Results 1 to 17 of 17
Thread: cheap not completely shit OBD2 readers, OBDII readers and toyota??
    5,955
    background: just bought a 2005 corolla (#humblepovertybrag) check engine light comes on and stays on occasionally, internet says it could be a few things.
    I bought a cheap as fuck chinese bluetooth OBD2 reader aw hile ago, has worked fine with a few cars when my phone plays nice, but it only seems to be half working with my corolla, it will report battery voltage but says there are no DTCs and won't report VIN or serial numbers or anything.
    my understanding of OBD2 is it should work the same for all cars that support it, so not sure what is going on. I asked the mechanic to read the codes and record them while it was in for a RWC, "yeah mate I cleared the codes and the check engine light came back on again" thanks mate.
    I have been thinking of buying a wired/standalone reader like https://www.aliexpress.com/item/Free...999.264.BrDfcE which doesn't need a phone and should work a bit quicker, wondering if I will have any more luck with it.
    Any good cheap OBDII readers people have used? any shit ones?
    Founder Nick's Avatar
    New New Zealand
    4,487
    I had issues with my IS300 and even expensive ODB2 reader link the ODB2Link I got. Didn't work, wouldn't connect to the ECU. The yanks didn't have an issue. Found out that the Australian IS300 uses a Japanese ECU so isn't fully ODB2 compliant.
    Long story short, used the following AT commands to get it working.
    ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100
    Give it a go, see if it is the same on the Corolla ecu.
    New New Zealand
    4,487
    PS, Toyota also use a "TechStream" cable, you can get these cheap off Fleabay too. Can do a few more things like reprogramming key fobs etc.
    5,955
    Quote Originally Posted by Nick View Post
    i don't know what that means. think i'm going to buy the standalone scanner anyway and add it to my collection of cheap but usefull tools that may never get used, i;m hoping that because it is mass produced Chinese junk that it will just work with everything.
    mine was build in south africa so maybe it isn't OBD2 compliant for..... different reasons.
    Lapping freo.
    3,507
    Sounds about right. 2006 is when obd2 became mandatory, older Toyota's don't. Which is odd as Toyota USA had the very same cars and engines with obd2 since the 90s!
    5,955
    cheers
    http://www.ebay.com.au/itm/16-Pin-Mi...8AAOSw4GVYGu6y
    $20 overnight from Hong Kong with software, sounds good.
    5,955
    ok stupid question on the techstream:
    do I want: IM, GA, GU, JK, P5, BU or are these letters meaningless?
    Supraholic
    Dec 2009
    146
    In the TorquePro app on Android you need to add that string for it to read, had to the same thing for the Supra to use the ELM427 OBD2 reader off eBay. Works quite well IMO.
    Melbourne, Aust
    527
    I wonder if that cable will work with this.
    http://www.microsofttranslator.com/b...%2Fmyengine%2F
    Russian program, built around JZ engines that has the ability to read knock and so on.
    CISCOKIDS
    The Gentlemen's Club
    Midnight Rocker
    5,955
    cheers for all the suggestions, was about to pay for torquepro and hope there was a spot to type gibberish into it but figured there must be a bunch of "camry owners" who are IT literate and aren't afraid to save a dollar so just searched play store for "toyota OBD2" and downloaded a free app called "ELMScan Toyota" after a tiny bit of bluetooth nonsense it connected, and had one DTC: P1035 - Heated oxygen sensor (HO2S) 1, bank 1, heater control circuit malfunction
    guessing the most likely cause of this is the O2 sensor is fucked, might look at where it is, how much they are and replace it one day, but it's a failure I'm not too worried about. might explain why some of the old sparkplugs were quite sooty??
    Jan 2013
    3,418
    change plugs and clean the maf.
    I like cars. Cars are cool.
    Always looking for Triumph 2000 and 2500 parts and cars.
    5,955
    did oil, plugs and air filter just after I bought it. might do the MAF, have needed to buy a can of electrical shit cleaner for a while (fuck, MAF cleaner is 27 bucks a can? hmmm.)
    super non genuine oxy sensor is ~50 bucks, and looks pretty easy to work out if the sensor or the heating circuit is stuffed.
    Jan 2013
    3,418
    toyotas have a habit of throwing o2 sensor codes when the fault is upstream. though at 50 bux, it would be rude not to i guess.
    5,955
    ah got ya now, will have a look at the hotwire if testing the O2 sensor and circuit doesn't show any problems.
    14,742
    Just use contact cleaner. Will be dirt cheap at jaycar.
    Sonova Beach
    6,073
    If it's throwing heater circuit codes though, the chances are it's fucked.
    If it's throwing range errors, then yeah maybe look at vacuum leaks, etc.
    Late '90s/early '00s VWs are the same.
    5,955
    Quote Originally Posted by Mr Flibberty Gibbets View Post
    the heater circuit or sensor? I had a poke around to see how hard it would be to get a multimeter somewhere to work out which is fucked, but it's in enough of a prick of a spot that I think i'll just throw in a new $40 ebay sensor and hope that fixes it.
