Results 1 to 12 of 12
Thread: Joining small diameter pipe
    479
    I want to make some exhaust gas backpressure measurements, and plan on connecting to the exhaust via existing O2 bungs.
    From what I've seen, people do this by attaching a length of brake pipe or similar to a blanking plug that sits in place of the O2 sensor. The question is, how to join the pipe to the blanking plug? The EGT runs at up to 800 degrees 50mm out from the head, so I'm not sure if brazing is an option. I don't have a TIG.
    I was thinking maybe a normal brake pipe and nut, but I would need to have a nipple inside the bung for the flared bit of pipe to push onto, and that's probably beyond my machining skills.
    Any suggestions?
    . crack's Avatar
    BNE
    2,443
    just cut the steel fitting of a brake hose / cut up a steel t-piece / ect. and pay the man to tig it on
    479
    You, Sir, are a genius. In fact I could weld a fitting that big myself with the MIG.
    7,529
    Buy o2 bung drill and tap 1/8", then screw in cut up brake hose
    479
    Thanks Dogsballs, I had considered this, but I'm not convinced a brake hose is going to withstand the heat. I think this is why others use a length of pipe, to give the heat a chance to dissipate.
    7,529
    O2 bungs should be down a bit off the header
    How you going to measure pressure? Won't that get effected by heat as well
    479
    The bung hole I want to use is the one I welded in for the wide band, it's about 300mm from the head.
    I've got a spare 1 bar MAP sensor, I was going to run some vacuum hose into it, then connect it to the data logger. I figured that because the exhaust gas isn't actually flowing through it, if the pipe and vacuum hose are long enough it shouldn't get heat affected. If that doesn't work I'll hook up a guage, which is what others seem to do.
    15,811
    Knock the porcelain and centre electrode out of a sparkplug, weld tube into that.
    Cuntberra
    6,096
    Why don't you buy the correct fitting with an olive and buy the correct size pipe and a flaring tool? flaring tools from china are very cheap.
    15,811
    Because a fucked spark plug and some welding wire is cheaper?
    1,199
    Way it's been done in the past, AN sleeve and tube nuts, 37* flares, several feet of stainless tube - coiled so it's not half over the engine bay - MSCN should have annealed stuff to make that easier.
    Something to go into a 18 x 1.5 bung shouldn't be too hard. Honeywell have something that might be better than running vacuum hose to a MAP sensor off some sort of nipple...no doubt npt though!
    Feb 2017
    1,061
    What about, cut a section of steel line, run a die over one end, and then tap the o2 bung the same and just screw the line in. Can ad a few nuts to lock it in place if required?
