't look twice. Just checked the engine number and that was it.
    Melbourne, Aust
    604
    Just buy some -8's or something and be done?
    CISCOKIDS
    The Gentlemen's Club
    Midnight Rocker
    Old Pac
    6,833
    Quote Originally Posted by vlsv88 View Post
    Im in NSW, but had a similar experience, blue slip (which is for NSW unregistered cars, so the more thorough inspection) didnt give a fuck about a big single, rosejointed suspension and stuff like that, just had to quieten it down and have a closed intake.
    1,348
    One of those things in Vic, you may get lucky but if you get the wrong idiot at Vicroads they can bend you over.
    I had a huge argument with a young head wobbler who inspected my old dr30. He claimed it couldn't be rwc because it didn't have a crash pad on the factory steering wheel.
    Then he leant on the exhaust manifold while looking for the engine number. While they tended to his burns his supervisor quickly checked the numbers and got me my plates
    12,877
    Vicroads, im not worried about.
    Roadworthy guys that won't pick the shit out of it are.
    Not so much of a problem yet, as after nearly 8 months im still pulling the shitter apart lol.
    7,758
    I know rwc guys in Narre Warren who are flexible. Might be far for you
    Jan 2013
    3,788
    if your fully stuffed i can do it at work. but im in morwell.
    12,877
    Thanks heaps mate, location is no worries. Not sure which way i go with it yet, but if i go single ill let ya know for sure!
