Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 91 to 120 of 278
Thread: VH Barradore
    Registered User peal's Avatar
    3,239
    nah.
    204
    Hmmmm, thoughts?
    Now it's a bit of a crash safety issue
    Obviously I'd trim the bottom of mount
    Seems a bit overkill for a washer fluid bottle?
    Means well but is skittled
    23,485
    This is where the pumps would end up
    The surge I was using ends up pressed against the front bumper to clear lol
    23,485
    Yeah that would be neater but another couple of thousand and won't support the power my 044's will
    23,485
    Holesawing 12mm alloy plate, slow and lubed or ???
    7,474
    Wood blade dry jigsaw. Piece of piss
    23,485
    3 inch won't be too tight for a jigsaw in 12mm?
    Shitney
    1,031
    Nah should be ok with a wood or alloy blade, just rough it out undersize and finish it with a half round file or die grinder. If you go the holesaw route, just do it in a drill press and use a bit of WD40 so it doesn't chatter.
    7,474
    I did the engine 10mm alloy plate on my vk with wood blade. Cut it like butter
    Defective Faux Forg's Avatar
    Sydney Traffic
    1,608
    Piece of cake in your lathe too.
    on hoes? yohoes's Avatar
    3,069
    I wasn't being serious. Fuel cells are a shit idea for a street car.
    Whys that?
    12,371
    Holesaw is fine, use wd40 or kerosene, run it slow, clear the chips out manually
    12,371
    Why is everyone hooked on the "must have surge tank" in this day and age. I dont run one and have no problems with fuel surge, I run a custom tank with pickups from the bottom of the tank. Its nothing elaborate but works
    Cause life is too short to chase painful fuel supply problems when a half decent surge tank eliminates them.
    3,069
    Moving the surge from next to the tailshaft to the front bumper of the car.. surely youre not serious?
    Put it in the boot
    7,474
    Then car car smells of fumes. Unless you spend 11ty billion dollars on teflon hose and fittings.
    Another option is get a small 10 litre cell with inbuilt a1000 but thats a bit pricey as well
    5,830
    Hows that tank gunna hold up in the event of an accident ?
    1,055
    What does the standard tank look like? How is the stock pump mounted inside the tank?
    7,474
    If it is an original vh tank it is carb so nothing. If it is a later efi tank the are mounted on the front face, towards diff
    Feb 2014
    Singleton, Aus
    214
    why dont you leave it where it was originally and make a tailshaft loop to protect it in event of failure, probably a good idea to have one anyway...
    3,069
    Spend a little money.. or dramatically increase chances of car on fire
    Lol tough choice
    7,474
    Its only fire
    3,069
    Fire extinguisher is definitely cheaper than Speedflow shit
    8,874
    Quote Originally Posted by marshy View Post
    Would need one anyway for the strip I would have thought.
    Alternative, stick surge pump in spare wheel well, make sealed lid for top. How much clearance is there above/behind the diff in front of the fuel tank? Iirc it might be abit tight but if it fits I'd do that.
    Jun 2007
    Approaching Uranus
    506
    Will an efi fuel tank from a VL fit in and be suitable?
    1,924
    Efi tanks aren't much chop on these either...sorting this stuff now on my headfuck commodore tank
    Just add new 1/2 or 3/8 pickup line deeper into tank with swirl pot welded underneath tank or boganised tank sump.
    Neatest way efi hardware intank with new pump & save setup you have for landy or another project.
    23,485
    Apparently, I am
    Spun it slow (220rpm) and it cut through it nice
    Hopefully get it welded up tomorrow
    Jun 2009
    1,138
    Not in my case. Got ride of a putrid smell in the cabin, eliminated extra hoses, cut out extra wiring, cut extra fuses, and cleaned up the whole system.
    Surge tanks are not the be all of fuel systems. But then again what the fuck would I know
    23,485
    Sorry forgot to reply
    It's further back than the radiator so hopefully the spilled coolant will help extinguish the fire
    Quote Originally Posted by [RX3] View Post
    As stated, it's at the front of the tank
    It was near the rear of the back tailshaft so nowhere near where a typical loop would be
    Quote Originally Posted by richzx View Post
    It has a VN fuel tank in it with a walbro pump
    23,485
    Made up a fixture to hold the tb to the flange while I drill/tap the 4 holes. Also bought some deep drill bits
    Radius of the alloy bend is too gradual to work so will need to run two silicon bends. Changed the hotside too as the gtx starts out at 2.5 inch
