Page 19 of 21 FirstFirst ... 915161718192021 LastLast
Results 541 to 570 of 613
Thread: Vs Barra ute
  1. #541
    Jan 2006
    5,655
    You won't need a 2 step for a few psi on the brake with stock turbo. Chuck that cheap eBay converter at it and some wrecker diff gears. That's all I'd be doing anyway because cheap fun is the best fun.
    agreed on the sentiment in the last sentence above. its the old 80/20 rule as it relates to modified cars. Barra the world!!!!
  2. #542
    7,116
    If I spent money on mods, I'd like to show.
    it at the track, that's the point. But I do get the vl will be much faster
    I idea of the 2 step is the balance between 0-15 psi going to be really fine. I can always dial it lower, but can't do it the other way around if convertor is too small.
    If I keep diff gears low I can also hit it at the higher boost and keep some traction. It will push deeper into 3rd gear with convertor also.
    The car doesn't need more hp, just need to get boost on the line. Also chatting to Jason in SA, seems the falcon has torque management with convertors over 2800 ish, Anthony burns had exact same issue when racing me in his new xe Barra ute on sun.
    The line pressure thing with auto has been mentioned to me. Not sure to be honest. I guess that's a new valve body
  3. #543
    7,116
    Anyone know anything about the S5 solenoid mod where you screw it in 3/4 of a turn to increase shift firmness?
  4. #544
    Sep 2012
    822
    The idea of the 2 step would be to leave the line at full boost, but to limit your horsepower at launch via your rpm. If you were to buy a decent stall you could sit on the line on the 2step at full boost at say 3000rpm, at 3000 you probably have half your horsepower available, so launch it hard and let it build power with revs as it leaves the line. Those tyres will hold the power you have but you need to hit them off the line to get the sidewalls working. Set up right its a high 10 sec car.
  5. #545
    Jul 2007
    Blackwater, QLD
    1,545
    why not do it through the software? you can set it up for more line pressure at full noise only. then you don't have to deal with rough shifts when you're just cruising around. maybe ask your tuner?
  6. #546
    7,116
    Thanks guys, low 11 and I'd be happy.
    Because I have column shift I don't have the tiptronic which raises the line pressure. Talking with Dave at kewish he reckons get it in power mode which is next best thing and will raise line pressure better than S5 solenoid mod
    Tbh I'm a little worried leaving line at 18psi even with convertor, which take a bit of the sting out.
    Anyhoo, its at tuners today. Dropping shift by 200 rpm and increasing rev limiter 200 rpm. See if it's in power mode. also suss why cruise control isn't working and weird random jerking at light cruise at 60 kmh
  7. #547
    Apr 2014
    ACT
    1,076
    do low 11s so i can try and match it lol
  8. #548
    7,116
    You can buy and fit convertor
  9. #549
    Not a Fan. Agent86's Avatar
    Melbourne,Vic
    648
    Tq management can be dealt with in the tune.
    The one thing my old ba needed was a convertor.
  10. #550
    7,116
    Quote Originally Posted by Agent86 View Post
    Seems loveb will get one for me
  11. #551
    Apr 2014
    ACT
    1,076
    ill split ya lol
  12. #552
    Jan 2008
    Bris
    984
    How about a modified stock converter? They normally only cost a couple of hundred to split them open and tweak a few hundred more rpm into it.
  13. #553
    7,116
    Need more than a couple hundred rpm, takes a bit for boost to come up. Hence 2.1 60ft
  14. #554
    2,623
    I reckon that run I had trying to bump it up staging and pushing the tires would of been around 2200rpms at best, obviously no tach though so guessing.
    Iíd say 3k converter would be where itís at, donít think a modded stocker would get there
  15. #555
    7,116
    Seems car is now logging exhaust cam out 10degs. Need to pull front off, might as well replace chain and guides
  16. #556
    7,116
    Weird it skipped a tooth and has a rough idle now. Wonder if we missed a tooth doing valvesprings but it didn't log. Anyhoo. $198 for new timing cover kit. Not a hard job, just awkward in my car. Fingers crossed I can move aircon condenser to get crank puller in there
  17. #557
    7,116
    Got the kit in the mail today. Went and picked up the proper Barra puller which is nice and small to make my life easier
  18. #558
    Apr 2014
    ACT
    1,076
    see you tomorrow lol
  19. #559
    7,116
    Mega butthurt continues. Good for a laugh
    https://m.facebook.com/story.php?sto...19531198082851
  20. #560
    2,623
    Any comments that the non fb user canít see
  21. #561
    Apr 2014
    ACT
    1,076
    far out that grew from last time. lol told em dont tag me else ill have to deal with the barrage of angry bogans lol
  22. #562
    22,981
    Yeah I think I got it worse cause mine is some kind of "classic" commodore haha
  23. #563
    8,029
    This needs a Lexen conversion to really piss people off.
  24. #564
    22,981
    I think the ford/Holden hate is stronger than the Holden/toyota hate
  25. #565
    2,623
    Vs Barra ute
    I think the hate is the fords had nothing until the barra, and for so many years has been LS this and LS into that, so get buthurt in a big way seeing a Barra in anything other than a Ford.
    Itís sad to be honest how the knuckledraggers carry on. A mate threw a 2JZ in a VT 10yrs and no one, not even toyota fanbois bat an eyelid
  26. #566
    4,231
    Nothing rustles jimmies more than a piston engine where Doritos once sat.
  27. #567
    22,981
    Is this coming out to wsid tomorrow?
  28. #568
    Apr 2014
    ACT
    1,076
    nah probably next wednesday still
  29. #569
    Jun 2007
    Approaching Uranus
    467
    So LoveB now owns this then????
  30. #570
    7,116
    Nope.
