Page 18 of 45 FirstFirst ... 814151617181920212228 ... LastLast
Results 511 to 540 of 1341
Thread: Vs Barra ute
  1. #511
    7,829
    Thanks to faux forg, I have have normal indicators, yay.
    See how I go, thinking of heading to heathgoat on sun
  2. #512
    Opens ALLMTR's Avatar
    Newcastlish
    23,490
    What are your feels, 11's?
  3. #513
    7,829
    Hard to say, been playing stalling it up on the brake. Definitely punchy off the line. 11.3-11.5 ish
  4. #514
    5,505
    What trans? T400?
    Daily: Honda Civic EK1 Hatch
  5. #515
    7,829
    Factory 4 speed btr, factory convertor, 3.08 gears
  6. #516
    5,505
    Hopefully the 500kg difference makes the btr last. Love the car btw.
  7. #517
    3,196
    The long first gear should get most benefit from the half tonne advantage
  8. #518
    7,829
    Had a good day out. Best on street tyres was 12.5@125, swapped to the 235 radials 12.2@122 with 2.1 60ft. Seems to tag limiter on 2-3 shift, bit runs pretty straight and easy
    Only issues for the day was heater hose blowing off on a burnout and oil cap disappearing during a run. Used 3/4 of a tank of 98, there and back. Also weighs in at 1450kg. Thanks to MilkmanDan for help during the day
    Video
    https://www.instagram.com/p/BaiRokzj...a6BIEWnEVI2A0/
  9. #519
    3,196
    Vs Barra ute
    Good day mate, thanks for a steer too.
  10. #520
    Newcastlish
    23,490
    Nice mph! Wheelspin or ??
  11. #521
    7,829
    Zero spin. Just can't build boost without pushing thru line.
    Only spin thru 60ft when we pumped radials up to 32 psi, lol
  12. #522
    Newcastlish
    23,490
    Converter will take a second off that time
  13. #523
    7,829
    Not sure, Jason has a 2800 and his did the same
  14. #524
    Newcastlish
    23,490
    What rear gears does he run?
  15. #525
    Jan 2008
    Bris
    1,171
    Nice mph . Clearly it has a much better et in it with a bit of work.
  16. #526
    Mar 2009
    Bendigo, Vic
    1,703
    2.1sec 60. Your got heaps left in it. Loose a third of a second in the 60 alone.
    Well done!
    Mmmmmmmmm beer.
  17. #527
    7,829
    Cheers boys
    Just depends if I want to make it a drag car or just leave it
  18. #528
    Caught in the ACT
    17,358
    do the 4 speeds still have the torque limiting in 1st gear like the 6speeds?
  19. #529
    7,829
    They do, another guy had issues with it. Mine doesn't, just tags limiter
  20. #530
    7,829
    $1190 for 9.5" 3500 lockup dominator convertor. Hmmm
  21. #531
    3,196
    Vs Barra ute
    You know the answer. Then we make the exhaust easy to pull at track.....Zeus clips for front bumper.....
  22. #532
    7,829
    We don't need more hp, really.
    Exhaust easy to take off
  23. #533
    Newcastlish
    23,490
    I'd drop the rear gear a bit too/instead. Make for an easier life for the auto
  24. #534
    7,829
    But no chance of traction if it hits 10-15psi off convertor. Also convertor will make changes faster, so 3rd will be used more
    Anyone know of a 2 step module that would work with the factory ford ecu
  25. #535
    7,829
    Seems the msd LS1 2 step box works. Interesting
  26. #536
    3,196
    Would still need a converter though otherwise will only get what you can do with the brake pedal. I like the idea of diff gears, at moment it drives through 60” on the DRs, reckon if didn’t want to go converter a step up in ratio probably wouldn’t hurt. Get some more rpms in 3rd aswell
  27. #537
    Jul 2007
    Blackwater, QLD
    1,663
    if it's hitting the limiter on changes, is the trans slipping? might be a good time to up your line pressure at full throttle? a mate was showing me a $395 converter which has a little extra stall and mainly reliability upgrades on ebay. 3.23/3.45 diff gears would help too.
  28. #538
    Caught in the ACT
    17,358
    thats a pretty big converter for a stock turbo?
  29. #539
    24,325
    You won't need a 2 step for a few psi on the brake with stock turbo. Chuck that cheap eBay converter at it and some wrecker diff gears. That's all I'd be doing anyway because cheap fun is the best fun.
  30. #540
    Jun 2007
    Approaching Uranus
    536
    Just drive it and enjoy the reliability, you're already doing the megafast VL so leave this as is.
