Results 1 to 20 of 20
Thread: Wet ecu - hints or tips ?
    Nov 2006
    Wallsend/NSW/Australia
    1,018
    So, looks like mounting the ecu in the passenger footwell isn't the ideal spot in a convertible that is prone to leaks.....
    My MX5 spat the dummy 2 weeks back (cranked but no spark and injectors not firing), finally got around to looking at it on Sunday. It had water in the footwell, but I didn't realise how much - the "high tide" mark was up past the bottom of the ecu, and the ecu case had water stains. Left it drying till today, and it fired up and seems to be running OK.
    My question is - what to do now ? Should I get the ecu checked out, if so, any suggestions as to who ? Just check the connections ? Any other ideas ?
    Obvious suggestion is to just replace the ecu, but due to having an immobiliser I would need to replace the ecu, immobiliser module, keys and proximity sensor thing in the ignition barrell so I'm keen to do my best to get the old ecu checked out.
    Syd-en-ey
    458
    If it's not a daily driver, i'd open it up and clean it up as much as you can, all the contacts are wires are probably going to be toast at some stage as water would have got into them and that's a bigger problem than an ECU as you don't want to replace the whole loom.
    Not sure who sells it these days (jaycar??) but some form of contact cleaner would be a good start, open it up if you can and clean it out if you can... And then hope. It might work for years... It might not!
    Nov 2006
    1,018
    It is my daily drive-to-work and weekend fun car, but not the main family car. Time to start looking for contact cleaner and cross my fingers......
    Jul 2002
    Brisbane Aust
    1,704
    Yeap, and buy a shit load of rice and sit it inside a bag with it everywhere after you contact clean it. Good luck.
    "And I know that arseholes grow on trees but I'm here to trim the leaves" Peeping Tom, Mike Patton
    5,963
    Soak in metho, or even better isopropyl alcohol. Use a new clean toothbrush to clean away any corrosion, blast dry with compressed air.
    Drill holes in floor so cannot flood again.
    5,099
    Or straight alcohol. Water by itself isn't so bad but that water will be full of yuck which ultimately cause corrosion. That's what you're trying to get out. Get in there with a toothbrush and clean it best you can as well as the terminals on both ECU and wiring harness - particularly since they were on the bottom. The alcohol will evaporate. ECUs sometimes have conformal coatings which is helpful but clearly if it didn't work at least for a bit the water was getting onto something important.
    Do NOT use WD40
    Edit: Beaten by Jack
    Nov 2016
    338
    I've run a heavily corroded circuit board through a dishwasher at 55 coz cunts on the internet told me too. Help get a lot of it off and then did the whole contact cleaner toothbrush compressed air procedure. Worked fine for years. As long as you get any corrosion off and make sure it's all dried really good, you should be ok whichever course of action you take. Def need to make sure it doesn't happen again, agree with drill method mentioned above.
    707
    aren't ECU's waterproof, every one I've see is. The the box itself isn't, the board will be epoxied, or potted.
    the problem is probably the loom, corrosion on the terminals etc, as covered above.
    GT-P
    Bandsenkowagon
    5,963
    Does this look waterproof to you?
    12,803
    Some are covered in epoxy rubber like shit, but definately not all, not something id risk with water anyways.
    Id chuck the ecu in a jar of rice.
    Jul 2002
    Brisbane Aust
    1,704
    That epoxy rubber shit is called potting. Often alone that wont be water proof and needs drying out. Often a waterproofing spray over everything is better, or used in addition.
    Uncooked rice absorbs the moisture. I have used it before on servers that definitely aren't built to go under water. Works faster in oven bag and around 60 degrees for a few hours.
    Aug 2010
    1,129
    Quote Originally Posted by pH@tTm@N View Post
    And a microwave will do it in a few minutes!
    wollongong
    1,012
    Or put it in a warm oven for a few hours, salt to taste and re-install.
    Nov 2016
    338
    Some tasty recipes there
    Aug 2010
    show bobs
    2,607
    MMM slow cooked PCB in a red wine jus
    Jul 2002
    Brisbane Aust
    1,704
    Hey it got 6 severs working until the replacements arrived
    14,815
    Do NOT use WD40
    You know that you can run a engine on WD40
    Nov 2006
    1,018
    Thanks for all the tips (useful or not !!!!). Its all dried out, water looks like it stopped about 5mm short of any electronics on the PCB, only got to the plugs / connections coming out of the ecu. Cleaned everything up with contact cleaner / toothbrush, new carpet underfelt, put it all back together and its going as good as ever (except for what seems like failing clutch hydraulics now ).
    Water leak seems to have been caused by getting a new softtop fitted late last year after the old one was slashed. MX5's have this great idea where water running off the softtop is channeled down into a plastic "gutter" inside the shell which then disposes of the water through a 15-ish mm drainhole that runs from basically the parcel shelf area (ie inside the body shell) down through a drain tube running through the body of the car and dumping on the ground. The trimmers seem to have left an Xmas tree trim clip floating around which ended up in this drain, completely blocking it. Once the drain is blocked, water just runs down behind the seat and into the passenger footwell.
    Pulled the clip out of the drain, run a trombone cleaner (essential special tool for MX5 owners) through the drain tube and all seems good.
    9,227
    Yeah, as said before, provided the board has no corrosion it should be ok. Dad's old A4 drowned it's ECU, due to blocked plenum drains and they dried it out and it was fine. The ECU was completely submerged, although I think Audi did have some form of waterproofing due to the location of the ECU. Fwiw, I killed an alarm ECU and had issues with the engine ECU on my Mazda due to dust ingress, alarm was a bin job, engine ECU was blow out the and tape up the seam.
    Registered User old_geez's Avatar
    Jul 2006
    1,268
    Sent from my iPhone using Tapatalk Pro
    Quote Originally Posted by Sicarius123 View Post
    Performance Forums, where our two best threads are a man stabbing a lawn mower and a lawn mower stabbing a man
