Results 1 to 11 of 11
Thread: turbo oil pressure
    Tamworth NSW
    78
    turbo oil pressure
    I have a GT4202 journal bearing turbo and ever since new I get oil in the outlet of the compressor.
    engine is a 1UZ running 10w40 synthetic oil and can have 100psi of pressure when cold.
    question is can I run a restrictor with a journal bearing turbo or could I try one of the new turbosmart turbo oil pressure regs?
    Sunshine Coast, Qld.
    7,627
    Restrictor.
    Gympie, QLD
    1,957
    Garrett website says it can occur from a restrictive intake also??
    Projects:
    '90 2jz-gte 929
    Tamworth NSW
    78
    thanks I will try a restrictor first, any idea how small to go?
    7,627
    How big is the oil drain and where does it drain back to?
    Tamworth NSW
    78
    speedflow -10 back to the top of the sump above the oil level
    7,627
    What's your breather system like?
    Tamworth NSW
    78
    speedflow -10 from both rocker covers to a catch can with 1 filter on a -10 fitting
    7,627
    1mm is fine for the restrictor, can't see any other reason for it.
    Tamworth NSW
    78
    thanks for your help
    7,627
    The only other thing you could do is check for crankcase pressure under boost. Get and oil cap and tap a thread in it, screw a barb in and connect to boost gauge and go for drive.
