Results 1 to 12 of 12
Thread: Twitchy Steering.
    5,828
    Twitchy Steering.
    syd
    2,628
    I noticed this last time my car got new tyres and wheel alignment. Since its a company car i didnt bother saying anything because the workshop is useless past changing an oil filter.
    I have no source of problem however it eventually settled down
    Mine is a 03 prado by the way
    ACT 2607
    1,753
    profile difference between the rims and your stock ones?
    5,828
    461
    If I understand it correctly your two sets of rims are going to give you a different scrub radii:
    OE are +50
    Advan are effectively +40.
    If the difference is taking you from a zero or slightly negative scrub radius, to slightly positive, this could cause instability.
    5,828
    461
    No spacers on the Advans anymore as the Toyo's rub.
    Dunlops on the Advans with 5mm spacers was fine, issue seems to be the Toyo's as they are a "wider" 225/45 than the Dunlop 225/45.
    So it's only 5mm difference in offset between the two rims? You wouldn't think this would make much difference to the scrub radius. Is the car FWD? We went from +50 to +25 in the Swift, only made a slight difference to stability, and really only noticable under brakes.
    5,828
    461
    Correct FWD and +5 difference now. sedate driving it is barely noticable but driven with some gusto slight movement of the steering wheel seems overly exaggerated if that makes any sense.
    Yeah, that makes sense, and could be scrub radius going positive, but I'm struggling to believe 5mm could make that much of a difference. Are you able to put the 5mm spacers on the OE rims and see if it behaves the same? If I'm following the bouncing ball here, that would mean the OE rims had the same effective offset as the Allys, +45, is that right?
    Another left field thought, if the guts of the issue here is steering sensitivity, could it simply be that the Toyo's grip is that much better than the Dunlops, you are getting a much more crisp response to the initial steering input.
    5,828
    461
    If it was scrub radius issue then wouldn't it have been there (or worse)with the Advans + 5mm spacer as it was with the dunlops ?
    Yeah, fair point, I think we can bin scrub radius as the cause. What toe setting are you running? If you added a little more toe in, it should take the sharpness our of the initial response.
    5,828
