Results 1 to 30 of 39
Thread: RB30e+t turbo selection
    Aug 2008
    2,190
    Yes I know I'm a pioneer but forum threads from 2002 on calaisturbo are hurting my brain. wwpfd for turbo selection?
    Application: VL standard RB30e and standard 4sp auto and 25 spline open 2 pinion diff and 14x6" rims. I'm hoping to get a cast iron RB30et exhaust manifold which I believe is T3 flange and will provide clearance to the block/engine mounts for a GT35 size turbo. Probably will use the Megasquirt I have sitting around. Occasional street sleeper duty only.
    Power: Whatever the the standard pistons/trans/diff will live with without being reduced to swarf. 200rwkw?
    I would prefer internal wastegate for pipework simplicity. The cheaper the better but would spend around $1k for a "nice" unit. No need to allow for future big power levels.
    Precision 5858? Chinese GT3071? This Kinu TD06 appeals to me with integrated WG and BOV plus box of fittings: http://shopping.kinugawaturbo.com/ki...housing-1.aspx
    Registered User E-Z's Avatar
    3,777
    Falcon gt3540, 10mm spacer on the stock manifold. Can push 300kw on the stock internals.
    caprice nugget.
    Aug 2008
    2,190
    Sounds good to me! Will the trans and diff live though? I figure the 14" skinny tyres and open diff will be a bit of a fuse.
    TJzone TJ's Avatar
    25,394
    With 14's you are going to be blazzzzzzzzzzzzing one tyre... a lot of the time.
    If you lock the diff you'll snap axles on the regular.
    #teamtremolo
    And i'd still fuck Betty....
    3,644
    The jatco will start to slip unless it's been built a bit, increased line pressure and such for over 180rwkw is needed. Aside from that the 25 spliner may survive up to 250rwkw because it will just blaze one tyre and not grip.
    To go quicker you need to build the jatco a little and get a 28 spline turbo-spec LSD or Detroit
    Falcon turbo is absolutely perfect.
    www.showgroundsphysio.com.au
    www.neillsbikefit.com.au
    Aug 2008
    2,190
    A rolling burnout is a rolling burnout....right?
    I got laughed out of the Holden wreckers here for asking if they had a 28 spline VL diff so I feel like they are going to be out of my budget.
    I'm comfortable digging into the trans a bit as long as it's DIY.
    Registered User INFLYT's Avatar
    N.S.W, Sydney
    465
    My second last VL was a RB30E+T.
    In my opinion, turbocharger options for this arrangement are;
    Standard T3 (can be hard to come by nowadays due to age, but wont kill the rest of the car straight away)
    JPC T3 "secret/big" high flow (looks like nothing has been modified on the hot side, but can make huge grunt)
    Ford/Garrett GT3540 (readily available, but needs fucking around to make it fit)
    12,874
    Grab an lsd from an EA2-ED fairmont ghia or equivalent fairlane/LTD. V8 even better as they are 4 pinion. Heaps around and they are usually around $50 from the self serve wreckers. Custom axles arent expensive.
    3,777
    if youre ok with single peggers, get a VN -VS diff, tthey are 40mm wider but are 28 spline, just run a mini spool if its for skids., just replace autos as they break.
    caprice nugget.
    7,756
    Vl turbo diff be $2k lol. I'll sell you my minispooled vk borgy for $1700
    1,994
    28 spline axles for these are crazy prices..sometimes easier just go 9" or shortened b/w for big tyres.
    Cheapest way is narrowed down vn long axles to suit vl diff...long axle not sure it would last with a spool or abuse.
    Got lsd centre out of coon diff also.
    N.S.W, Sydney
    465
    I thought he was asking about a turbocharger???
    3,777
    caprice nugget.
    Jan 2013
    3,788
    Gt42r. You only dose once
    Aug 2008
    2,190
    $2k diff is wayyy outside of my budget for this. Driveline strength is very relevant to turbo selection because I don't want to have to pour many house repayment tokens into a VL.
    10,713
    25sp LSD is fine with normal tyres, it's only when you put 275 ET streets and have 400rwhp that they break. I have personally tested this; twice.
    N.S.W, Sydney
    465
    Just as I thought...
    With my previously aforementioned car, I went 25 spline L.S.D as recommended.
    My VL Turbo before that one had a locker. Don't do that.
    12,874
    Coon lsd and cut down vn axles wouldnt cost a few hubge. No need for $2k turbo diff
    7,756
    Commodore borgy axles are tapered. Here in lies the issue and why they aren't cheap these days. Original 28 spline axles go for good money. Especially at vl width. Mini spool the 25 spline and just replace axles when they break
    あなたの母親の肛門 Shifty's Avatar
    10,793
    Sending you a PM bruddah
    694
    My old 30E+T was amazing with a cheap T04E. Came on boost almost instantly and ran 16-18psi without any issues other than the motor breathing a lot (like all RBs). I will likely run the same setup on the current shitter I'm building too.
    10,713
    Wasn't the cheap hotness for these to advance/retard the cam one tooth?
    Jun 2007
    Approaching Uranus
    531
    Also thinking of doing this with one of my VL's but was thinking a .82 rear housing 3076 turbo or would I be better off with a gt35 and .63 rear? ( car is auto) Really dislike turbo lag especially after owning the G6E turbo where response was almost instant and pulled 280-300 rwkw, but a little concerned the smaller displacement will make the gt35 a fraction laggy. Thoughts?
    Mar 2006
    Not Mt Druitt
    1,220
    Just picked up a r31 with 146k, so this is relevant to my interests. is nistune the go for ecu department, or upgrade?
    7,756
    Link seem to be a very popular plug and play ecu, reasonably cheap as well
    See a lot of guys using the barra turbos, internal gate and all with good success. Cheap to upgrade to 61mm billet front wheel or change to external gate. Still fit low mount with spacer
    Jun 2007
    Approaching Uranus
    531
    Concerned about the big rear housing though 1.06 on a 3ltr too big? Car doesn't have a converter so possible lag monster. I do have a 1.06 gt35 off an xr6 but it has a .7 front cover for even more lag. Would like 280-300rwkw, would a billet wheel 3076 do this? Have a Microleb and X6 ign box with 800cc injectors and cast manifold with external gate to do it with.
    7,756
    I hear ya. You could choke it down with small exhaust. Bit tricky on stock convertor, not sure how the lockup clutch will like that hp
    Gt35 will do it easy, might be laggy. Could go a china something smaller
    Call proboost or raceequipped and chat with them
    Jun 2007
    Approaching Uranus
    531
    I;m now thinking billet wheel 3076 with 1.02 rear housing, this should get the power goal but at what boost?
    Mar 2006
    Not Mt Druitt
    1,220
    I like the link ecu idea, need a airflow meter upgrade though as these ones are so old and unreliable.
    Can you put a smaller rear housing on a barra turbo?
    7,756
    Why not?
