Page 5 of 37 FirstFirst 12345678915 ... LastLast
Results 121 to 150 of 1082
Thread: Vs Barra ute
  1. #121
    Apr 2014
    ACT
    1,077
    im gonna be in melb by about 7pm will this be ready for skids by then
  2. #122
    7,534
    You have issues
  3. #123
    Thornbury Melbourne
    1,252
    How's the Tig going?
    Quote Originally Posted by myliberty
    My car is a broken heap of shit too, so we have something in common.
    13's for $1300: RX4/929 nugget.
  4. #124
    7,534
    Diff and tailshaft done. tailshaft copped new front uni, yoke and centre bearing. Diff got new bearings and pinion had to be machined to fit the torque lock.
  5. #125
    7,534
    Quote Originally Posted by aaron_hogan View Post
    Got gas yday but haven't had a chance to fire it up yet
  6. #126
    Sep 2012
    861
    I think i have the same helmet as you, you will need good natural light for it to work properly with the tig, doesn't handle night well at all.
    Love the build.
  7. #127
    204
    Be very careful with those helmets if you are doing any high frequency AC Tig work,especially at low amperage's. They flicker and drop out frequently.
    I recently replaced mine with a cig weld prolite, which has 4 sensors instead of 2 and is good down to 5amps on AC. Streets ahead of the old unit.
    The old one is great for mig/stick etc though.
    Means well but is skittled
  8. #128
    7,534
    Back on all four wheels with new suspension. Sits perfect height.
  9. #129
    2,972
    Chapel tough laps tonight?
  10. #130
    7,534
    Sic re
  11. #131
    678
    What do reckon total cost will be for this venture?
  12. #132
    7,534
    $11k as I redid all the suspension
    Today fitted up the tailshaft and then modified the height of trans mount so tailshaft angle wasn't too bad. Then welded up the catback as I switched it from passenger to drivers side cat location. Also cut a wedge out of the section above the diff so it tucked up nice. Looks a bit shit, but least there were no holes. Had a practice on aluminium for a while, but just went to shit when I tried cooler piping. So going to drop of drivers side cooler piping and rad to mate to weld.
    Had bit more play of the accelerator pedal. Chopped the plastic back heaps to the smallest possible. The. Took out a little bracket on firewall. Seems to tuck up nice. Just need to bolt it in
  13. #133
    Sep 2003
    415
    the weld looks ok. as long as air doesn't escape, it's doing its job.
  14. #134
    7,534
    Exactly. Lol
  15. #135
    23,650
    Heatproof paint and step back two more steps, that's my solution
  16. #136
    7,534
    Bwahaha
  17. #137
    7,534
    Few fiddly jobs today. Fitted the turbosmart 14psi actuator, set 2mm of preload and checked if it worked. Also massaged the rail to move the rack over for better dump pipe clearance. Relocated a few lines in the process. Got another btr 4 speed to work out the hole position for the Speedo gear conversion, then did it to my box. Dropped off radiator to be modified for falcon outlets and also one cooler pipe to be welded
    Trimmed the sump a tad for bit more clearance against rack as well and cut a bit off alternator for turbo hotside outlet
  18. #138
    7,534
    Testing actuator
    https://www.instagram.com/p/BW4vVuKD...cf-ZEdYE3Quc0/
  19. #139
    7,534
    Cut the rack mounts and moved them over 1.5". Fired up the welder and welded them in. Fits pretty nice, wound the tie rod in to get part of the lock I lost. Put the engine in and dump was close to fitting, so gave it a little tap and boom. It's in. Tackle the bottom half and cat tomorrow
  20. #140
    7,534
    Spent a few hours on this tonight and it really didn't look like I did anything. Played with the top part of the dump for a while as the bolt end of the intermediate shaft would hit as you turned. Ended up cutting a wedge out and rewelding it. Then played with the bottom section and trying to keep it high as possible. Can't weld the two halves together till I get the cat back from being opening up at one end to 3.5
    Then I jigged the fbw for the best spot then bolted it to the firewall
  21. #141
    7,534
    Pics
  22. #142
    Mar 2009
    Bendigo, Vic
    1,694
    I was really expecting a lot more use of a large hammer in this build. Heat shield back on. "It's factory built officer. Promise."
    No pieces of rockers to find each week to.
    Mmmmmmmmm beer.
  23. #143
    8,317
    Many awesomes. There will be so much bogan butthurt.
    My Sports Sedan
  24. #144
    4,794
    especially with Honda floor mats
  25. #145
    Slanted big_pete's Avatar
    Sep 2003
    Wagga
    7,620
    It has the VTEC? yo.
  26. #146
    2,972
    Quote Originally Posted by jimmyg View Post
    I was really expecting a lot more use of a large hammer in this build. .
    The trans tunnel had the fuck belted out of it, otherwise the big stupid thing just fits everywhere it's impressive
  27. #147
    7,534
    Cheers guys
    Jimmy surprisingly it fits pretty well. There are bits of tapping and a little cutting here and there but overall not bad. Yeah, with factory heat shield it will be factory looking, also why i got that plenum.
    Still undecided whether to fill ford logo with bog or paint the red to wrinkle black. The red is sorta growing on me
  28. #148
    Mar 2009
    Bendigo, Vic
    1,694
    It's Holden red now. Lol
    Can't wait to see it at the drags/pf xmas etc.
    Mmmmmmmmm beer.
  29. #149
    7,534
    Can sort out cooling system, intercooler pipe work and exhaust now
  30. #150
    7,534
    Threw rad in this afternoon. Cut the charcoal canister hanger off for more room on drivers side. Used a mix n match of Barra and ecotec rad hoses. The el twin fans I got off hoges are 10mm too wide so I am waiting for some Mondeo fans in the post
    Looks like I'm kissed on the dick with the exhaust. If I rotate the dump into the right position the cat section is perfectly straight to the cat back. Runs on a angle past the gearbox to to catback flange just at the centre bearing. That's tomorrows job
    Also got a spare set of vice grips, so I can cut and modify my old shitty ones to bead roller for cooler piping
