Results 1 to 5 of 5
Thread: Turbo Cam recommendations
    May 2017
    10
    Hey guys, Im after any advice regarding cam selection. The engine is 414sbc built with quality gear for 600hp NA.
    I've purchased a Garrett billet 88mm turbo brand new built by rotomaster. Was a Gtr45 with 81.6mm front wheel and 87 rear, now has 88 front wheel 1.15a/r.
    It was a good deal so grabbed it, my plan is to collect parts over a 12 month period including intercooler, new pistons, fuel pumps, carb upgraded clutch etc.
    Can any body suggest a cam to suit to help get into the 650-700rwhp region maxing at about 6500rpm. Its currently a solid roller so prefer to stick with a turbo solid roller, it runs a manual 5 speed and currently 3.9 rear gears. Im also after a mild sounding setup nothing like she is at the moment.
    Cheers in advance.
    BOOSTFARKIN Morcs's Avatar
    May 2012
    630
    More or less cam it for the rpm range na that you plan to operate in not the horsepower you want to make.
    I don't know not alot of the sbc also if doing much street ks go for a hydraulic roller at your desired rpm limit would be fine.
    To be honest get a custom grind for it by ringing a cam company.
    Or try searching on theturboforums /yellow bullet
    May 2017
    10
    Thanks Morcs, I've got a guy in Brizzie who's going to spec a cam for the combo. He'll be supplying one of his custom carbs and rebuilding my short with new turbo pistons and pins. We should get 600rwhp with this.
    4,859
    272 or bust.
    www.markpakula.com
    May 2012
    630
    Quote Originally Posted by Briz406 View Post
    If your going with zok race carbs
    From reading zoks posts on Aussie v8 you'll be in good hands
