Page 1 of 3 123 LastLast
Results 1 to 30 of 88
Thread: Rebuilt LS Breathing Like A Steam Train
    Toowoomba
    1,203
    If I don't laugh I'll cry.
    My mechanics got my engine started for the first time last night. Fresh L98 rebuild with Mahle pistons, bottom end was assembled some time back by a previous mechanic and recently we've only assembled the heads.
    It's very difficult to wind over and the breathers are pumping out smoke (much worse than below when it's warm apparently). Below 2000rpm it seizes almost instantly.
    [Click for video]
    Mechanic was concerned about piston-to-bore clearance but he called the original machinist (who didn't do the assembly) and he suspects the original mechanic has put rings in the wrong order.
    Does that match the symptoms or does anyone else have further ideas on what the cause might be?
    Choo choo
    LS7 Prius = Proper HYBRID Walt Kowalski's Avatar
    May 2010
    WWG1WGA
    1,492
    Feel for you. Calling BPM, TJ, Dogsballs et al
    Logical debate beats name calling any day. My Badges Of Honour so far in PF: Racist, Bigot, Islamaphobe, Numpty, Moron, Far Right Wing Nationalist, Far Fight Wing Fascist, "raving fucking lunatic", "dumb" & climate "denier". AND they are just SOME of the pathetic tags that I've been labelled by SOME here. HINT: Those labels are signs that the accusers have lost to logical debate.
    Watch this:
    Caught in the ACT
    17,068
    Apr 2009
    Devonport, Tasmania Australia
    2,203
    Farking hell man
    06/07/2011
    Registered User JESUS CHRIST's Avatar
    Nov 2009
    Even i don't know
    3,819
    Sorry can't help, but farrrrk that's noisy!
    Give one of the guys Walt mentioned a PM to come in here and look see.
    Even better Dale cunt (10sec RX7), he's built more of them than he's had roots.
    12,390
    Did it sit for a long time between being built and now? Rusted up rings maybe?
    23,623
    I would guess it's grabbed a ring. We can all guess all night but, either way, it's coming apart
    Caught in the ACT
    17,068
    would a compression test show if there was something odd with rings (eliminate bearing clearances or something?)
    Jan 2013
    3,406
    Pull it apart. Who built it?
    I like cars. Cars are cool.
    Always looking for Triumph 2000 and 2500 parts and cars.
    Struggletown
    6,580
    Basically this. It could be a couple things but either way it needs to come apart and then you'll know
    Hold it flat cunt
    Toowoomba
    1,203
    Yeah I guess cunts fucked either way, just trying to prepare myself for best and worse case scenarios. Will be picking it up tomorrow and removing the engine on the weekend.
    Fingers crossed it just the rings that need attention and not pistons or bores.
    4,051
    If its that tight, aint gonna be good....
    If it was a machining fuckup or something like that if would of felt tight by hand during assembly - one would assume.
    Mystery till you pull it apart.
    Ellis Juan mizone's Avatar
    4,042
    Humour me. Wack a torque wrench on the crank, throw it into neutral and turn it over with the torque wrench. How much until it clicks?
    Aug 2011
    251
    This. Those heads are coming off and I'm hoping for your sake the bores are ok...I would also guess a ring has folded over...
    A mechanic assembled one of my engines. When I went to check it with the head off still i noticed a small shadow on the bore, vertical about 4mm wide. Asked what it is, he didnt know. We popped out the piston and the middle ring had a small piece snapped off the end and was sitting on the side of the piston. He thinks it was because he used his big ass compressor which he usually used for large diameter V8 pistons (on my measely 87mm pistons lol) and it didnt catch the end of the ring properly. Probably a reasonable conclusion.
    Toowoomba
    1,203
    I'll have a crack on the weekend. The bottom end did turn over fine on the engine stand.
    May 2014
    495
    Just plumb the breathers back into the sump
    Registered User peal's Avatar
    3,244
    Yep, that's fucked.
    On the Shelf
    5,142
    This.
    When was it last spun by hand?
    Quote Originally Posted by peal View Post
    Yep, that's fucked.
    Undoubtably.
    However, did someone fill it with oil? As in, fill it.... to the brim.
    Toowoomba
    1,203
    It was on an engine stand a few weeks ago spinning by hand to set the crank scraper clearances.
    Given my other experiences with the car it's much more likely that the original builder (no longer in business) rushed the assembly. Everything else we've had from the machinist has been good.
    Melbourne - Vic - Aus
    1,062
    Have had the same issue with similar levels of steam train-ing. Rings had grabbed on 6 of 8 cylinders and destroyed the ring lands.
    Melbourne, S.E. suburbs
    1,449
    Can't hurt to comp test it before you pull it out. If anything it may isolate the problem cylinder(s) and help you find the problem. Although it will probably be pretty obvious when it's torn down, the more data you have, the better.
    17,890
    cunts fucked just pull it out and fix it, dont waste your time doing compression checks..
    1,307
    MFJ and Dale are spot on, no patch ups on this one.
    Don't keep flogging a dead horse, pull it out, pull it down and let us know what you find
    Jun 2009
    1,139
    yep pull it before you fuck it even more
    7,524
    Send it to dalecunt he's got a dart long motor there ready to swap with you /i
    17,890
    got 2 darts and the spare RX3 motor.. plenty of HP to go around
    Toowoomba
    1,203
    From one RX into another, that'd be perfect.
    5,891
    this should be in the vaping thread.
    Struggletown
    6,580
    Couple things to check if it doesn't stare you in the face when you pull it apartů
    More obvious is ring gaps but also check back clearance/radial depth of the rings and ring grooves. Had one years ago where the ring grooves weren't deep enough. It would run until it got warm and then lock up. Let it cool down no it would be free as a bird, warm it up again and it stall again lol
    Hold it flat cunt
    Cuntberra
    6,096
    At least you haven't fucked every part in the engine like what happened to me when one of my pistons let go.
