Results 1 to 18 of 18
Thread: Mechanical hand brake calipers.
    5,824
    5,824
    204
    Means well but is skittled
    Apr 2003
    437
    Brembo make some, including some as factory fitted to Audi, lambo, etc.
    Not sure what size disks tho..
    5,824
    5,824
    204
    those only suit 12mm to 15mm discs, Everest is 15.6mm, I will flick em an email though and ask, Thanks.
    AU falcon rear calipers have a mechanical hand brake mech inside the caliper. If you where to put a breather in the fluid inlet port to keep out the crude they would work with just cable actuation.
    http://i.imgur.com/rtiS96A.jpg
    Disc thickness varied across the series from 13ish mm to 22mm
    5,824
    5,716
    Yeah been searching Brembo's but finding actual specs seems impossible.
    [img]
    OEM Brembo park brake calipers on a Jaaag XJR and S-Type R 2003-2005
    330mm x 15mm rotor, I think 15.6mm thick rotor won't be a problem. The handbrake is cable actuated.
    The AU coon ones will obviously be cheaper though...
    5,824
    5,716
    Got a part number on those, are they centre pull ?
    Left caliper C2C11644 / 2W93-2B685-CB
    Right caliper C2C11643 / 2W93-2B683-CB
    Pads are C2C13800 but you'd be nuts to buy them from Jag, can get aftermarket ones for $10
    The anti rattle spring & pin kit is C2C21784
    I put up some more pictures in the previous post as well.
    5,824
    204
    [img]
    Aug 2011
    793
    AU Coon is Drum in Disc. xD-ED Coon is mechanical handbrake.
    Struggletown
    6,580
    Yep. And the falcon setup is not very reliable
    Hold it flat cunt
    8,859
    Another option is a transmission mounted park brake like on light/medium trucks. If you decide to go the hydro handbrake, I'd use a hydraulic lock system, pretty common system by all accounts and very effective.
    5,824
    1,287
    Yep, the one on my Discovery would lock all 4 wheels, was great.
    Part of the LR parts bin too.
