Results 1 to 9 of 9
Thread: Bending 8mm steel bar
    23,658
    Need to put a 180 degree bend in 8mm steel rod on something like a 2" diameter. Best options??
    Thanks
    150
    Heat up with an oxy and bend around something smaller than 2inch od pipe
    I usually tack weld a bit of pipe to a 10mm plate work bench I have and tack another piece very close to clamp the rod whilst bending. Hope that makes sense
    150
    Or cold bend
    Sent from my SM-G925I using Tapatalk
    23,658
    Will a bunnings disposable butane things get it done?
    4,054
    Will shit it in
    12,772
    8mm you could do it cold. butane will definitely help
    Ellis Juan mizone's Avatar
    4,060
    Will shit it in
    Yep works with the little burners. Take you time and heat it up evenly. I put mine in a vice and heated it up, then used a large ring spanner to slowly bend it around a form.
    Beware that is will discolour what you are bending
    23,658
    Yeah I'll make up a jig in the coming days as I need to make a dozen of them
    2,973
    Cold will be easy, we regularly bend up 12mm bar at work by hand and holes in stillages etc.
