Results 31 to 48 of 48
Thread: HDJ80R Landcruiser 1HD-T rebuild:
    Registered User bigshipengine.jpg's Avatar
    Wollongong
    8,159
    Is the 400k thing the same for 1HDFTE's as well? See plenty with 500k on them etc. Are they all time bombs waiting to let go?
    If so the 25k buy in is a bit rich.
    It Places the lotion in the basket!
    is unplugging your matrix aaron_hogan's Avatar
    Oct 2002
    Thornbury Melbourne
    1,265
    The 1hdfte's seem to last just fine. Having said that the bottom end is the same as 1hdt anyway. For me it comes down to maintenance. eg: the crank in mine was fine and the bearings were still looking healthy. Fuck knows why the old boy's one let go.
    1,507
    My brother has an FTE with about 520k on the clock, never opened. His mate has one at about 680k, also never opened. I think they are a proven good thing.
    1,902
    what are the EGT's like with no intercooler?
    Wollongong
    8,159
    Thanks for that about the FTE's
    Oct 2002
    Thornbury Melbourne
    1,265
    Quote Originally Posted by TRD-MX62 View Post
    Ceramic coated hi-flowed CT26. 12psi wastegate. Redarc EGT guage. tapped into the centre of the manifold pre-turbo.
    Just cruising at 100kmh sits on 400deg. If you absolutely nail it the warning beeper will go off as it nudges 700 deg but comes back down right away.
    To me that says not enough fuel. Was told not to worry too much as its not driven on the limit. Also its only done a touch under 5,000km so far. Tune will come soon.
    Intercooler will be good to sort out but its not #1 on the list (doing my swivel hubs and diff build is).
    Quote Originally Posted by myliberty
    My car is a broken heap of shit too, so we have something in common.
    13's for $1300: RX4/929 nugget.
    Oct 2002
    Thornbury Melbourne
    1,265
    Had a catastrophic failure of the RHF inner wheel bearing. This led to loss of brakes, red hot grease fire and destruction of the CV.
    Frustrating because I had just about all the parts for a total front diff and brake rebuild except the CV's and was planning on doing this mid January.
    Now I have no choice but to get really stuck into it.
    As the bus is a 1991 GXL it came with 15" rims. I bought the later model larger slotted and dimpled rotors and Brembo pads in preparation. Also got braided lines. Should pull up really nice. Contemplating installing an E-locker. Already have new CW&P, drive flanges, bearing kit, swivel kit. Big job and not really looking forward to it tbh.
    Any brands of CV's to avoid? The hotness used to be HDK branded cv's. $180 each or $220 each for the greasable version.
    Cairns
    578
    You will need the calipers to go with the bigger discs, if you dont already have them.
    Oct 2002
    Thornbury Melbourne
    1,265
    Quote Originally Posted by T T Celica View Post
    Yep, already got them. The brake upgrade has been on the cards for ages. I reckon it's probably worth putting a seal kit through them at the very least if not a full reco.
    I'm having trouble finding HDK cv's for the later 80's (as the spline area is longer). They advised 100/105 series have a different spline on the end to an 80. Looks like I'm going to get Terrain Tamer and be done with it.
    I did get new spindles - the later type with roller bearing instead of a bronze bush. $60 ea. Obviously non-genuine.
    Have cleaned up the spare hubs, knocked the cones out and packed the wheel bearings so those are ready to go. Next thing is to get the knuckles off and drop them off for a soak in the hot tank.
    Cairns
    578
    Terrain tamers are fine. I did twist the CV /drive spline on one about 5 yrs ago, but backing a 3000kg caravan up an embankment puts a fair bit of strain on the pointy end of driveline bits. It was replaced under warranty too!! Definately rebuild the calipers, cheap piece of mind really
    1,902
    would definitely put some kind of locker or LSD in the front depending on if you have free wheel hubs or not, full time or part-time Transfer case?
    Oct 2002
    Thornbury Melbourne
    1,265
    It's full time. I actually have a rebuilt Hilux LSD sitting here from another project and was told (by Terrain Tamer dude) not to use that in the front of the 80 as it will affect steering initially and then wear out real quick.
    Love to get the e-locker but I think the budget just won't stretch at the moment. I hardly drive off road anyway. Really just want to eliminate the classic driveline clunk.
    1,507
    Trutrack will be good in the front. I have one to go in my Rangie when I get the time and motivation.
    \_(ツ)_/ burn is weird's Avatar
    1,931
    a good torsen in there will do the job and you won't notice it at all under everyday driving.
    applying a bit of brake pressure if you cock a wheel keeps you moving along.
    Not a Fan. Agent86's Avatar
    Melbourne,Vic
    730
    Quote Originally Posted by aaron_hogan View Post
    To me that says not enough fuel. .
    High EGT is not enough air. feed it a bit more boost
    Oct 2002
    Thornbury Melbourne
    1,265
    YAY! After rebuilding the swivels with new CV's and flanges the dreaded clunk is gone. The brakes are working like a treat. I rebuilt my rear hubs too.
    Next up will be tailshaft uni's and a wheel alignment.
    Registered User jimmyg's Avatar
    Mar 2009
    Bendigo, Vic
    1,707
    Be like a new car.
    Mmmmmmmmm beer.
    You had one fucking job, Imran. One. Now look, there's Flibberty Gibbets all up in here, seeing straight through your ruse. One. Fucking. Job!
    Oct 2002
    Thornbury Melbourne
    1,265
    Quote Originally Posted by jimmyg View Post
    Be like a new car.
    Mechanically yeah, paint wise it has the dreaded clear coat peel.
    Fucked up one of the universal joints now I need to wait for the replacement to arrive. Let that be a lesson to use a g-clamp or vice to squeeze the caps in. Tapped it with a hammer and a couple of needle rollers fell over inside. When it wouldn't go home of course I hammered it harder. Only twigged to my mistake the next day.
    Climbed under and drained the diff oil only to find the front had about 400ml in it when it's meant to be like 2.5L. Filled her up with Penrite's finest.
    Part way through installing the Redarc BCDC1225. I already have brand new SSB agm batteries and a Redarc Sbi212 (the big 200A version). Picked up a Redarc Manager 30 for the van on the cheap too.
    Getting closer to finished.
