Results 1 to 13 of 13
Thread: Brake rotors. 300mm x 28-32mm 4x114.3
    Mar 2009
    Bendigo, Vic
    1,694
    After a rotor for a custom front brake setup for my shitter track car. Much Googles and ebays have not had any luck sadly.
    After 300mm Dia and 28 to 32mm thickness. Would be epic if they where 4x114.3 also but don't hold out much hope.
    Thanks PF you guys rock!
    Mmmmmmmmm beer.
    Nov 2016
    321
    R33 gtst are 296mm and 30mm thick when new. 5 stud unfortunately but you may be able to get blanks and have them drilled.
    Jul 2015
    NZ/NSW
    176
    Honda Accord/TSX
    05-08 impala
    Alfa 147
    Chrysler Voyager
    2006+ Fiat ducato
    Mondeo
    Cross 6 AWD Crewman
    ZC Vectra
    I30
    S Series Jag
    KIA Optima, Sedona, Grand Carnival
    none are 4x114.3 but some varied hat heights ... if 2pce DBA52510 or Stoptech 31.G3B.0071 or 28.001.1100
    Mar 2009
    Bendigo, Vic
    1,694
    I sorta figured I was pushing shit up hill with 4x114.3
    It's a starting place thanks guys.
    Mmmmmmmmm beer.
    Apr 2009
    Devonport, Tasmania Australia
    2,204
    Random thought that may or may not be any use.
    But 3t in the states comparing a big brake kit for the ae86 boys with a 300mm 2piece rotor. Not sure on width but 28 sounds right and they are 4x114.3 ... Could be a start also mate
    06/07/2011
    Boob dude to4garret's Avatar
    Feb 2005
    769
    I have a set of new 320mm x 32mm in 4x 114.3 collecting dust if that would help. I went a two piece wilwood in the end that you could probably get a 300mm disc for.
    Mar 2009
    Bendigo, Vic
    1,694
    Wow! To many options to fast! See what I can work out and go from there.
    Mmmmmmmmm beer.
    Jul 2015
    NZ/NSW
    176
    what caliper are you using and pad annulus/depth? I'd go the 2pce setup, as DBA wont sell you blanks unless usually a 50pair order, so unless you can find one with 4x114.3 and the right hat height its going to be a little tough. 2pce you can set it up accurate. but with a larger outlay up front.
    28.001.1100 has annulus of 42.3mm, 31.G3B.0071 is 50.75mm and the DBA 52510 is 54mm and 52919 is 41mm
    Mar 2009
    Bendigo, Vic
    1,694
    Found these with you guys help thankyou. Should JUST squeeze under 16" wheels. I will make my 4 piston wilwood's rear calipers now.
    http://www.ebay.com/itm/WILWOOD-DISC...item3f1f9ad5e2
    Was hoping to stay 15" wheels but fuck it 16's with 45/50 profile tires it will be fine.
    PS Thanks T04garret for your kind offer.
    Mmmmmmmmm beer.
    Apr 2009
    2,204
    Just an FYI the t3 brake kit fits under most 15inch wheels... But either way keen to see how it shapes out man...
    06/07/2011
    Mar 2009
    Bendigo, Vic
    1,694
    Sweet! Thanks FP. Going to be a tight fit. In time it will be an update in my shitbox track car build thread. No more RIP brake, kitty litter fun for me anymore. Maby.
    Mmmmmmmmm beer.
    4,026
    180mm radius might be a bit tight for the 6 piston on a 15 inch. I'm assuming I'm too late and you've already purchased; the four piston only need 153mm.
    http://www.ebay.com/itm/WILWOOD-DISC...3D271113180642
    Have spent far too much time checking and rechecking the clearance of mine on the Valiant's 15 inch wheels!
    Mar 2009
    Bendigo, Vic
    1,694
    Your not to late MP. Limited budget means anything I do is done with plenty of time for reflection and adaption.
    Looks like I've got some more work to do. Thankyou.
    Mmmmmmmmm beer.
