Results 1 to 3 of 3
Thread: Stupid autocad question (quick one)
    will strike if provoked dhs's Avatar
    If I'm in Layout mode, I can toggle the grid lines on and off in my viewport
    However I want them to stay toggled on during export to PDF so they appear in my copy to show people
    Is this in Page Management or somewhere else? Is there a command I can type to force them to stay on, as all my annotations etc
    for company name etc are outside the viewport and even if I have mulitple viewports I will always want the grid lines on.
    2005 VZ SS 5.7L M6 Ute
    Registered User ajs991's Avatar
    Dec 2012
    Bathurst NSW
    I don't believe you can. Add them manually with array might be an option.
    Nay sayer Mr Ed's Avatar
    You might be able to do it but either way Id still just draw them in on a separate layer, then you can toggle on/off & set print lineweights/etc however you like.
    If you dont draw them then you have to worry about reference points possibly moving between model space and print settings/etc too. Draw them in yourself then you know theyre fixed.
