Results 1 to 30 of 30
Thread: Abnormal tyre wear
    Founder Nick's Avatar
    New New Zealand
    4,501
    Abnormal tyre wear
    Guys,
    Need some advice. A while ago the nopics was hit in the rear quarter by a truck. Not too much damage but smashed the rear door window and side window, broken tail light. Truck didba runner so bent over and sorted insurance myself.
    Was all repaired and looked great.
    Since that time ive had issues with chewing out rear tyres.
    Got a set replaced and got the shop to do a wheel alignment, they said itbwas all sorted etc.
    Que about 9 months later and another set is chewed. Buy, aligned (different shop).
    Now i ive just done a trip to Sydney and back, i noticed that during the trip that i could hear a small wirrrrring noise, has gotten louder since returning to Brisbane.
    So thinking the diff was going, i jacked up the car and checked it, seemed to make normal noises.
    I then checked the rear tyres. Yep fucked out again.
    What can cause rhis type of wear? Too much toe out? Why cant these tyre monkeys align my shit?
    Sent from my LG-H815 using Tapatalk
    6,450
    Which bit looks bad in that photo?
    New New Zealand
    4,501
    Top right bit, see how it is worn?
    Will post a pic of another previous tyre that has it a bit worse.
    New New Zealand
    4,501
    Couple of previous tyres, 6 months apart. Yes, a couple of shops have "checked alignment". I'm starting to think they might need to check the subframe.
    Cuntberra
    6,096
    Something is bent probably not subframe but the exact car model would be helpful some cars have piss weak subframes some don't. Also if the wear is a little bumpy your shock is fucked
    I did 7 years of smash repair on suspension for three smash repairers.
    New New Zealand
    4,501
    2006 Subaru Liberty.
    Shocks were replaced before this issue.
    Cuntberra
    6,096
    Quote Originally Posted by Nick View Post
    From memory they have two lower control arms per side with only limited adjustment. Take it to a good alignment shop and ask for only a print out and post here and I bet we will see the problem straight away.
    Cuntberra
    6,096
    Actually 2006 is the multi link but still get a printout.
    Oo=V=oO GTV's Avatar
    Mar 2009
    BRISBANE
    1,891
    That's very bad wear. Must have too much camber or some toe out, which should be obvious for an alignment. Is wheel bearing OK?
    Jason, 1983 GTV6 2.8, 1974 2000GTV Group Nc
    Cuntberra
    6,096
    Quote Originally Posted by GTV View Post
    A wheel bearing might be borked but will not cause noticeable wear also the wear in the first photo looks crazy but is actually accentuated by the tyre design the wear in the later photos was corrected but not correctly as there is not enough adjustment in these if there is something bent. Not to mention you don't want to over adjust something to compensate for bent components which is why manufactures don't give you much adjustment.
    Sep 2010
    Adelaide, SA
    1,462
    The tyre in the first photo has a fractured steel belt in the tread.
    Cuntberra
    6,096
    Please explain,
    Sep 2010
    Adelaide, SA
    1,462
    Look at the relation between the tread and the sidewall. It changes around the circumference of the tyre.
    Cuntberra
    6,096
    Yea I noticed that and need more photographic evidence to come to that decision as some tyres actually look like that.
    Big john may be infact on top of this and right but the op still needs to post more pics. I 'm starting to think BJ nailed it.
    Sep 2010
    Adelaide, SA
    1,462
    They look like that if they are fucked.
    Cuntberra
    6,096
    Yea you are right if you look at the tread lines where they stop you can see it. Sorry you have an egal eye and were right.
    I will say it's hard to judge off one photo but BJW nailed it good on you.
    New New Zealand
    4,501
    It is a interesting theory but the other side tyre is the same as i mentioned. Bit wierd to have both fail.
    Im going to get the insurance company involved. And as you said, get another wheel alignment with the printout.
    New New Zealand
    4,501
    For reference here is whamt they should look like.
    Tyre off front.
    Sep 2010
    Adelaide, SA
    1,462
    Wheel alignment isn't go to fix broken tyres. Either impact damage of a manufacturing fault.
    Sep 2007
    5,260
    That kind of wear right on the edge isn't usually a camber issue, it's way too much toe-out
    3x1UZ+1x2UR...
    New New Zealand
    4,501
    Sure a broken tyre might be very possible, I just can't get past that it's done the same thing to multiple tyres from different brands.
    Quote Originally Posted by perthdrivers.txt View Post
    That's what I was kind of thinking, even though the tyre blokes seem to think it's ok. Will call insurance company today and see what the options are, may take it to Ken at accurate to get a professional look at the geometry.
    509
    + 1 for toe out. A little neg camber won't wear the inside that quickly, unless you are doing lots of burnouts. A lot of neg camber eg 3%+, would be visually obvious to you.
    Another thought - given the uneven nature of the wear, are you sure it's not rubbing on something?
    EDIT: Do you know how to stringline a car? You should be able to check the toe yourself with this method.
    Jan 2011
    1,398
    Looks like it is rubbing on something.
    New New Zealand
    4,501
    No idea on stringlines, something that I've always thought "I really should learn to do that" but then just pay some bloke to slap it on a machine.
    Stan, yeah that is what I thought at first too, but the only thing the tyres can hit is the plastic inner guard and there is not a mark on them.
    Jan 2011
    1,398
    What about under full suspension compression/droop? Doesn't look like an alignment issue to me. Viewing the pics on my phone tho, so might be missing something.
    509
    It's pretty straightforward, four axle stands and two bits of string and a tape measure is all you need. Run one bit of string between two axle stands next to the car at hub height, then do the same on the other side, making sure the two bits of string are perfectly parallel. Then measure the distance from the string to the rim edge (not the tyre) at hub height in front of the hub, then behind the hub ie 180 degree opposite. For zero toe, the measurement should be the same. If it's toeing out, the front measurement will be shorter than the back measurement.
    I'll see if I can find you a video.
    I had another thought, if you have really bad rear toe out, the car would be oversteering when turning in, do you notice that?
    509
    And here's the video. This guy is doing the toe on the front, but the same principle applies to the rear:
    https://www.youtube.com/watch?v=bYhpBouhikk
    Mar 2009
    BRISBANE
    1,891
    actually, does look a lot like a tyre that is rubbing on the coilovers...
    out in the boonies...
    4,380
    Got a tyre on my car done same thing, but alignment, ok.
    Did a bit of research with only a couple of links on the entire internet, but its called tyre tread/shoulder "separation"
    Apparently can be a tyre defect apparently or overheated but I'm not entirely sure, mine are yum cha brand tyres however.
    https://www.bobjane.com.au/info/tyre...n-information/
    If you want to try and find more info look for "separation" in your google searches.
    If you come up with concrete answer on the cause let me know.
    Edit: And no it's not rubbing despite what internet mechanics say in most threads where someone asks about the same wear pattern.
    9,113
    Something in the rear end is bent, either subframe or suspension arms. While it might be possible to get the alignment right to compensate, most aligners don't bother, hell most can't even get the car to drive straight after an alignment.
    Does the car drive straight when viewed from behind?
    Nopics had a similar issue on her old Magna after a motorbike hit the front wheel, no obvious damage but she suddenly started chewing out tyres and the CV joint. The impact had twisted the knuckle slightly. Couple of guys on another forum have had the same issue as well after hitting stuff with the wheels.
