Page 3 of 3 FirstFirst 123
Results 61 to 77 of 77
Thread: Big Fuckoff Engine - 2017 Dyna Low Rider S (FXDLS)
  1. #61
    Registered User TRH510's Avatar
    266
    Quote Originally Posted by brasher View Post
    Just ordered a set of Ohlins HD 215's. This one hurt the bank account.
    Will be custom built by motorcycle metal in the states, he is considered the Ohlins guru so should be in good hands.
    For ohlins nerds the build will be considered a custom with designation "S36PR1C1LB"
    S - Single tube Piston diameter
    36 - Piston diameter: 36 mm
    P - Monotube high pressure gas type of shock absorber with external “piggy back” reservoir.
    R1- Adjustable rebound damping on single tube shocks. Adjuster wheel above the end eye.
    C1 - Adjustable compression damping. Adjuster wheel or slot on the reservoir.
    L - Adjustable length. (+-10mm from 340mm)
    B - Integrated hydraulic spring preload adjuster. Adjuster wheel or hexagon on the adjuster.
    I really wanted to do the NIX22 Fork cartridge at the same time but simply cant afford it.
    Porn
    Sent from my Nexus 5X using Tapatalk
  2. #62
    You 'gon take that deeuck fat910's Avatar
    Apr 2008
    Sadstone
    1,304
    Oh, you tight ass! Should look and perform mint.
    They say i know fuck nothing, but i know fuck all!
  3. #63
    Registered User MVLUV's Avatar
    Feb 2012
    Brisneyland Aus
    121
    I like where this is going.
  4. #64
    whaddayatalkinabeet brasher's Avatar
    Feb 2006
    4,784
    Yep should be something out of the ordinary. A race Harley of sorts.
  5. #65
    8,000
    Fark, would be a pretty pricey little upgrade! Guessing more than the air ride on the last one?
  6. #66
    14,704
    They work pretty well.
  7. #67
    8,000
    No arguments there.
    Sent from my SM-G950F using Tapatalk
  8. #68
    Feb 2006
    4,784
    Yeah like triple the price lol.
    At least for a sportsbike you only need to buy one shock.
  9. #69
    14,704
    The Kat has 2 as well... I'm a tightarse and bought second hand out of Japan - admittedly they're slightly older/lower spec in that they have a gold zinc'd steel body rather than alloy, but otherwise the similar spec.
  10. #70
    Feb 2006
    4,784
    I got emailed today if I wanted to get the shafts done in carbon nitride. For a paltry $500usd a shock lol.
    I said no funnily enough.
    I think the end result will be worth it. Problem is it will amplify how shit the forks will be once the rear is sorted. Because they are cartridge style can't just jam preload adjusters in these. But they are too soft under brakes. Upsets the geometry.
  11. #71
    14,704
    Pull forks, ship to Suspensionsmith in Canberra. He's excellent, and not afraid of doing oddball stuff.
  12. #72
    Feb 2006
    4,784
    I spoke to terry hay about what I can do with the front and he said best bet is bite the bullet and do the ohlins cartridge and do it right first time sort of thing. I hate it when people make sense and it's not what I want to hear lol.
    could try the old heavier oil trick first and see how that goes but that's a bandaid solution in itself.
  13. #73
    14,704
    Springs and a revalve will set you back ~ 1/3rd to 1/4 of what the Cart kit will cost. Give Laurie (Suspensionsmith) a call - he has a different attitude to the suspension guys I've encountered in the past...
  14. #74
    Feb 2006
    4,784
    it already has a cartridge in it, Harley to their credit thought they were doing well with this fork, and it is pretty good until you weigh more than 90kg or ride it hard.
    I'll give him a yell and see what he thinks I can do. I am actually going to Goulburn on Sat morning so that might work out well.
  15. #75
    Feb 2006
    4,784
    Santa came early. These are trick. Haven't had a chance to test them yet.
  16. #76
    Feb 2006
    4,784
  17. #77
    Feb 2006
    4,784
    First ride done just to check alignment and nothing falls off. Was unbelievably good. Set the sag as reccomended and took off. Couldn't even feel the dish driveway when leaving it was so plush.
    Felt immediately higher and tip in was so much quicker, it held its line perfect and any road imperfections didn't bother it at all.
    I sped up the rebound and put 2 clicks of compression after stopping to check the bolts and belt tension and was met with a lot livelier bike but not something you could ride on a daily basis. Will be a good initial setting for some natio runs but waiting for double demerits to piss off before giving it the ultimate test.
    Extremely impressed but you should be for the price.
