Page 20 of 21 FirstFirst ... 10161718192021 LastLast
Results 571 to 600 of 613
Thread: Vs Barra ute
  1. #571
    Apr 2014
    ACT
    1,076
    It's jisy visiting sydney for shenanigans
  2. #572
    \/ \/ My motivation \/ \/ ALLMTR's Avatar
    Newcastle-ish
    22,979
    When you gotta ute every cunt wants to borrow it...
  3. #573
    Apr 2014
    ACT
    1,076
    only chuck wants to buy it lollllllll
  4. #574
    That's Sir Cunt to you... krisr's Avatar
    Shitney
    993
    I noticed that when I had my old ute, I was the most popular cunt around, especially when people had to move house...
    Quote Originally Posted by Motherfucker Jones View Post
    If you can't appreciate that then you are more narrow minded than the most mulleted, flanno, thong wearing, thong slapping, 253 owning, southern cross tatted, fuck off
    we're full stickered, VB drinking bogan you'll ever meet
  5. #575
    are hairy Dogsballs's Avatar
    7,116
    People never ask me.
  6. #576
    Look behind you... Milkman Don's Avatar
    look behind you
    2,623
    Longest gearbag rebuild ever....
    #whereistheute?
    I agree with Rdyno
  7. #577
    16,764
    Quote Originally Posted by Milkman Don View Post
    #whereistheute?
    my rebuild is at 10 months and counting.
  8. #578
    look behind you
    2,623
    Doing it at home?
    I agree with Rdyno
  9. #579
    16,764
    nope - long and protracted story that currently sits at mate stuck a long bolt in the wrong hole when re-fitting and into the water elbow on the back of the oil cooler..
  10. #580
    Registered User gtrboyy's Avatar
    1,875
    It looked low parked next to my vp a few weeks ago.
    How long before auto & alternator fixed?
    an easy fix is get a mate to drive in front of you at 60 then 80 then 100 and mark in on your speedo with some liquid paper.
  11. #581
    look behind you
    2,623
    Quote Originally Posted by gtrboyy View Post
    Only two blokes who know that answer, but from an outsider view the bloke in sydney has been having fun thrashing the car around but not fixing it...
    I agree with Rdyno
  12. #582
    7,116
    Front is pretty low, should of gone one step higher.
    No idea, its coming back on trailer today
  13. #583
    1,875
    I dropped maybe 2" from factory ute springs & took 50+ kgs out of it yet still vp looked like 4wd.
    First thing I checked was rear tyre/guard to see what's needed to fit 255/60 or 275/60 tyre under them lol
    By looks of it seemed like he'd been waiting a while for auto bloke to fix it or was giving him the fuck-around
  14. #584
    7,116
    Finally got my act together and yanked out the motor/gearbox. Although a bit of mucking around, just easier with it all out. Was bit of a pain with the aircon all connected but all well
    Did the gearbox first. Pulled the extension housing off the old one and the Speedo gear. Measured up the little slot of the Speedo gear retention then cut the output shaft. Swapped the housing over. Turned box over and ripped the pan off to do a service. Fluid a bit ordinary. I took out the s5 solenoid and screwed the adjustment screw in half a turn. This should firm up shifts by increasing line pressure. They say 3/4 for a really solid shift, so I dialled it back. Reassembled and put it back on engine
    Started on the timing chain replacement. Started by removing alternator and power steering pump, as both need to be replaced. Then pulled the rocker cover off. When I pulled the top cover earlier there was oil everywhere, particularly coil 1 and 2, they were left not even pushed on. Wtf, dodgy bastard just left it. The rocker cover gasket kit arrived today, so going to replace all of them. So soaked up the oil in the sparkplug holes. Then Took off rocker cover. Cam timing looks ok. Urghh. I have the timing chain kit, so will change it tomorrow anyway
    Need to drop past wreckers and grab a PS pump as there is heaps of shaft play, most probably due to running it with no fluid. Then Repco for some oil and oil filter. Change out the timing chain. Then get it back on the road
    Sent from my Nexus 6 using Tapatalk
  15. #585
    7,116
  16. #586
    1,159
    Good to see you’re getting stuck in. Cam timing codes due to broken plug coming off sensor?
  17. #587
    Canberra Nth
    2,860
    x2
    I'd bin the BTR and buy something half decent.
    BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe
    - PSN: rotacoupe
  18. #588
    7,116
    Quote Originally Posted by bpm View Post
    Possible. Or this one had a split seal, so oil getting in there
  19. #589
    Newcastle-ish
    22,979
    Quote Originally Posted by no13b_Coupe View Post
    x2
    Sure, if he was going to keep it (which, with it's history/memories, I doubt)
    1jz Rolla Van ....... 10.5 at 134mph
    "Reacher figured if he could put that drivetrain in some battered old sedan body, then that would be his kind of car"
  20. #590
    look behind you
    2,623
    can you hurry up and fix this, I need to use it for a few weeks until you sell it
    just finished pulling my hubs out, bearing in front left is cactus. Will have back together and ill head around later on
    I agree with Rdyno
  21. #591
    7,116
    Scored a mint PS pump at Jolly's for cheap this morning. Collected some oil/filter from Repco. Got straight into the timing chain. Took longer to clean the gasket surfaces than to swap it out. Replaced all the front seals and rocker cover seals. Pretty nasty, all baked on. Clean up timing cover and rocker cover as best I could. Put on another alternator and PS pump. Cleaned coils and put original ford top cover on. Drained the oil, swapped over filter. Filled the trans while it was out, as a pain from the side under the car. Spare yoke always handy.
    Wired in new alternator plug as old one full of oil and one wire plastic was stripped. Also rewired the crank angle sensor.
    Then put it back into car. At this stage milkmedan came over. Helped the last push. No major hiccups. Cleaned up a few things from last time. Filled and checked all the fluids. Turned the key, first crank and it fired. No leaks. Tested trans on the stands and seemed fine. Will take for a test drive in the morning after I fix a couple rear end things
  22. #592
    two jaaaaaaaags drscrote's Avatar
    Jun 2009
    669
    That's fairly moving well done.
  23. #593
    Registered User jimmyg's Avatar
    Mar 2009
    Bendigo, Vic
    1,548
    Good stuff.
    Mmmmmmmmm beer.
    You had one fucking job, Imran. One. Now look, there's Flibberty Gibbets all up in here, seeing straight through your ruse. One. Fucking. Job!
  24. #594
    7,116
    Quote Originally Posted by drscrote View Post
    Cans of v and up to minight helps.
    Cunt also swapped out my battery for one with wrong terminals.
    Also found panhard bush is flogged out
  25. #595
    look behind you
    2,623
    He had the motor 95% back in by time I got there, he doesn’t stuff around!!
    I agree with Rdyno
  26. #596
    Registered User bigshipengine.jpg's Avatar
    Wollongong
    6,718
    Quote Originally Posted by Dogsballs View Post
    LoveB. The gift that keeps on giving.
    It Places the lotion in the basket!
  27. #597
    Registered User PXL265's Avatar
    1,317
    I would hazard a guess that the terminals would be correct for a defender.....
    Sent from my XT1635-02 using Tapatalk
  28. #598
    7,116
    Topped up 3 litres of atf, this morning. Removed the last of bump stops so it won't bottom out. Fixed a split in the turbo coolant joining hose. Changed the 2nd fan wiring so it comes on with aircon
    Drives alright. Kept nice and cool. No oil or water leaks at all. Ready for sale
  29. #599
    Registered User [ryan]'s Avatar
    3,537
    Good shit
  30. #600
    May 2012
    Canberra, ACT
    54
    How much $$$???
