Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 61 to 90 of 278
Thread: VH Barradore
    Registered User Dimi's Avatar
    Sep 2012
    1,628
    Stop over complicating it for the poor cunt. Pull the TB apart, weld a 90* section of tight doughnut to it clocked in the right direction. put it back together, first joint will be a straight silicone. Will take less than 20mins to fix.
    Post it to me with a dan murphy gift card and ill do it for you
    23,479
    This is my proposed solution. I thought I had some 12mm alloy plate but I doesn't.
    Sep 2012
    1,628
    Perfectly fine.
    Slightly more fuck around having to make flanges. Or go poverty spec and cut the flange off the plenum weld elbow to the plenum and weld flange to the elbow.
    Those cast elbows and pretty much all cast aluminium welds are poo to weld and look poo compared to nice fresh 6k alloy.
    Struggletown
    6,580
    Isn't there some plate over in the corner behind the small block chev?
    Hold it flat cunt
    23,479
    Dimi: I've got one flange bolted to the manifold in that pic (it's actually a BA to FG adapter). Yeah, I didn't expect the China elbow to weld real well
    I've got some 10mm plate
    Sep 2012
    1,628
    Sorry mate I missed that
    23,479
    10mm do?
    Sep 2012
    1,628
    10mm do?
    yeah will be ok, bolt it to the bench when welding so it doesn't warp like a pretzel
    23,479
    I'll see if I can scam some 12mm. Welding will be some other cunts problem
    23,479
    Doing the fuel system at the moment. I only need the one way valve on the second 044, yeah? The Haltech will bring that on at, say, 75% throttle
    caibstastic!!1 caibs's Avatar
    perth
    260
    in regard to swapping the bf alternator for a ba unit, is it as simple as just swapping them over then wiring power, sense and then alt light to the dash? or does the ecu recognise that its not there
    some fucken busted ass peice of shit
    23,479
    Don't know, I'm running Haltech ecu
    perth
    260
    ahh yep. is gonna be an awesome rig when done. which wont be far off at your rate of progress
    Sep 2005
    NSW
    234
    Quote Originally Posted by caibs View Post
    14 Street Triple R
    23,479
    Made up some brackets to hold the surge tank
    Surge mounted
    Out with the lameness in with the hotness
    How the fuck do you break the core free of the exhaust housing?
    7,473
    Wouldn't be my choice of spot. If pinion gear breaks (common occurrence) tail shaft will take that out
    23,479
    Yep, it's a concern
    23,479
    Thanks everyone for your help, I sorted it
    Drain done
    Need to get some more silicon and alloy bends
    23,479
    Got a new rear brake line made up today, scored some 12mm plate, got some fittings and hose. Ordered silicon and alloy bends off the eBay. Started on battery in boot
    9,241
    A big shitty illegal fuel cell in the boot is way better idea chuck.
    23,479
    Yeah I'm starting to agree
    1,924
    Mount surge tank in boot.
    Drill out original sender fuel pickup line to 3/8 or 1/2 with new sock filter...just make sure it goes closer to bottom of tank unlike factory carb tank 7mm pickup line that sits too high..lift pump can mount in crevice next to sender unit.
    If efi tank can weld deeper swirlpot/tank sump underneath..toss plastic shit thing inside & bend up return line to top of tank so it's no longer restriction.
    Fuck oath after all the fucking around with factory tanks required those fuel cell set ups look enticing.
    9,241
    I wasn't being serious. Fuel cells are a shit idea for a street car.
    23,479
    Yeah, dunno. I don't like the surge next to the spinny thing either but :shrugs:
    Maybe get a smaller fuel tank made to take up 2/3 the room and run the surge in the remaining room
    Dunno
    Struggletown
    6,580
    Why are they so horrible? Aside from taking up valuable dead hooker space
    Hold it flat cunt
    1,924
    Efi Hardware intank kit would be better than getting another tank made but already got f/pumps.
    Shitney
    1,031
    Yup - I put a VE fuel pot with EFI Hardware weld in kit into a stock HQ tank and it worked perfectly, 1 x 60psi line to the rails and life was good.
    Jun 2009
    1,138
    Why is everyone hooked on the "must have surge tank" in this day and age. I dont run one and have no problems with fuel surge, I run a custom tank with pickups from the bottom of the tank. Its nothing elaborate but works
    23,479
    Yeah, if I can't find somewhere better for the surge, that's what I'll be doing
    23,479
    Hmmmm, thoughts?
    Now it's a bit of a crash safety issue
    Obviously I'd trim the bottom of mount
