Results 1 to 9 of 9
Thread: Talk me through exhaust pipe
    23,661
    What's the best deal with mig welding exhaust tube? Straight up, I'm a shit welder but want to get better and want to do as much on my cars as I can. Low amp, low wire and patience or high power/wire and fast action?
    Any help much appreciated
    5,963
    Just practice, from memory the trick is hotter than you would think and move fast, but I'm a shit welder too. TIG is better and easier for nearly all aspects of exhausts if you have that luxury.
    Apr 2009
    Devonport, Tasmania Australia
    2,205
    Mig is pretty easy, practice your settings and write them down.
    At first go a bit hotter than you think you need. It's better to stop start a bit because you are too hot than to have fuck all peno and get it all in one.
    Fit up is key. Spend as much time as possible making sure everything is a nice close fit. Any time saved here is a cunt to try and clean up later lol.
    Mostly exhaust tubing isn't real thick or thin, so there isn't much that can go real wrong... Patience and fitup, the rest is pretty straight forward.
    06/07/2011
    Apr 2009
    2,205
    Also, I'm sure you know. But just incase, always disconnect the battery from the car when spot welding or tacking or anything.
    I'm paranoid so I remove both terminals lol... Only cos I can't remember which is the right one.
    06/07/2011
    150
    No point repeating what fanta pants has mainly covered but as another tip I tend to have hotter settings when I tack weld and turn them down slightly when I actually weld.
    Never do an uphill mig weld on thin metal too, will blow holes.
    I always setup my welder by running a weld on a bit of scrap the same thickness of the job.
    Sent from my SM-G925I using Tapatalk
    23,661
    Thanks guys, that gives me somewhere to start
    5,963
    If you have more time than money it is worth looking at lobsterback bends too. Also you either get better at welding faster or a shit result with lots more leaks.
    23,661
    Do you get time to go from side to side or just right down the middle?
    1,314
    Right Up the middle. It's not thick enough to weave. Shouldn't need a second run either unless you missed the edge.
