Page 4 of 4 FirstFirst 1234
Results 91 to 115 of 115
Thread: 13's for $1300 Crimson Tide
    Brisbane, North side
    1,652
    So I fixed up wiring and checked fuses. Engine cranks and fuel pump runs but it will not start. Cannot find a fuse on the computer itself. Will check fuel and spark later today. Any ideas?
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,608
    Does the fuel pump prime without the engine cranking? The oil pressure switch will turn on the pump when there is pressure, regardless of whether there is an ECU or not.
    1,652
    No. It won't run until I started cranking, thought that was weird
    Sydney Traffic
    1,608
    Sounds like the ECU isn't getting what it needs. Where ddi you cut the loom? From memory there's inputs into the engine wiring from the dash area near the brake booster. And the speedo needs to be connected or you'll get a VSS circuit fault (which will probably just make it stall at traffic lights)
    1,652
    Under dash above centre console
    1,652
    Sorted. I had also disconnected some secururity system so was acting as a kill switch
    10,262
    so skids?
    1,924
    Ah the ol' mongoose anti-theft module..surprised it even worked.
    Going to holesaw some speedholes into that thing?
    1,652
    so skids?
    Page 2
    Sydney Traffic
    1,608
    I wonder if a new serpentine belt arangement could add some lightness.
    1,652
    I have been trying to figure this out myself. Maybe by relocating the alternator to where thr AC compressor is and putting it on an adjustable bracket
    ACT Now!
    27,019
    I found a belt that would fit exactly. Iirc I unbolted the alternator, fitted the short belt, then bolted the alt back on. Whatever I did it wasn't complicated.
    1,924
    Non p/steer have different tensioner..was either some povo pack or NZ only cars that got vl manual rack.
    Should be belt diagram in car manual or online.
    Steering will be tad heavy without a pump weight is weight yo'
    2,934
    Don't need power steer going straight. Can the rack
    ACT Now!
    27,019
    Disconnect the ps hoses and swing the rack a few times to clear the oil. It's not as heavy without ps as you'd think. Barely even noticed it wasn't there tbh.
    I'll see if I can find a photo when I get home.
    2,934
    For extra inspiration do some googling on the GM Motorsport cars setting LSJuan times in the mid 2000s. You will see how much can be cut out of a commodore without caring
    1,652
    Any SE QLD boys looking for a catch up or beer, going to work on exhaust side of turbo fri and sat. also can do some free revs and burnouts followed by and bon fire and or bbq let me know if keen
    ACT Now!
    27,019
    And then?
    Or did it suffer SEQ Syndrome and no one turned up?
    1,652
    We just collectively understood day light savings, so now can divert mental power back towards this cunt
    2,934
    My knee grow
    10,262
    Quote Originally Posted by Panda I give no fuck View Post
    If this is still a thing, in. Happy to swing spanners, point and drink available booze to help/hinder the process as required.
    Registered User E-Z's Avatar
    3,777
    yeah we should do a weekend
    caprice nugget.
    1,652
    Yep still a thing. Got stuck back into it on the weekend. Super keen for a weekend on it with beers and shit talk.
    Canberra Nth
    2,966
    Live stream test skids
    - PSN: rotacoupe
    Sep 2017
    Brissy
    3
    I'm happy to come give you a hand mate, I need to get an inside look at my competition this year anyways
