Results 31 to 52 of 52
Thread: Honda Z50A Monkey Bike
    VIC
    1,263
    Original cases. All Takegawa bits - DOHC 4 valve 124cc, 5 speed, dry clutch.
    At the end of the day, it had everything done, but wasn't as 'fun' as a simple cheap build.
    Good luck with your A build. The headlight bucket and side cover you have are two of the hard bits to get. Find the original tail light bracket and you're set.
    Look behind you... Milkman Don's Avatar
    look behind you
    2,972
    Quote Originally Posted by QABB View Post
    Where did you ride it? When I threw money on minis we raced mini motard at lakeside or gambled getting chased by the rozzers in the bush
    I agree with Rdyno
    Thank you for smoking <---cop's Avatar
    Nov 2007
    6,272
    Quote Originally Posted by Milkman Don View Post
    Will this project get finished?
    Awesome keeping from the olds, so much stuff gets tipped over the years without thought. I've seen a few builds of these and like QABB says above they are a money vortex.
    It will be finished. I've had it too long not to.
    Plus my kid already is asking why "his bike" has taken longer than 2 weekends to finish.
    Nov 2007
    6,272
    I'd love a crate Takegawa engine but that's never going to happen.
    I'll either rebuild this with a 88cc kit and just ride it or stick a Daytona 125 or Daytona 150 in it.
    Either way I think I'll get a bracket welded on for a rear brake pedal now before paint in case I need to run a clutch lever.
    Nov 2007
    6,272
    Other random things to bring the thread up to date.
    The old wheels were trashed. They are a 2 half design and were rusted solidly together.
    I couldn't even get the other wheel apart.
    Nice new OEM wheels. I'm sticking with original 8" rims but will run road tyres.
    Engine dress up things, new oil seals, screws, etc etc.
    I'll have to refinish rather than replace the clutch cover as the new ones don't have the same engravings as the original.
    I've got giant ziplock bags full of parts everywhere. One for each area of the bike.
    This is the bag for the forks. Every part will be brand new except the lower legs that I will have to get rechromed.
    I think I'll pick up some JZ sliders as well as they tighten up any play in the front end.
    New OEM seat.
    Chain guard is going to need some work but I'll straighten it up now so it can go and get rechromed at the same time as the fork lowers.
    I gave the original handlebars a quick clean up.
    Unfortunately one bar has had a bolt welded into the mount at some point in the past.
    I may still splash out on a brand new pair just because.
    Registered User 308hjute's Avatar
    681
    I agree with your young bloke, hurry up and finish it.
    Nov 2007
    6,272
    I need to get some odds and ends like fork legs, chain guards and bearing races chromed. Any recommendations in Brisbane?
    I also want to get the hubs drilled out so I can run larger brake cams from the later model bikes to fit extended brake arms.
    Anyone I can trust to do this? It's a simple drill out but I would have a hard time finding replacement if they aren't done correctly.
    Two years in Lompoc... Lobster's Avatar
    6,189
    Quote Originally Posted by <---cop View Post
    What is taking so long. Don't let the kid down!?!?!?!!1
    CJM 4 Life yo!
    ruddvegas
    10,314
    Heard good things about East Coast Electroplating in Brendale in the past, have not used them myself however. I have a feeling they aren't cheap, but I can't imagine anyone still doing that shit would be.
    Quote Originally Posted by Dimi View Post
    Quote Originally Posted by schnitzelburger View Post
    15,830
    I've got a guy, but he's out at Blacksoil.
    Pics of the job?
    15,830
    Just looking at the pics on the other page - i reckon if you could find another front hub and backing plate you could relatively easily convert to a double sided drum....
    Nov 2007
    6,272
    Quote Originally Posted by Sketchy View Post
    Yeah everyone is crazy expensive. Things like the lower fork legs I've had to buy now because I can get new Honda ones from Japan delivered for half the price of getting a local to rechrome them.
    Pics of the job?
    So the early hardtails like mine run a smaller brake cam than the later bikes.
    Late model on top, early model below.
    Mine haven't arrived yet so I can't measure them.
    If I get the plates drilled to take the bigger cams I can use aftermarket longer and stronger brake arms.
    There's nothing available for the early bikes. Apparently there is enough meat to drill them out.
    The easy way is to swap to the late model plates but they look shit.
    Stock pressed brake arm.
    Takegawa arms to suit the bigger cams.
    I don't think I've ever seen that.
    I'll see how it goes with better shoes and more leverage but I like quirky.
    15,830
    Is the late model brake cams swap a common thing? I'd be concerned about how much boss is left after it's bored.
    Looking at the pics, converting to double sided drum would be a case of a cable splitter (use a Suzuki GT750 unit or early Yam TD/TZ), bore the hub out of one drum and countersink the stud holes, then bolt up with countersunk bolts instead of the normal hex (although, depending on how deep the shoes run, you may be able to use a normal or low height hex head. Would go drum, rim, rim, Drum with hub. I'm assuming the rim halves are the same side to side?
    Nov 2007
    6,272
    Yeah it's a reasonably common thing and a few have done it.
    It does look really close so I'll have to measure it when they turn up. Worse case scenario I go with the ugly plates.
    Yeah rims halves are identical.
    15,830
    Just realised - only issue with a double drum arrangement is that you'd lose the speedo drive - would also have to trim the speedo drive lugs off the hub.
    I could do the machining for the twin drum conversion, but I'd defer the backing plate mods to my mate.
    Nov 2007
    6,272
    There's actually an off the shelf disc brake conversion for them as well that I can head towards later if I want to.
    Here's the better arms on the ugly backing plate option with an 8" rim.
    15,830
    Later backing plate is no doubt stiffer - is it just the raised section between the cam boss and the axle boss that's the ugly bit?
    Nov 2007
    6,272
    Yep, they have just reinforced them and made them stiffer. Otherwise interchangeable.
    Original
    Revised
    Nov 2007
    6,272
    Tank was a bit rusty inside as expected.
    I did the old trick of filling it with vinegar and adding a heap of salt to make a sodium acetate and hydrochloric acid solution and eat the rust.
    Shook, emptied, refilled etc for a week then finally rinsed it out with water and baking soda then flushed with fuel.
    Came up pretty good. I was planning to seal it with Red Kote but then I started stripping the outside of the tank.
    It's a fucking mess.
    Dents and putty everywhere, fibreglassing patches underneath on seams, pin holes, dents.
    Kinda of walked away from it at this point. I'll bare metal it and then see if it's worth saving.
    I don't remember it being repaired like this and wasn't expecting it at all.
    Slanted big_pete's Avatar
    Sep 2003
    Wagga
    7,620
    Holy shit, that looks like it was bombed in WW2
    15,830
    Leave it like that for Ratbike feelz?
    Nov 2007
    6,272
    lol it would be a perfect ratbike tank.
    The last of the bits also turned up for the front end to build it completely from new OEM parts.
    I'll polish up the stem bearing races and see how they look before I think about chroming them.
    I'm trying to dismantle the speedo drive to rebuild it but there is the world tiniest blind brass screw in the aluminum housing and it almost stripped completely the first turn of a screwdriver
