Results 1 to 30 of 41
Thread: LS into Gen2 Pajero
    Melbourne - Vic - Aus
    1,058
    LS into Gen2 Pajero
    My daily NL Paj-bucket has finally cooked its 6G74 to the point that no amount of silver seal is able to keep water out of the cylinders. I'm not planning to buy a new daily until the start of next year, so I'm keen to try and screw another 12 months out of this thing before turning it into dog food cans.
    I have a spare rear sump LS1 and auto box with all the accessories that I figured I'd try and sleeve into the prick. There's no conversion gear for these anymore as Marks 4x4 no longer make the kits so I've gotta try come up with my own. I still use the car out bush on occasion, so 2WD isn't an option.
    Car is also auto, so an adapter plate isn't really ideal unless there is a simple way of getting the electric auto to work.
    Can anyone in the know confirm if this list is correct from a "make fit and turn all the wheels" perspective?
    - Gen2 Paj 3 liter transfer case (as it's 23 spline and not 24 like the 3.5)
    - Advance Adapters 50-0430 (4L60E to Jeep NP231)
    Everything else I can fabricate myself.
    Enlarged Member RMX's Avatar
    Apr 2010
    The United States of Australia
    1,192
    Subscribed.
    I can offer no real advice other than peer pressure.. Do ittt!
    How many blowjobs to pay off that debt?
    1,792
    from memory they run an A340 auto with a standalone controller? would make a UZ, FZ, JZ or GZ conversion fairly strait forward...
    1,058
    Good point. The 3.5 does have the A340 box and I can get a 1UZ for about the price of the advance adapters kit I posted above.
    Back to Google I guess.
    8,864
    UZ into Pajeros is relatively "common", in that there are a few running around including a couple of UZ L400 Delicas. From what I've read around the traps you need to swap the input and front pump so the Mitsubishi box works with the UZ, saves messing around at the other end.
    8,864
    2,929
    A few UK V8 pajs, I'll try find the threads
    [DIRTY31] lysdexia's Avatar
    Apr 2005
    Bunbury
    2,410
    what about using the LS1 and the 4L60 that you have, and adapt to whatever transfer case you can get in the correct side drop for cheaps.
    or, buy a transfer to suit a 4L60 out of something in the US even.
    nb: I have no idea what it would cost to get new shafts made etc vs buying the Gen 3 transfer and jeep adaptor as you mentioned in the first post
    1,058
    The problem with changing transfer cases is that I would lose the super select and potentially low range, assuming the Silverado ones don't have it?
    Passenger side front diff makes life hard as well. Otherwise I'd just use a TB42 box and transfer.
    8,864
    Majority of GMs are dual range, the ones that aren't that I can think of are the Astro/Safari and Express/Savanna vans, the Trailblazer and Silverado SS and Quadrasteer Denali pickups. From what I can tell only the Borg Warner case is single range, iirc it's the same unit used on the Adventra. But yeah, you loose super select, the only way to keep that is retain the OE case or use the Jeep one, which apparently is pretty near the same anyway.
    12,741
    If you stuck with the jeep transfers, most of them are l/h diff offset, and the linkages would probably be not far off the mark.
    Best bit is a wrangler rubicon transfer (if you can find one) has a 4:1 reduction
    Desert Nigga vet 180's Avatar
    Dubai
    2,977
    UZ makes more sense in this case as the paj bay is short and wide. A UZ is shorter and wider than the ls. You can also get the UZ to bolt up to your current trans. You can run with the stock headers until you turbo.
    1,058
    1UZ is certainly looking to be the go. It won't be going turbo, I have too many turbo V8's in my life as it is.
    Perth, WA
    682
    You'd be wasting your time putting a 1UZ in, a fresh 6G74 with some work will have a bit of poke.
    The only reason to put a 1UZ in is to gain noise.
    LS as you have a spare makes sense for a big power increase.
    1,792
    A VVT-i 1uz 3uz or to a lesser extent 2uz would be nicer obviously and more power then a $500 early 1uz but OP suggests this is a budget job...
    1,058
    Definitely a budget job. Tickling a 6G74 is also an option, but short of strapping a turbo on it, I can't see too much improvement being possible.
    12,741
    With some work... Lol, its a mimimum 50kw power deficit we are talking about here
    And then you are still stuck with a gutless under performing pos 6G just begging to blow a head or bottom end.
    1,792
    Quote Originally Posted by afraid View Post
    1,058
    .... but not a desired one
    1,288
    6G75 with a bonus 380 shell to adorn the verge?
    Nay sayer Mr Ed's Avatar
    14,905
    You shut your whore mouth!
    Perth, WA
    682
    Not a huge power difference difference, but the difference does mean you'll be revving the engine out to get the torque... 4WD isn't about limiter bashing in most cases.
    RPW over in Perth do a bit of work to them, or did, dunno if they are still around. You'll make up the difference pretty easily and have no headaches with conversion.
    We had 250k on ours before it needed new valve seats... that was 9yrs ago and I still see it driving around towing a boat.
    12,741
    The 1uz will make more piwer, lower in the rev range than a 6g74 bro
    1,058
    Having had both, I'm inclined to agree. The 6G74 is capable, but not a very pleasant engine.
    8,864
    As much as I like Mitsubishi, your mad if you think a 6G of any variety is equal or better than a UZ, especially for a 4wd. The DOHC 6G74 might have had more power than the 1FZ-FE but it had a lot less torque, and drank PULP like a fish. A tickled 6G would be the same, and develope it's torque too high in the rev range compared to a V8.
    Dubai
    2,977
    Quote Originally Posted by South View Post
    The noise would be nice, but the obvious choice is torque and reliability. The 1UZ is a great 4x4 engine simply because of the reliability. In Stock NA form there are very few engines more reliable.
    Perth, WA
    682
    Its not that much of a torque increase that is 1400rpm further up in the rev range... in a vehicle that weighs much more than the Toyota sedan it came out of...
    1,058
    I'm more concerned about reliability to be honest. I've never had any luck with Mitsu motors not lunching themselves when you look at them the wrong way.
    14,905
    My LS400 moves ok and is 1750kg. Google suggests a gen2 pajero is also 1750kg.
    12,741
    Yep this.
    And the difference in torque is 1400rpm..before you start modding the 6g to try, and make the power of the 1uz.
