Results 1 to 15 of 15
Thread: MAP + TPS: Am I choking my engine?
    Aug 2011
    348
    Hello everybody.
    I have a single seat AR51 buggy with a 2006 GSXR1000 motor and I have a question.
    Some info:
    The conventional wisdom with running these motors in an off road buggy is that the standard air filter is not good enough to cope with the dirt/dust etc. So as a quick and easy solution I have cut the ends off 2 foam pod filters and stuck them over the 2 intakes leading to the stock airbox. I have a "standard" K&N filter inside the airbox as per normal.
    Now after cutting some laps on the weekend I have pulled the datalogs (I run the woolich racing ecu editor setup) and I have found my manifold pressure hits a brick wall at around 71kpa. From 30-80% TPS it doesnt seem to change. It seems to run pretty damn well, although it was bogging down in some of the deeper sandy sections of the track.
    Is this normal?
    Do many motors see the magical 101kpa(atmospheric pressure)??
    Am I choking my motor with my dodgy pre-filter setup?
    Some pics for info and showing off. (If you zoom in on the third one you can see the "pre-filter" on one side.
    windsor nsw
    1,192
    You should definitely be soon closer to 100kpa. There's a restriction somewhere. Fuck that looks like fun
    Aug 2011
    348
    And a vid...
    5,962
    Drive it somewhere clean with the pre filters off?
    Aug 2011
    348
    Ok so I went through a few datalogs and found that the MAP is reading 75kpa with the engine off. Digging around to try and find if this is the normal range for a GSXR MAP sensor.
    6,438
    Probably the sensor scale. What ecu?
    Aug 2011
    348
    Stock suzuki with the woolich racing editing box and software.
    I will ask on their forum as well.
    6,438
    I would check the sensor voltages. You should expect about 4.7v at atmospheric but look up a 1 bar MAP sensor voltage table to confirm.
    It could be scaling in the log viewer too.
    17,900
    whats it read with key on and engine off
    Aug 2011
    348
    It reads 75kpa.
    Aug 2011
    348
    I will have to call woolich tomorrow and find out if this is normal. My understanding of it is that over a certain kpa it switches from MAPxRPM to TPSxRPM, so maybe the suzuki MAP sensor only goes to 75kpa??
    6,438
    It will be a 1 bar sensor for an NA car mate.
    Aug 2011
    348
    Thats what I thought yes.
    Aug 2011
    348
    Ok so it seems a new genuine one is around $150. Is there any reason I can't use an aftermarket one or is the scaling different? The woolich tuning software doesn't seem to have any features to adjust the scaling of the MAP sensor. I guess it assumes you will use the stock one.
    Feb 2017
    1,065
    I have nothing useless to add, but came to say, fuck this thing is tits!
